Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 7th July 2008, 15:45   #1
widebody32
Garage: 540i m sport/gtr skyline/e46 323
Help with m5 cluster swap into 540auto
I have recently swapped a e39 m5 cluster into my e39 540 sport and am after some help.
Everything works apart from the reverse features as in lights and rear pdc.
This is due to the cluster being from a Manual car and mine being a Auto.
From what i can work out it is somethin to do with the can interface and the ike not sending the signal to the lcm. Is there anyway i can bypass this or hook up a micro switch to act as a reverse light switch?
Any help would be appreciated
widebody32 is offline
Old 1st November 2008, 22:52   #2
BCUZICAN540
BCUZICAN540's Avatar
Garage: Montreal 540i, Dakar M5
Send a message via AIM to BCUZICAN540
You need to have the cluster coded to the car that you are driving. GT1 will solve your problems along with adjust the mileage to match the mileage on the vehicle. If you dont have the correct mileage a little dot will apear next to the mileage in the cluster.
BCUZICAN540 is offline
Old 17th November 2009, 05:37   #3
e39Aram
Garage: 540i silver
Send a message via AIM to e39Aram
I have a different problem I can't see my mileage at all it shows some numbers but you can barley read them anyone know how to get around that???? please reply thanks!
e39Aram is offline
Whats the best way to correct the speedometer? Kmac E39 M5 and E52 Z8 Discussion 24 3rd July 2008 02:11
Mafs test info request after disapointing dyno nerio02 E39 M5 and E52 Z8 Discussion 5 7th February 2008 18:05
m5 instru cluster swap on a 540??? firemanory GTBoard.com: General Sportscars 2 16th November 2007 14:56
Instrument cluster repair options dcaron9999 E39 M5 and E52 Z8 Discussion 10 31st May 2007 18:58
Swap M5 cluster for Alpina cluster (e39) 540is For Sale or Wanted 0 25th May 2002 19:03
Page generated in 0.07515 seconds with 11 queries
