BlueTooth DIY. - Page 4 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > General Forums > M5 E39 and E60 tips & tricks
Like Tree2Likes
Old 23rd September 2005, 16:29   #31
Pip
Garage: E39 M5 Carbon Black
Re: BlueTooth DIY.
Firstly sorry to post another explanation on rost12's post explaining the same thing without those lovely photographs but I just thought I would point out how easy it was to install on a 1999 M5 which already had the BMW factory fit Motorola.
Just to let you know that I put in a retro fit BT system courtsey of a wiring loom from bimmernav.com and the ULF module # 84 106 969 268 'courtesy' of BMW.
A ULF module number was given to me by bimmernav.com as the most recent but then BMW gave me the above number as being for my chasis number even though it was them that said they/I could not put in a BT system.
Wiring loom $350 + $25 p&p (bimmernav.com)
BMW ULF module £300 (probably USD 300 ??? despite 1.8 conversion £/$)
BMW ULF bracket £12 ($12??)
Phone holder £20 (new but private purchase)
Nokia 6310i re programming £10 (Nokia supplier)
Probably a hour or two work depending on how much hoovering and cleaning you do as you go along. Remove centre armrest via the crappy cupholder and connect up part of the wiring from bimmernav.com. Open boot and disconnect the navigation system to insert the new ULF and ULF bracket. Add in the new wiring loom from bimmernav and remove the old gubbin's from the old phone. Obviously reconnect the nav system (checking on the connections to the unit - my silly mistake, hence this post).
Finally remove the rear seat to place the 'antenna' for the BT system which communicates with the ULF system in the boot (it is recommended that it is put under the rear seat for maximum reception). A wire connected to this needs to be fed through to the boot setup which can be a little fiddly. Pairing of the phone as per the handbook can then begin. You may also have to get your phone reprogrammed with the latest operating system for the whole thing to work properly my Nokia is two or three years old but is still an excellent phone without all that camera/MP3 sh*t (I only want to communicate).
All the usual features of the modern day BMW BT system work such as the steering wheel button and dashbord display. I should add that my system replaces the original BMW Motorola 8700 set up. Having spoken to Baz a 1999 year 528 owner (Thankyou again for your assistance), who had the older BMW phone connected by a line to the car you may experience a problem with not having a coaxial cable running from the centre armrest to the boot and so have to purchase some specially thin coax and then feed it under the carpet to the boot. Nauseating.
For fellow UK residents I should point out that BMW have a list of BT approved phones on www.bmw.co.uk/bluetooth and I suspect it might also be useful for Yankees too although they should probably check that the phone is Tri-band for US usage.
I should also add that having a phone specific tray will ensure that the signal is boosted (it falls out when sat in the car loose) and the power is replaced through constant charging as BT saps the battery as gurus will know.
All in all SUPERB. I now have two smiles when I get in my car.
Pip .
Ps Questions on a postcard.
Pip is offline   Reply With Quote
Old 18th January 2006, 16:53   #32
Clem
Clem's Avatar
Garage: 2003 Jet Black Beast
Question:
Will the OEM setup work if you have the "Euro styled" armrest with the storage tray underneath but without the center divot/cell phone snap in?
Respect a mans car, a man respects you.
"In every detail, the M5 was a poster child of the M philosophy: superb driving dynamics, luxurious interior and above all, uncompromised performance."
- BMW.ca regarding the E39 M5
~03 ///M5: SchwartzII/Imola, PDC, M-Audio, Rear Sunshade, Split Fold Rear Seats
Appearance: front grille w/
DIY sink drains & brake ducts (not installed)
Interior: ACS shift knob
| ACS park brake handle
Audio: ice>Link Plus
Electronics: hardwired V1 | Lidatek LE-30 (not installed) | BMW BT Kit | BMW V3 RAZR Snap-In
Lighting: Hella Euro headlight | Solaris Diamond Coat signal bulbs | Prolumen 5000K HID foglight conversion (not installed)
Clem is offline   Reply With Quote
Old 21st January 2006, 14:47   #33
Pip
Originally Posted by Clem
Question:
I am not sure exactly what you mean but assume you mean that there is no wiring under the armrest so would say "No" as a good guess. I think that the wiring in the armrest connects to the steering wheel control etc
I am no expert so do not take my answer as read. Probably best to speak to the 'ever so uninterested stealer'!
Pip
Old 12th February 2006, 19:28   #34
ambishop
Guest
Garage: 740i, M6, 928S4
Just as a quick follow up here. I am no longer using bmwbluetooth.com as a source to make the Bluetooth harnesses. Things seemed to fall apart a while back and I now have a better option for making the harnesses using all BMW OEM parts. It was a little cheaper having Parag make them early on, but I now would just prefer to have all BMW parts
Martin
www.bimmernav.com
ambishop is offline   Reply With Quote
Old 18th August 2011, 19:15   #35
NachtBlau
NachtBlau's Avatar
Garage: E39 M5 Nacht Blau Metallic Individual
What happened to the pics?
NachtBlau is offline   Reply With Quote
Old 13th July 2012, 05:53   #36
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
So 8 years since this thread, I still do not have Bluetooth in my beast. I feel like a techno dinosaur when it comes to ICE. Can someone fill me in on the skinnys of retro fitting Bluetooth for a 2001 with Mk4 and factory phone harness? Tried search and that landed me here.
Old 13th July 2012, 15:39   #37
Pip
Crikey, you are a little behind the curve. In essence you need to buy a wiring loom (Bimmernav.com) and a BT ULF module (essentially a little box of tricks that goes in the boot and replaces the smaller phone/ULF unit you will have in there). You may also have to buy a bracket to hold the ULF in place. It depends what sort of bracket is in there at the moment. Mine had CD changer and the Tv unit so I do not think I really needed a new bracket but bought one just in case (approx GBP15/USD 22). I have a spare.
The wiring loom bastardises the existing phone wiring (I had the old flip type BMW Motorola c/w curly wire) and goes in the armrest (access via rear cup holders). Then I seem to remember removing the back seat to put the BT antenna in place and simply disconnecting the old ULF and plug and play on the new one.
After that simply synchronise the phone to the ULF module utlising the controls on the armrest or steering wheel.
I did mine in 2004 so my description may be a little rusty.
Best of British luck.
Pip
See here: BMW E39 Bluetooth Installation instructions - Bimmernav BMW Upgrades
The Following User Says Thank You to Pip For This Useful Post:
bimmerule (13th July 2012)
Bluetooth Parts and Info for US Cars TommyGun E39 M5 and E52 Z8 Discussion 70 4th June 2004 18:16
BlueTooth DIY. rost12 E39 M5 and E52 Z8 Discussion 11 20th August 2003 13:44
Visteon and BMW planning September Bluetooth rollout Teutonaddict E39 M5 and E52 Z8 Discussion 2 27th August 2002 19:40
Confirmed - Bluetooth phone for MY03 andrewe E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 21st August 2002 14:32
OT: New Motorola Bluetooth Car Phone Kit JFB E39 M5 and E52 Z8 Discussion 10 9th January 2002 23:27
