Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 29th October 2008, 17:47   #1
street1407
Garage: M5 2001 Velvet Blue
Stalling M5
I have recently aquired another E39 M5, after a unhappy period in a 535d M Sport and that dim witted auto box!!. Love being back in the beast but have come across the same problem I had with my last M5, after a long run and with the engine nicely warmed up the engine has a tendancy to stall when knocked out of gear i.e long run on the motorway take the slip road off to the roundabout go down through the gears knock it into netural and when you are rolling up to the roundabout it stalls..losing the assistance to the steering and brakes! This is becoming fairly common when it is warm and the revs do seem to dip low (below 500rpm) whenever you knock it out of gear and then rise again to around the 650rpm idle. Has anyone had the same problem and if so what was the cause of it? Greatly appreciate your comments.
street1407 is offline
Old 22nd January 2009, 01:48   #2
g.p.racing
Garage: E39 M5 carbon black
hi,
i realise im a bit late in adding a comment but ive recently had similar problem, returned to dealer they plugged in and decided the breather pipes had perished 9they had gone really soft )which was causing the cutting out-they replaced the pipes and seems to have solved problem.
hope this may help someone
G.P.
g.p.racing is offline
Old 22nd January 2009, 11:27   #3
street1407
thanks for that, I think that may be a solution. Have discussed potential air leaks etc although they have tried to avoid doing that. They have just replaced the temp sensor - to no avail and they are now considering the replacement of the oxygen sensors. I think I will as for the breather pipes first as this would lead to faulty readings on the oxygen sensors?
An M5 to M5 waive... finally! joenjolera.com E60 M5 and E61 M5 Touring Discussion 23 2nd November 2008 04:37
Help. BT stalling apbails ALPINABoard.com | BMW Alpina Discussion 7 18th September 2007 06:23
Troubleshooting stalling? Jayson E39 M5 and E52 Z8 Discussion 3 6th August 2006 00:11
Stalling problem ! Nelson E39 M5 and E52 Z8 Discussion 5 18th March 2003 23:20
Stalling problem Tim K E39 M5 and E52 Z8 Discussion 3 14th September 2001 12:44
Page generated in 0.08483 seconds with 11 queries
