TECH: Clean your MAF, don't replace! - Page 6 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > General Forums > M5 E39 and E60 tips & tricks
Like Tree3Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 26th May 2012, 16:03   #51
dimi_108
dimi_108's Avatar
Garage: Carbon Black 2001 E39 M5
I'm going to do this next weekend. Thanks so much mate!
2001 E39 ///M5
S62 5.0l V8 400hp 500nm
Build thread
85% mechanically restored. Estimated completion February 2013.
dimi_108 is online now   Reply With Quote
Old 26th May 2012, 18:03   #52
ger
ger's Avatar
Garage: M5 Le Mans Blue
Airflow across the maf needs to be in the correct direction, in this case towards the centre of the car. Both left and right hand side maf sensors are the same so to get the correct airflow one has to be inverted compared to the other. They are all like that sir!
Re the stripped thread, I'd be inclined to add some epoxy to the hole and screw in the screw, then add a zip tie over the screw's head to ensure it won't come out. You might be lucky and find someone has a spare maf tube they could sell you for a reasonable sum. Until then I'd be confident that the repair would be ok (in a normally aspirated engine the air is sucked in, so it would have the effect of sucking the maf sensor in rather than pushing it out).
Hth.
Originally Posted by pingufreddy View Post
HI,
I own a 2002 M5 with 50k. miles in mint condition.
I was worried about the MAF's and thought that they may be slowing the beast down b/c I bought oiled fiters from K&A (?)
Anyway. I just cleaned my MAF's after locating the hard to find Torx safety 25 ratchet bit. The left hand MAF (facing the car) had a ripped rubber housing cover. I noticed that there was no writing on the MAF plate itself visible to the person looking down at it. I removed the screws, and saw that the MAF wires were facing DOWN in the assembly. The way the harness was set up it was impossible to rotate the plate to face up.
On the right side it was the opposite. The MAF wires pointed UP. On this side there was no rubber cracking or wear. Also, the screw on the left hand side (top) was stripped; tightened but not all the way and kept revolving.
I cannot get a throttle body replacement without buying a whole new MAF.
What do you thin about the opposite facing of the MAF's ? By design or by someone being stupid? DOes it make a difference in performance?
Thanks,
Joe
11/2000 M5 Le Mans Blue
My car's thread
ger is online now   Reply With Quote
Old 12th July 2012, 04:36   #53
Tjlazer
Tjlazer's Avatar
Garage: 2002 titanium silver M5
Video link now dead? Any ideas where I can find this?
Tjlazer is offline   Reply With Quote
Old 23rd July 2012, 23:01   #54
Skills
Garage: matte black e60 M5
I am going to try this. It doesn't look like it can hurt anything...
Skills is offline   Reply With Quote
Old 9th September 2012, 21:10   #55
Edgy36-39
Garage: Le Mans 2002 M5, Fern 1999 M3
Anytime Tools 11 pc 5-POINT STAR TORX TAMPER PROOF SECURITY BIT SOCKET SET - Amazon.com
Can anyone else confirm this is the right bit kit to get for an '02? Local store kits don't fit. Thanks.
FULL SCALE HOBBIES:
Fern Green 99 M3, Stamped LTWs, Conforti Software and CAI, Dinan Exhaust, OE Hellas and a few other nice touches. MRegistry listing here.
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, a few other nice items. MRegistry listing here.
Work, Wine and Wheels: http://chrisparente.com
Edgy36-39 is offline   Reply With Quote
Old 4th April 2013, 06:23   #56
rrides
Garage: 2000 M5 Carbon Black
Coincidently I cleaned mine right before seeing this thread hoping that it would solve the sporadic jerky acceleration I was experiencing in first and second gear. Used the CRC spray last night, drove the car all day without experiencing any throttle issues.
rrides is offline   Reply With Quote
Old 4th April 2013, 06:26   #57
rrides
Home Depot here in Atlanta sells a full set of bits with a hand driver for $10-$20.
Old 5th April 2013, 21:23   #58
Kthxbye
Garage: 2012 Range Rover Sport
Cool, thanks for sharing
Kthxbye is offline   Reply With Quote
TECH: Clean your MAF, don't replace! louv E39 M5 and E52 Z8 Discussion 42 12th November 2010 12:45
KN filter and MAF....Lost power? Gaspasser E39 M5 and E52 Z8 Discussion 7 3rd September 2003 10:48
TECH: tire life. when do you know to replace your tires? young-nyc E39 M5 and E52 Z8 Discussion 12 14th June 2002 11:47
Stop tech Big brakes or Brembo. Rave E55 E39 M5 and E52 Z8 Discussion 0 15th January 2002 03:32
