Power steering fluid question - Page 2 - The Unofficial BMW M5 Messageboard (m5board.com)
Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 1st December 2011, 01:17   #11
Edgy36-39
Garage: Le Mans 2002 M5, Fern 1999 M3
I can see this is old, but for when others find this thread. Here's what maintenance guru Mike Miller says in his old school maintenance recs:
Power Steering Fluid
Replace every 30,000 miles. This is a very neglected operating fluid. Almost all BMWs use automatic transmission fluid in the power steering system, except for some E32 7 Series cars, which use Pentosin hydraulic oil. Nothing will balls up the works faster than using one when you should be using the other. Check the sticker on the reservoir, check the owner’s manual, and if you are still confused, take the car to a pro or e-mail me.
It is not necessary to evacuate the entire power steering system. I just open a line down by the pump.
I have had great experience using Red Line Synthetic Power Steering Fluid – 184,000 miles and counting on the original rack and pinion unit and pump on the vehicle I used to test this product. But I would not use it in place of Pentosin hydraulic oil where that product is specified.
Point is, Red Line call is PS fluid but its ATF.
Nice to read that some have used Mobil with no problem. I'm low and need to top off, and can't find Red Line at the big box auto stores.
There is nothing about power steering fluid in the owners manual, not even how to check. Very lame, BMW.
FULL SCALE HOBBIES:
Fern Green 99 M3, Stamped LTWs, Conforti Software and CAI, Dinan Exhaust, OE Hellas and a few other nice touches. MRegistry listing here.
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, a few other nice items. MRegistry listing here.
Work, Wine and Wheels Blog http://cparente.wordpress.com
Edgy36-39 is offline   Reply With Quote
Old 7th February 2012, 19:52   #12
ACHTUNGM5
ACHTUNGM5's Avatar
Garage: 2001 M5 TITANIUM SILVER
does Castrol make a synthetic trans fluid that could be used for the power steering?
ANSWER IS NO CHECKED IT OUT
ACHTUNGM5 is offline   Reply With Quote
Old 25th March 2012, 01:08   #13
Soup Nazi
Soup Nazi's Avatar
Garage: SC'ED E36, '01 E39 M5
I topped it off with pentosin atf1.
Seems to be alright.
Soup Nazi is offline   Reply With Quote
power steering fluid question mkdz E39 M5 and E52 Z8 Discussion 22 17th February 2010 04:27
Power Steering fluid MAH E39 M5 and E52 Z8 Discussion 27 2nd November 2007 17:01
EDC/Power Steering fluid question plisken E34 M5 Discussion 2 30th November 2004 04:55
power steering fluid ?? cardriverm5 E34 M5 Discussion 6 10th November 2004 00:50
power steering fluid 91 M5 12otis E34 M5 Discussion 3 25th March 2002 14:37
