18th August 2004, 18:07
#6
01 M5 Black/caramel
Re: Mallet 427Ci Supercharged CTS-V vs M5?
Originally Posted by RennSportSC'dKellenersM5
Misha,
While my car is STILL under construction, it should produce about the same power (hopefully a bit more) than that CTS-V.
A BIT more?? CTS-V stock is 400, Mallet is 500 (crank HP) with your S62 and lower c.r., and big boost, I would be surprised at anything under 600 at the wheels which is about 700 at the crank!!!!
