Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 8th September 2002, 22:05   #1
JFB
JFB's Avatar
Garage: 2001 M5 Royal Red / Caramel / Burl
Tech: Lidatek Installation - Lighted Rocker Switch?
While looking at Jeff's (sysvr4) installation instructions for the Lidatek laser echo LE-20, I noticed the push button toggle switch he installed for his MP3 player. He mounted that in the pop-out panel to the left of the fog light switch. I thought that looked nice.
I thought it would be cool to re-wire the Lidatek-provided toggle switch to a lighted automotive rocker switch. I found a nice looking one (Gardner Bender: Rocker - Mini, Lighted - GSW-48) that states that it is for automotive uses.
My idea was to eliminate the Lidatek-provided LED and use the lighted rocker switch instead. I'm having a problem, though, getting the rocker switch to light when the Lidatek alerts.
I used the dremel tool to cut out a rectangular hole centered in the pop-out panel. The hole barely allows the switch base to squeeze though, but the hole is narrower than the lip of the switch base that protrudes above the pop-out panel. Mounted in the panel, it looks very nice.
There are three connectors on the rear of the rocker switch, each with a spade terminal. They are numbered and labeled:
  1. Line
  2. Load
  3. Neutral
I clipped the three wires off the toggle switch provided by Lidatek.
I attached to the red power wire (with the fuse) a female terminal that snaps into the rocker switch spade terminal. I connected the power wire to terminal #2 ("load") on the rocker switch.
In the Lidatek-provided toggle switch the other two red wires (that run to the transponders and speaker) are soldered to the same terminal. I attached both of them to the same female terminal connector, and I connected the two red wires to terminal #1 (line) on the rocker switch.
Terminals #1 and #2 are the ones that close the circuit when you toggle the rocker switch. That part works fine. When I turn on the switch, the Lidatek speaker chirps. I used an IR remote to test the two transponders, and the system alerts just as it is supposed to.
I have not yet mounted the transponders on the bumper. I seem to have misplaced the 8mm socket. Funny, that happens to the same one that fits the trucks on my son's skateboard.
Anyway, to get the rocker switch to light, I tried running a wire from the white line that connects to the transponders, and hooking it to the #3 (Neutral) terminal on the rocker switch. This is the same white wire that connects to the black speaker wire and that would connect to the black LED wire, if I were using the LED. No luck.
I just can't seem to get the switch to light, and I'm not an expert in this stuff. It's possible that I have a bad light in the switch itself (I'll check that). I am assuming that is not the problem, though.
Do you guys have any thoughts on how to wire this so the rocker switch will light up? Here's the wiring diagram...
Jim
2001 ///M5 Royal Red / Caramel
JFB is offline
Old 9th September 2002, 01:53   #2
JFB
JFB's Avatar
Okay. I figured it out. The lighted rocker switch I was using required too much voltage to power the light. I changed it out for a 12 volt automotive lighted rocker switch just to test the theory.
With the white wire attached to the #3 (Neutral) terminal, the red power wired connected to the #1 (line) terminal, and the two red transponder wires connected to the #2 (load) terminal, the LED functioned perfectly. It lit up briefly when I turned on the switch, and lit up like crazy when I tested the transponders.
Unfortunately, the lower voltage rocker switch it is too wide for the pop-out panel.
Now, I just have to find a 12 volt lighted rocker that will fit in the pop-out panel.
I'll let you know what I turn up.
JFB is offline
Old 9th September 2002, 04:08   #3
TiGumz
TiGumz's Avatar
Garage: 2001 M5 Anthracite
Great Idea
Jim,
I like the idea of combining the light and the switch. Please post pics of your install when you complete it.
Glenn
08 M5 Interlagos
Dinan Exhaust
01 M5 Anthracite
UUC short shift
Dinan 3.45 Diff
07 Exige S
TiGumz is offline
Old 10th September 2002, 07:25   #4
JFB
JFB's Avatar
Rocker Switch Installed
Glenn
I uploaded the pictures. You can see the installation on this page.
