Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 21st May 2008, 21:46   #1
Dennis215
Garage: 06 M5 Black Saphire
New Owner SMG question
Hi Guys,
I just wanted to introduce myself as a new E60 M5 owner (luv it, luv it, luv it), but I do have a couple of questions about the SMG. In "Drive" from 1st to 2nd sounds like the engine is really racing before its changes up then then it feels like i have stepped in cement during the change, after 2nd everything seems OK in the Higher gears. I have tried all the drive logic settings without much luck. I have read elsewhere that this is normal? It only seems bad from 1-2nd, do I really have to forgo Drive and only use the paddles for smooth driving?
Also is there a SMG for dummies?
Dennis215 is offline
Old 25th May 2008, 02:12   #2
holmesmd
holmesmd's Avatar
Garage: 540i 00', M5 03',06' E63 M6, 08' E90 M3
Send a message via AIM to holmesmd
Hello and welcome! A few thoughts:
1.If you are in drive mode you need to modulate the throttle to get the car to rev and shift. We have named it the "kick down" button for lack of a better term. It is the small "click" you feel when you depress the throttle far enough to get moving. If you are using the throttle and do not go down far enough the car will not accelerate like it is capable of. I am not exaggerating when I say that you need to floor it with "stabs" to get the most out of the gears. the dummy box is otherwise only concerned with fuel efficiency. That's why you find yourself in 6th gear when you are only going 50 mph!
2. You might try calibrating your tranny. While traveling in the car between 40-90 mph throw the car in neutral, depress both paddle shifters for 3-5 seconds, release them and put the car back into a gear. this will recalibrate your transmission.
3. I assume your software has been updated and your SZL censor has been changed out by the dealer. this caused problems with most of the car's systems early on.
4. You have an M5, shift it yourself! It is by far the most fun you will have with it. I only use D5 when on a long highway jaunt when I want to chill. In the city it's usually S5 or S6 all the way.
5. When in doubt, have a knowledgeable tech or SA from the dealership drive your car with you in it. Ask them about their opinion.
6. When shifting yourself, lift off of the throttle just a bit after you shift and the car finds a gear. this method was more of a requirement early but it still helps IMO. Good luck. In the future, you should try a thread search here to read over all of this stuff that we have already written. I think it's why you did not get any other responses. take care!
holmesmd is offline
The Following User Says Thank You to holmesmd For This Useful Post:
ManicM5 (31st August 2009)
Old 25th May 2008, 09:48   #3
DRM
DRM's Avatar
Garage: 2002 M5 (Chiaretto Red Metallic)
Good God!!........
My tongue is bleeding, I'm biting it so hard.
Dan
______________________________________________
Daily Driver
'02 M5 (Chiaretto Red Metallic w/black napa full heritage leather/wood trim/leather Euro cntr console/BSW speakers and sub) Sig series Dinan S/C'd S3 package/ Dinan S3 clutch-flywheel/Dinan high capacity oil cooler /Dinan forged aluminum wheels/Dinan SSK/Dinan - Brembo BBK/Stg 3 Dinan - JRZ suspension/monoballs/275-35-18 RA 1's all around
The "Predator"
'02 996TT w/X50 (slate grey metallic w/full natural grey leather, small carbon package, aluminum trim pieces, exterior color painted wheels, etc, etc).
EVOMS Stage 4 (640hp/615tq)
PSS9 w/F&R H&R sways and EVOMS F&R shock tower braces
Sachs clutch and Porsche SSK
Toyo RA-1's 245/18 fronts; 305/18 rears
DRM is offline
Old 25th May 2008, 17:22   #4
holmesmd
holmesmd's Avatar
Why Dan? Did I say something wrong?
holmesmd is offline
Tags
smg
New M5 owner, CPS question teutonic rx E39 M5 and E52 Z8 Discussion 6 14th September 2007 18:57
Press Release no 3: The Seven-Speed SMG Gearbox Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 15th December 2004 01:18
An in-depth SMG II review (LONG) kenneth E39 M5 and E52 Z8 Discussion 17 10th March 2004 01:31
SMG Question? M3Finally E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 1 21st December 2001 07:47
SMG Question M3Finally E39 M5 and E52 Z8 Discussion 10 21st December 2001 06:44
Page generated in 0.11764 seconds with 11 queries
