Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 5th April 2009, 16:24   #1
xsrdx
xsrdx's Avatar
Garage: 2003 M5, Carbon Black
Fluid Extractor (vac pump)
Just did my first oil change with a vacuum pump, took me about 30min including filter. You remove the dipstick, insert the dipstick tube to the bottom of the oil pan, give the handle a few strokes to build vacuum, and just watch the reservoir fill up with used oil. Sucked my oil pan dry, filled to the top at just under 7QT.
If you're still using ramps and wrenching drain plugs, or using the dealer for oil changes, a pump saves you considerable time and effort or time and $$, depending on your chosen method. And in the case of using a dealer, no more worries about too much, too little or what oil they used.
For cars with no access to the filter topside, the pump is of marginal value because you still have to get under the car to change the filter. I'd have to empty it twice to do an oil change for my Ford 7.3L Powerstroke and I can get under my Jeep without ramps, so no real utility there.
But in the case of the E39 M, I didn't even have to change my clothes.
Very cool gadget. Mine is from Griot's, 6.8QT capacity, but would guess they are relatively generic items. Best thing is I never have to visit a dealer again for a routine oil change.
xsrdx is offline
Old 10th April 2009, 14:23   #2
malexgcab
malexgcab's Avatar
Garage: M5 CB
Mess free and easy.
malexgcab is offline
Overhearting ?, Fluid ?, Water pump ?, Sensor ? Ehhh? its fixed itsself ! stumbo E39 M5 and E52 Z8 Discussion 2 6th October 2008 04:51
Hand Pump Oil Extractor? Tenzin E39 M5 and E52 Z8 Discussion 10 22nd May 2007 22:55
Griot Garage's Hand Pump Oil/Liquid Extractor lestat832 E39 M5 and E52 Z8 Discussion 19 21st August 2006 18:50
DIY Dummies Guides to Oil Change using Fluid Extractor HDClown E39 M5 and E52 Z8 Discussion 0 18th September 2005 01:46
Problem with washer fluid detergent pump fumaras E39 M5 and E52 Z8 Discussion 1 24th December 2003 18:52
Page generated in 0.08031 seconds with 11 queries