Jason
If you see this, feel free to host the images and post them onto this messageboard.
JFB is offline
Old 10th September 2002, 14:14   #5
Russ
Russ's Avatar
Garage: Y2000 M5 - Royal Red
Originally posted by JFB
Okay... changed it out for a 12 volt automotive lighted rocker switch... a 12 volt lighted rocker that will fit in the pop-out panel... I'll let you know what I turn up.
JFB, so what's the part number of the "recommended" rocker switch? Manufacturer? Cost?
Thanks much!
Russ
Russ is offline
Old 10th September 2002, 14:43   #6
CM5GO
CM5GO's Avatar
Garage: 2003 Porsche C4S .. Black / Grey
Wow! Very nice job!
Chris Z
2003 Porsche C4S
Jet Black on Grey
6spd
B&B Tri Flo's, K&N's
Dinan Stage II Software,
UUC Short Shift, ACS Pedals
Euro angel eyes
StageII Xenon, Amber Fogs
19 inch BBS LM's
KW Variant 2 Coilovers
Nowack / HD Ducts
Mintex Pads (red box)
Euro arm rest
(press www button for pics)
SOLD! (boohoo)
2001 X5 4.4i sport (Sold!)
Audi All-Road 2.7t (Wifey)
CM5GO is offline
Old 10th September 2002, 17:14   #7
Diamond Dave
Diamond Dave's Avatar
Garage: 2000 Ford Expedition
Jim,
Fabulous installation there. Very clean. I admire that.
Believe we would all appreciate a future update as to the performance of the unit. Would love to read a post from you stating how the Lidatek saved your back side. Dang Flower Mound police!
Take care,
DWP
Diamond Dave is offline
Old 10th September 2002, 17:59   #8
atomic80
M5 Extraordinare!
atomic80's Avatar
Garage: 2007 Cobalt Blue Porsche 997TT
Here are the pictures/instructions:
M5 in dash rocker switch installation for Lidatek LE-20
This shows the pop-out panel from the left of the foglight switch. The rectangular hole was cut with a dremel tool, and the edges filed.
Measurements are distance from hole to edge. Narrow edges are 3mm wide. Top and bottom are 10mm wide.
Switch is a 12 volt lighted mini rocker switch.
Showing switch inserted into the pop-out.
Showing wiring for the rocker switch to operate the Lidatek LE-20.
Terminals are numbered, bottom to top:
#3 is white wire to transponder (also connects to black speaker wire).
#2 is red wires to transponders and speaker
#1 is power (connects to fuse)
Showing switch and pop-out mounted in the dash panel. Switch turns on/off Lidatek and illuminates to indicate transponder alert.
Jason
'05 Range Rover w/mods
'05 K1200S w/mods
'07 997TT w/mods
'08 Audi A3 w/mods
atomic80 is offline
Old 10th September 2002, 23:10   #9
JFB
JFB's Avatar
Moderators
Can you guys delete this thread? It duplicates another thread.
I'm not sure how we ended up with two identical threads.
JFB is offline
Old 11th September 2002, 01:42   #10
atomic80
M5 Extraordinare!
atomic80's Avatar
Re: Moderators
I copied this thread here for those that wanted tips.
atomic80 is offline
Valentine One / Lidatek M5, M3, Z8 Rearview Mirror - FOR SALE BeastPower For Sale or Wanted 8 4th December 2009 15:52
Lidatek install - post installation notes MikeNJ E39 M5 and E52 Z8 Discussion 7 28th September 2002 02:57
Tech: Lidatek Installation - Lighted Rocker Switch? JFB E39 M5 and E52 Z8 Discussion 15 11th September 2002 01:07
TECH: spring installation height difference. young-nyc E39 M5 and E52 Z8 Discussion 20 13th June 2002 16:35
Page generated in 0.19526 seconds with 11 queries
