Stock CL65 dyno results... - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > GTboard.com: Discuss other sportscars > GTBoard.com: General Sportscars
GTBoard.com: General Sportscars See the GTboard.com DVD. This form also contains a BMW X6 and X5 Forum.
Old 18th December 2006, 00:57   #1
DoctorV8
DoctorV8's Avatar
Garage: 2002 M5 Sterling/Caramel, 2001 M5 Black/Black
My car now has 16,000 miles on it. Finally had a chance to get it up on the ol' dynojet. I was very pleasantly surprised with the numbers: 559 rwhp 670 rw ftlbs.
Even without the 1% SAE correction, the car made 550 rwhp and 660 ft lbs. I am the 2nd owner, but I have no evidence that the car was tuned previously. I know for a fact the 155mph limiter is still intact, as you can see by the curve dropping off at 5200 rpm in 4th gear.
Even the A/F ratio was spot on, definitely not as rich as I expected for a stock tune. We had to use the optical sensor with a piece of tape on the harmonic balancer to pick up RPM, and finding a vacuum line to measure boost just wasn't possible.
The car trapped at 120 mph in the quarter previously, at curb weight of 4600 lbs with abysmal traction here in Houston (at sea level.)
2002 M5 Sterling Grey/Caramel/Bruyere, Rotrex twin supercharged, 2.65 gear, Brembos, KW Variant 3, B&B Triflow/X pipe, Alpha N running with Stock ECU, Stainless Brake Lines, 4 Rear Wheels, Upgraded F&R Shock mounts, Billet Throttle body gaskets, AA LTW Flywheel/Clutch
2013 458 on order
2009 SL65 Black Series
2005 Gallardo, UGR-TT, 1000 awhp/15 psi
2005 CL65 Eurocharged, 544 rwhp/744 ft lbs
1989 Testarossa
1988 928 S4 5 speed
1983 Aston Martin Lagonda
1977 450 SEL 6.9 Ronin Edition
2013 Shelby GT500 662 hp bone stock
2012 Fisker Karma EV
2010 ZR1, Caravaggio interior
2005 Ford GT, silver sans stripe, ART Twin Turbo, 205.1 mph Texas mile @ 17psi/93 oct
2004 C5 Corvette, F55 Magnetic ride, Pioneer AVIC D1, ATI D1SC Procharger, minitub, Fikse Profil5
1990 C4 Corvette ZR-1 DOHC Lingenfelter 6.8L, coilovers, Wilwood brakes, Fikse FM5, 185 mph Texas Mile
1991 Mustang LX Coupe 331 cid, Incon twin turbo, Griggs, 6 speed, SN95 ABS, Big Stuff 3
1979 Lincoln Mark V 510 cid stroker, FAST EFI, Gear Vendors overdrive
1970 Mercury Cyclone GT restomod, Roush 427 EFI/T56/Wilwood brakes/Heidt's suspension
1961 Continental, suicide doors
DoctorV8 is offline   Reply With Quote
Old 19th December 2006, 14:54   #2
FikseGTS
Garage: ACR,GT-R
awesome numbers, what was your ET with that 120 MPH trap? can you post the slip numbers?
FikseGTS is offline   Reply With Quote
Old 19th December 2006, 15:45   #3
DoctorV8
DoctorV8's Avatar
ET's were terrible due to the burnout box spanning the whole width of the lane, requiring me to drive through the water. Despite doing a burnout, I know there was water on the tires. ESP was active until nearly half track. Best 60 ft was in the 2.2 range with me babying it, best ET was 12.3. I think the traction was bad enough to even adversely affect the mph a bit.
Old 19th December 2006, 21:22   #4
Gustav
Administrator
Gustav's Avatar
Garage: BMW M3 DCT Sedan / Limousine
Wow, with a auto gearbox that is alot RWHP. Its a big beast
Google+ LinkedIn Facebook Flickr
My email gustav@gtboard.com m5board Member visiting Stockholm, Sweden? PM me to and I'll show you Stockholm! gtboard.com
Gustav is offline   Reply With Quote
CL65 dragstrip results.... DoctorV8 GTBoard.com: General Sportscars 6 18th October 2006 14:47
DYNO TEST RESULTS AT EVOSPORT em5464 E39 M5 and E52 Z8 Discussion 6 19th May 2005 18:39
dyno figures for stock 2001 m5 and powerchip sergiyz E39 M5 and E52 Z8 Discussion 13 22nd September 2003 16:20
New Dyno numbers. Jim C. vs. Stock compared as well. Tim W E34 M5 Discussion 3 3rd June 2003 10:46
E34 ///M5 Dyno Results riseosiris E34 M5 Discussion 4 10th February 2003 16:05
