Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 5th February 2009, 12:26   #1
304M5
304M5's Avatar
Garage: MY 2001 BMW M5 354 M - Titanium Silver, E36 BMW M3 - Estoril Blue & MY 2002 E39 BMW M5 TOURING...
How to set / fix Tyre Pressure Control Monitor in E39 M5
Hi, i previously had problems with my Tyre Pressure Control Monitor in my 2001 e39 m5 but now i have fixed it. So if yours is not working here is some useful infornation on how to fix it:
Firstly, turn the key to ignition (do not start it).
Secondly, hold the tyre pressure control button down for approximately 5 seconds (keep it pressed, do not let go). Then when it comes up on the OBC or computer "set tyre pressure" then you can let go.
Lastly, once you have let go of the button you can start the car and drive it around for a bit for it to set the tyre pressure control monitor.
IMPORTANT: If it comes up on the OBC or compter "tyre pressure control inactive" then follow the instructions above. If you have the car started and press the tyre control button it will say "tyre pressure control inactive" automatically and you have to follow the instructions above again to set it.
I hope this helps. Thanks
E39 ///M5 & E36 ///M3
304M5 is offline
The Following 2 Users Say Thank You to 304M5 For This Useful Post:
Alin10123 (9th February 2009), zarnd (21st February 2009)
Old 9th February 2009, 13:00   #2
Alin10123
Alin10123's Avatar
Garage: 03 LMB M5, 05 TSX
Thanks for the tip!
I was wondering how you set that up.
Alin10123 is offline
Old 21st February 2009, 12:45   #3
zarnd
zarnd's Avatar
Garage: 2002 Le Mans BLue M5
Thanks for the tip! mine has been doing this for well over a year, but assumed that there was a fault with it so left it alone!
Will give it a go though!
cheers
Alex
2002 M5 - TotalBMW Feature car September 2008
2000 Land Rover Defender - Land Rover World Feature Car June 2007
1989 VW Golf GTI - Track Car
zarnd is offline
Old 20th May 2009, 02:31   #4
skeggy
Garage: le mans bluw E39 M5
i still cant get mine to work! I get to the point of driving around, but then nothing happens - if the button is pressed again i get the inactive message come up - have tried loads of times and everytime the same
Any tips
skeggy is offline
Old 26th May 2009, 21:53   #5
304M5
304M5's Avatar
If everytime you press it it comes up as "tyre pressure control inactive" then that means there is a fault. It could be that one of your sensors from the wheels do not work.
304M5 is offline
Old 26th May 2009, 22:11   #6
skeggy
is there anyway to see / feel them behind the wheels without taking them off - not even sure if mine are still on the wheels
skeggy is offline
Page generated in 0.09872 seconds with 10 queries
