M3 woes - BMW M5 Forum and M6 Forums
M3 E36 1993-1999 Sedan, Coupe and Convertible (incl. SMG models)
post #1 of 4 Old 5th July 2002, 04:21 PM Thread Starter
m3man
Question M3 woes
Hi guys, I'm new in this forum. I have some problems with my M3 3.0 and I'm looking for some god sent advice!! When the car is cold there is some hesitation in the low-revs band 2-3k and as soon as it warms up the car is practically dead in that region. Above 5k its fine. Any ideas? The DIS has showed nothing, spark plugs, fuel filter are both new, injectors are cleaned air flow meter is new and still the problem is there PLEASE help!!! Many thanks
m3man is offline
post #2 of 4 Old 8th July 2002, 10:05 AM
Andy G
Is It the vanos?
Have you had the Vanos checked? mine hesitates when freshly cold at that point, but as soon as the engine is warm, it now performs as normally (after a minute or two), my dealer originally checked the vanos (as this was his original assumption) when it first had this symptom but found that to be ok, when he checked the Lambda probe, that was faulty, it was also shown to have a small air leak, so check all your connections as well. Have you had it looked at by a BMW dealer?
Andy G is offline
post #3 of 4 Old 9th July 2002, 02:42 PM Thread Starter
m3man
Oh god I hope it's not the VANOS!! Its going to the dealer first thing wednesday 8 am. Mine used to do the same thing when cold but now the hesitation is constant. Where should I point my attention for air leaks? As I said the air flow meter is new. Thsnks Andy G for your reply..
m3man is offline
post #4 of 4 Old 9th July 2002, 05:59 PM
Andy G
the air leaks on mine were from the one of the individual trumpets that feed the cylinders in the end, causing it to run lean throughout the rev range.
The vanos can be the weak link in an otherwise strong package.
Andy G is offline
M3 Csl!! Mr Janne E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 56 11th April 2004 11:34 AM
2001 M3 Woes technogeeky E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 1 6th August 2003 12:33 AM
2003 Bmw M3 dNA3D E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 5th December 2002 07:01 AM
ot: e46 smg m3 vs. 996 c2 for track and street? Paul S E39 M5 and E52 Z8 Discussion 18 25th August 2002 07:07 AM
The M5 killer...the Audi S4 E39 M5 and E52 Z8 Discussion 57 30th March 2000 02:23 PM
HTML code is Off
