Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 12th March 2002, 06:00   #1
1C00lVC
1C00lVC's Avatar
Garage: '01 Ti/silver E39 M5
Send a message via AIM to 1C00lVC Send a message via Yahoo to 1C00lVC Send a message via Skype™ to 1C00lVC
Nav Sw Ver 18 upgrade - FAQ
from bimmer.org http://members.roadfly.com/csauerbry/navfaq.htm
Nav Software CD V.18 FAQ – Updated 2/10/2002
1.) The new graphics/features are for the Mark III system ONLY. The Mark III system is installed on all 3-Series produced after 6/2000, 5 & 7 produced after 9/2000. The version 18 CD update will take the MK III system to version 4.0. The version 18.2 CD update will take the MKIII system to version 4.1.
2.) The update disk DOES work on the MKII system installed on all 1999 and 2000 models, however the MKII does NOT get the new graphics, features, etc, but does get many bug fixes and a slightly improved trip routing logic. The update disk will take the Mark II system to version 8.0.
3.)The software is NOT available for download. You must either have the dealer do the upgrade (some actually do have both required CD's) or purchase the upgrade kit from BMW.
4.) The software IS available for at your dealer's parts department. The part number is 65 90 0 140 531 and the description should come up as "Split Screen". The upgrade kit includes the Software-CD, Key-CD, and instruction manual. Only purchase the kit though if you are positive you have the Mark III system otherwise you will be wasting your money. Most if not all dealers should have the version 18 Software-CD and if you have the Mark II system you will not need the Key-CD to complete the installation like the Mark III system. – UPDATE – The dealers are no longer selling the version 18 disk since the 18.2 CD has been released. The part number for this disk is 01 59 0 141 891. This part number is ONLY the software cd and does not include the Key-CD. I do not know if BMW has released an updated software kit, but I will post the part number if I found out what it is.
5.) If you can confirm you have MKIII system, but your dealer says you can't upgrade, THEY ARE WRONG. It does not matter that the 2001's do not have the widescreen. IT WILL WORK. To prove them wrong, get the upgrade kit, install it, show it to them and then smile when your service advisor is completely stumped and looks like an uninformed idiot!
6.) The Software-CD and Key-CD are linked together which means you cannot use any Software-CD with any Key-CD. Each Key-CD has a matching Software-CD so if your dealer has the Software-CD, you cannot use a Key-CD that you may have obtained elsewhere.
7.) The Mark III system is the only nav version that requires the Key-CD. If you are doing the upgrade on a Mark II system, you will NOT be asked to insert a Key-CD after you complete the upgrade.
8.) The version 18 disk is NOT the map update disk that you receive from NavTech. The nav software updates the operating system of the navigation computer. The Map disk just provides the map database for the navigation system. They are separate and unrelated.
9.) Version 18 does not mean you have version 18 of the navigation software. Version 18 means that the software CD is the 18th Navigation software CD BMW has released since first offering the Navigation System as an option. The version 18 disk will update the MKIII to application version 4.0 and MKII to application version 8.0. The version 18.2 disk will update the MKIII to application version 4.1 and Mark II to application version 8.1.
10.) If your dealer does the upgrade, but doesn't have the Key-CD and has to take you back to version 17, the navigation system may get reset out of USA mode. You will know this has happened if you are now receiving directions in yards instead of feet and the "Emergency" option has disappeared from your main menu. To fix this, make sure the dealer hooks the car up to their computer and resets the navigation system to "USA".
11.) If you upgrade your MKIII system with the version 18 disk and do not have CPT-8000 installed, you will not see the "Emergency" option in the main menu since this information can now be accessed by using the split screen option and selecting the on-board computer option. Again, this will only show as a dedicated menu option if you have the CPT-8000 cellular phone installed.
12.) On the MKIII system with the version 18 upgrade disk installed, the 2001.1 disks from NavTech work with no problem, but the newest 2001.2 disks are better optimized for the new version and run a little bit faster than the 2001.1 disk.
14.) You do loose the OBC+Radio option if you have the MKIII system and choose to upgrade. It comes down to personal preference, but in my opinion, the new features far outweigh loosing this.
15.) The way to determine which Nav software version you have is to go into either “Set” or “Settings” from the main menu. In the upper right hand corner, (see picture) you will SW x-x/xx. The first number indicates which generation nav system you have. 1 indicates MKI, 2 indicates MKII, and 3 indicates MKIII. The second number (which will most likely be 1) tells you that you have the full color “high level” nav screen. The third numbers tells you the software version. The version 18 disk will take a MKIII system to version 4.0 and show 1/40. The 18.2 disk will take the MKIII system to version 4.1 and will show as 1/41.
16.) The 18.2 Nav Software CD has been released by BMW. If you have used the version 18 disk to bring your MKIII system to software 4.0, you will have no problems using this disk. If your MKIII system is still using a software version below 4.0, the system will ask you for the Key-CD which most dealers do not have. You will need to first upgrade to version 4.0 using the version 18 software CD and Key-CD. If you have a 2002 vehicle, you will not have a problem as all 2002’s came from the factory with the 4.0 software. Cars produced after sometime in December have the 4.1 software loaded and the nav system is completely up to date. The only way to know which software you have is to check your software version.
17.) The 4.1 software that the 18.2 CD load onto the MKIII system is mainly a bug fixer. BMW has not added any new features to the software. With the 4.1 software, the nav system runs a little but quicker and much of the lag time that was present with the 4.0 software has been removed. The OBC+Radio is still not available, so it is probably safe to assume that BMW has removed that feature.
Arie
Remember, with an automatic transmission, Shift Happens....
'01 M5 - Titanium Silver/Siilverstone/Aluminum trim
- PDC
- Split seats
- deleted spoiler
- M Audio
- 8000 phone
- Voice Reco
- TV tuner
My Website
1C00lVC is offline
NAV upgrade Rezf E39 M5 and E52 Z8 Discussion 12 9th January 2006 20:54
F-U-N With NAV Upgrade MJ E39 M5 and E52 Z8 Discussion 9 10th February 2002 21:49
updating NAV software...very simple, quick, and painless. 6 minutes. Jacob Lee E39 M5 and E52 Z8 Discussion 7 2nd February 2002 16:27
Early MY 2000 and NAV ver. 18 - impressions AJ E39 M5 and E52 Z8 Discussion 1 28th November 2001 18:28
Page generated in 0.13764 seconds with 11 queries
