Originally posted by MEnthusiast
just in case anyone looks at this in the future- I got it to work by tapping into that green wire. as I suspected it wouldnt cut the circuit because both sides of the connector are metal- it just taps in to it. works great. here are some pics
http://homepage.mac.com/z8mania/PhotoAlbum22.html
Good to see you've installed the unit.
I noticed you have wires coming out of the UGDO area however if you look by the windshield, the wires from the rear view mirror goes thru a small rubber boot to the power source.
Maybe the above is hard to understand however you can PUSH the power wires out the same black rubber boot that's by the windshield. It'll give you almost a stock/clean look without wires hanging out.
Just follow the rear view mirror wires up and you'll find the area I'm speaking of.
Mola
