WOOWWW!: AC Schnitzer Z4 C30! - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > GTboard.com: Discuss other sportscars > GTBoard.com: General Sportscars
GTBoard.com: General Sportscars See the GTboard.com DVD. This form also contains a BMW X6 and X5 Forum.
Old 4th April 2003, 00:47   #1
enots
Garage: 2004 Mazda 3
Here we go:
Source: http://www.germancarfans.com/news.cf...403.001&Page=2
The latest member of the BMW family - the new Z4 roadster - has just been introduced to the world's public and at the same time AC Schnitzer presents its interpretation of this Roadster, excellent even in standard form, which already lays justified claim to being a classic of the future.
At the Geneva Motor Show 2003, AC Schnitzer presented a complete range of special accessories covering all areas of the vehicle and highlighting the authentic Roadster feeling. All components displayed are currently in the development or fine-tuning stage; they will however all be available during the Spring.
For the power plant of the most powerful variant at present - the BMW Z4 3.0i - a performance upgrade is already "in the pipeline". A development achieved in close collaboration with the BMW Motorsport Team Schnitzer, Freilassing.
The power of the AC Schnitzer Z4 C30 is increased by supercharger technology. The heart of the upgrade is a turbine supercharger which thanks its toothed belt drive allows almost noiseless running. Only in the upper speed ranges is the characteristic compressor note - totally desirably! - produced.
The geometric design of this supercharge means it only needs maximum 38.000 rpm to achieve a boost pressure of 0.35 bar at an engine speed of 6.500 rpm. This increases the output of the standard power plant to a stately 295 HP / 217 kW and brings the maximum torque up by 80 Nm.
Thanks to the excellent efficiency of the supercharger, there is no need for an extra charge cooler. The high-tech bearings are permanently lubricated via an autonomous, dedicated oil reservoir. This has the advantage of allowing the two oil circuits to work independently.
The scope of supply of the AC Schnitzer C30 performance upgrade also includes the full stainless steel AC Schnitzer sports rear silencer with chromed tailpipe trim in the new racing design and a modified control unit program. The performance upgrade is naturally also available for other vehicles with the M54 B30 engine.
Even without the engine tuning - for the BMW Z4 2.5 or 3.0i - we recommend fitting the AC Schnitzer sports rear silencer which optimises gas flow and hence response behaviour. As a "smaller alternative" the tailpipe trim in racing design completes the package.
Faster and more precise gear changes promote the adrenalin surge and improve the car's acceleration. So for the manual BMW Z4 3.0i we have adapted the AC Schnitzer Short Shift.
To ensure safe control over the driving power of the new BMW Z4 at all times, a special high performance brake kit for the front axle is in development. The internally vented and slotted brake discs measure 334 millimetres in diameter and are 32 millimetres thick. The special calipers are fitted with two 42 mm diameter pistons. Naturally the standard ABS system is retained in full.
Our engineers also invest great efforts and their entire know-how from motorsport in developing the sports-safe suspension setting. In extensive tests on race tracks and on public roads, a complete suspension concept has been developed which consists of the AC Schnitzer sports suspension, special anti-roll bar kit and the racing strut brace. The complete concept, the components of which can also be fitted individually, ensures sporting handling while retaining the high standard of driving comfort.
The suspension concept also includes the AC Schnitzer Type II and Type III alloys and racing rims in multipiece design. Specially selected for the Z4 roadster are various wheel and tyre combinations up to size 8.5J x 19" offset 43 with tyres 235/35 R 19 on the front axle and 9.0J x 19" offset 37 with tyres 265/30 R 19 on the rear. For tyres, we recommend high performance types from Continental and Michelin.
The high technical standards we set for our products are also evident from the bodystyling of the AC Schnitzer Z4 roadster. It was a particular challenge to pick up the styling of the Z4 roadster and continue its lines with subtle emphasis while retaining its discreet elegance.
The result is a made-to-measure outfit for the BMW Z4 roadster which fulfils all these attributes. The front part is enhanced by an exciting design of front spoiler attached to the standard front skirt. And it realises even more downforce on the front axle.
