Convert SMG to Manual - BMW M5 Forum and M6 Forums
M3 E36 1993-1999 Sedan, Coupe and Convertible (incl. SMG models)
post #1 of 5 Old 7th June 2002, 04:16 PM Thread Starter
racer_xbr
anyone knows how to convert a SMG car to a 6 speed manual ?
the gearbox can be reused ?
coments...???
the SMG will hold with a supercharger ??
racer_xbr is offline
post #2 of 5 Old 7th June 2002, 04:55 PM
Bart Carter
Bart Carter's Avatar
To accomplish your actual desire, a 6 speed, there is only one way: Order a new M3 fitted the way you want and sell the SMG car.
From a lot of experience with cars in general, this is cheaper, easier and just better in every way jthan trying to do a conversion.
-Bart
2002 Bluewater/caramel
Any other car is a compromise
Bart Carter is offline
post #3 of 5 Old 3rd August 2002, 02:17 AM
DSK M3/4
DSK M3/4's Avatar
RDSport has converted a few of the US E36 M3s from auto to 6 speed and 5 speed to 6 speed. at least for the US, the 6 speed requires a different drive shaft to connect to the differential.
the 5 speed will hold up to the power of a supercharger; i'm pretty sure the 6 speed will as well. don't know about the SMG.
good luck!
'98 M3/4
DSK M3/4 is offline
post #4 of 5 Old 5th August 2002, 12:19 AM
pride355
pride355's Avatar
In Turkey I saw several M3s that have become manual 6-speed from SMG because of the SMG problems the owners had. They just change the electronical system and put an extra clutch pedal.
I don't think it would be a problem as the SMG M3s use the same gearbox, diff. and shaft.
ONUR
'11 M3 Coupe M-DKG AlpineWhite
'09 Audi TTS Coupe ibisWhite (SOLD)
'07 911 Carrera S Coupe MeteorGrey (SOLD)
'05 M3 Coupe SMGII SilverGrey (SOLD)
'03 M3 Coupe SMGII BlueWater/Black (GONE)
'96 M3 Coupe 3.2 EVO Estoril/Grey (SOLD)
pride355 is offline
post #5 of 5 Old 5th August 2002, 12:26 AM
pride355
pride355's Avatar
About the supercharger question:
I have a friend who has a supercharged euro-spec M3 EVO which has approx. 550 HP and only parts he doesn't have any problems with that power are the gearbox and the diff.
He changed the clutch though.
I'm sure SMG car can handle 380 hp with the OEM clutch. So there won't be a problem having a supercharged SMG car.
However once you have more power you have to use heavy duty clutch which means harder pressure thus can cause a problem for SMG hydrolics.
ONUR
pride355 is offline
SMG over Std. Man. is like Windows over DOS Dirim E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 12 29th June 2006 06:21 PM
An in-depth SMG II review (LONG) kenneth E39 M5 and E52 Z8 Discussion 17 10th March 2004 12:31 AM
SMG vs. Regular Manual Trans stickboy E60 M5 and E61 M5 Touring Discussion 7 14th June 2003 11:45 AM
///M Transmission: SMG or Manual? Hutzal E60 M5 and E61 M5 Touring Discussion 5 20th September 2002 08:24 PM
SMG Press Release Omar E39 M5 and E52 Z8 Discussion 12 18th February 2001 10:45 PM
HTML code is Off