The smooth connection between the front and rear is created by the AC Schnitzer side skirts adapted to the contours of the Z4. The integrated cooling ducts also guide the airflow directly to the rear brakes. Particularly eye-catching are the side-mounted deflectors with integral flashers for the indicators, which with their chromed ribs give a totally new appearance. The two-piece rear wing, the triangular sections of which are mounted separately left and right on the boot, sets totally new accents. The overall appearance is rounded off by the new AC Schnitzer rear skirt, which not only harmoniously integrates the sports rear silencer into the rear end but at the same time gives the vehicle a far more powerful look.
Exclusivity is the watchword in the cockpit of the AC Schnitzer Z4 roadster: as well as a silver carbon-fibre interior, matching door sill trims and an ergonomically designed AC Schnitzer airbag sports steering wheel, the accents are set by the aluminium accessories. Choose from the pedal set with matching footrest, the handbrake handle and - for manual models - matching gear knob. For automatics we are currently developing a carbon-fibre selector. Last but not least, foot mats are available in high quality velours with the AC Schnitzer logo.
The AC Schnitzer Z4 is a thoroughbred roadster which combines all technical and aesthetic characteristics. On the track, cruising the country lanes or in the city - wherever you go, it's at home.
-Greg
2004 Mazda 3
[ View Me ]
enots is offline   Reply With Quote
Old 4th April 2003, 03:10   #2
MEnthusiast
Moderator Emeritus
MEnthusiast's Avatar
Garage: 03 M5
ewwww
All the best,
MEnthusiast is offline   Reply With Quote
Old 4th April 2003, 07:10   #3
dNA3D
dNA3D's Avatar
Garage: Too young to drive, dad owns a 740iL
Wayyyyyy overdone.
dNA3D is offline   Reply With Quote
Old 4th April 2003, 16:31   #4
Terk
Terk's Avatar
Garage: '07 997 Turbo
Yuck!
T.
Tony
07 997TT Basalt Black/Natural Grey
05 X5 4.8is LeMans Blue/Black Nappa
05 X5 4.4i Titanium Silver/Black
69 Firebird Carousel Red/Black
03 ///M5 LeMans Blue/LeMans Blue (sold )
Terk is offline   Reply With Quote
Old 4th April 2003, 17:54   #5
dNA3D
dNA3D's Avatar
Look at that rear wing... looks like its attached by Bluetack in the middle.
Old 4th April 2003, 18:48   #6
DF7
Garage: 1999 BMW 750il
**** that's a hot look for the Z4!
me likey!
DF7 is offline   Reply With Quote
Old 5th April 2003, 20:55   #7
tfung
Moderator Emeritus
tfung's Avatar
I think the Z4 with a lowered suspension looks great!
agree with the wing.. could have been better...
US Spec 2001 E39 M5 - LHD
AC Schnitzer
Dinan
3.45 differential
Others
Euro Spec 1999 E39 M5 - RHD
2007 Mercedes E63
2007 Corvette Z06
2008 Nissan GTR
2011 Ferrari 458
tfung is offline   Reply With Quote
Old 5th April 2003, 23:30   #8
TriflowM5+M3
 TriflowM5+M3's Avatar
Garage: 01 Lemans Blue M5
i dont know..it looks better modded than it does stock. I think that the body kit is nice, maybe a little to over done but the side markers are weird. They look like wings....
playtex with wings
 TriflowM5+M3 is offline   Reply With Quote
Old 6th April 2003, 21:47   #9
Reflex55
Reflex55's Avatar
Garage: 02' M5
Well, judging by other ACS designs, this one is quite mild. And it doesn't look too bad also.
.: '02 M5 Carbon/Silverstone :.
-Hamann HM450 Package
-Brembo 355mm Discs
-H&R Coils
-ACS SS
-OZ Superleggera 9x19/10x19.
and more to come.....
Reflex55 is offline   Reply With Quote
AC Schnitzer / DINAN M5 se Cars For Sale or Wanted 0 7th November 2002 19:45
BMW M5 AC Schnitzer Blue Angel Cars For Sale or Wanted 1 14th October 2002 14:29
BMWNA announces Z4 pricing... KRM GTBoard.com: General Sportscars 2 21st September 2002 20:07
Just ordered AC Schnitzer splitters Blue Angel E39 M5 and E52 Z8 Discussion 4 14th March 2002 01:35
BMW AC Schnitzer X5 C30 enots E39 M5 and E52 Z8 Discussion 2 10th October 2001 06:18
