Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > GTboard.com: Discuss other sportscars > GTBoard.com: General Sportscars
GTBoard.com: General Sportscars See the GTboard.com DVD. This form also contains a BMW X6 and X5 Forum.
Old 9th November 2009, 15:06   #1
Htp
Why engine of Supra so strong!
From the internet, there are many samples that 1000hp/800whp for 2.xL supra engine, why this engine so strong?
I know the hp come from the turbo with high pressure, but the engine strong enough for so high pressure.
What's the reason?
1. thick wall of cylinder?
2. better material of engine block?
Because even the iron block engine of bmw(for example, the M50), also can't charged too much pressure!
And for V8 M5, it is 5L engine, but even sleeved, it seem still not as strong as the supra! not see 1000hp M5, but with 2.xL supra, 1000hp seem not very difficult!
Htp is offline
Old 9th November 2009, 15:26   #2
rdm190
rdm190's Avatar
Garage: 2001 Carbon Black
What's the reason?
Most BMW engines were never designed to handle forced induction (until recently of course). Go on to a E36 M3 forum and look at the numbers some of the S52 guys make with turbos. Still not a Supra, but I have seen some very impressive cars. If i remember correctly there were some 700+hp cars out there.
You are comparing BMW engines, as a whole, to an engine that is world renowned to be a factory freak on boost. Engineers obviously waaaaaay over beefed the Supra motor from inception. I am sure it was never intended to handle 1000hp, but thats how the cards landed. Why do you think Supra's are so rare and command such a high price?
If you are buying a BMW for ease of modification with a high HP/$$ ratio, you need to seek life elsewhere. I know it is blunt, but it is the truth.
-Ryan
2001 M5 Carbon Black/Black Extended
Hella Euro Headlamps/Umnitza LED Angel Eyes/UF IATS/MVIV NAV Computer/20% Tint all around
2008 Ford Explorer Eddie Bauer 4x4. Takes the bad weather beating for the beast.
1995 Ford Mustang Cobra
2006 SeaDoo RXP
rdm190 is offline
Old 9th November 2009, 17:56   #3
ard
ard's Avatar
Indeed.
ard is offline
Old 9th November 2009, 18:15   #4
wilsodh
wilsodh's Avatar
HPF now offers a 'Stage IV' build of the S54 engine in the 1200 hp range..
We'll never see this with the thin-walled aluminum S62, but that cast iron S54 block can really take a pounding!
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
wilsodh is offline
Old 9th November 2009, 18:45   #5
herrubermensch
herrubermensch's Avatar
Garage: LeMans Blue 2001 BMW M5 with black and blue extended leather and brushed aluminum trim
Sales Feedback: (4)
Send a message via Yahoo to herrubermensch
Dave
Good God! That's crazy!
I really like the Stage 2.5 and Stage 3 kits for the E46 from HPF, especially with the body kit! My kind of aesthetics! I really think that's next after the Beast is done. Faster and cheaper than supercharging a Z8!
--Peter
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim, ESS Supercharger, RMS In-Plenum Intercooler, RMS Plenum Plates and Custom-Bored 52mm Diameter "Shorty" Velocity Stacks, Dinan TBs and Headers, CNS Catback Exhaust, Evosport High-Flow Cats, Stoptech Trophy Sport Brakes (6-Pot Front/4-Pot Rear; 355 mm Rotors All Around), Dinan 3.45 Differential, Dinan LTW Flywheel, GC Coilovers (550 7" Front/325 10" Rear), Dinan Front and Rear Swaybars, Dinan Monoballs, Dinan Rear Wheels (18 x 9.5) All Around With 10mm Spacers and 90mm Wheel Studs, Michelin PS2s 275 35 18s All Around, UUC EVO3 SSK with DSSR, Voltphreaks VPR-S40P Endurance Battery (14 lbs.), Setrab 16-Row Oil Cooler, Dinan Under-Plenum Heat Exchanger Removal Kit, Vorsteiner Double-Sided CF Hood with Open Vents, CA CSL-Style CF Trunk Lid, Zionsville Super Duty Cooling System, Aquamist HFS-6 Meth Injection with Custom CF/Aluminum Trunk-Mounted Fuel Cell Designed by Howerton Engineering, XRP HS-79 Hosing, OKD Plasma Ignition Coils and Plug Boots, Smoked Hella Tailights, Clear-Corner Hella Euro Headlights, CA ACS-Style CF Front Splitters, Custom Stereo Using Stock HU, PLX Digital Gauges, V1/S1 Mounted in UGDO Location, Recaro Sportster CS Seats, Schroth 4-Pt Street Harnesses, Dinan Foglight Delete Kit, and Various Other Bits and Pieces
Coming Soon!
Hankook R-S3 285 35 18s All Around, EAS Competition Steering Wheel, TC Designs Roll Bar, Leather Eurodash, Full Leather Doorcards, TC Designs Rear Sway Bar Brackets, Rogue Stage 3 280mm Clutch with JB Racing LTW Flywheel, Dinan Differential Subframe Reinforcement, Stoptech Carbon Ceramic Rotors, Quad Head Laser Interceptor, Kenne Bell Boost-A-Pump
When the Motor Blows
Balanced and Blueprinted S62
herrubermensch is offline
Old 9th November 2009, 18:57   #6
wilsodh
wilsodh's Avatar
--Peter
Agreed. The E46 looks every bit as well sculpted at the e39 to my eyes. The HPF M3's are a force to be dealt with. The upper stage engine builds have had some problems with smoking and oil consumption however. I think HPF got their arms around this problem, and offered to re-build their customer's engines with different machining, torque plates, smaller ring gaps etc. HPF has been impressive from a 'get it right' standpoint.
Dave
wilsodh is offline
Old 9th November 2009, 22:31   #7
rdm190
rdm190's Avatar
This is what we all get for buying a car with an eighth the aftermarket following as the M3.
Oh well, I still love my car. I loved my E36 M3 but they (E36/46) are a dime a dozen in some areas.
-Ryan
rdm190 is offline
Old 9th November 2009, 22:44   #8
MarinJim
Garage: E34 M5
The Swedes are turboing the S38B36 engine to way over 1,000 hp and take them to the drag strip all the time, weather permitting. They make 1,000 hp BMW's as easy as they make good meatballs.
MarinJim is offline
Old 9th November 2009, 22:56   #9
HarcoM5
Garage: 2001 BMW M5 Carbon Black
Amen.
I've seen 3 other m5s since i have bought mine, and 1 was at the dealer when i bought it.
An interesting fact, i did see a ///M540i at a local bmw/audi/porsche/mercedes dealer and a ///M318 on the road. the 2 nicest/most rare BMWs available.
HarcoM5 is offline
Old 9th November 2009, 23:18   #10
Doctor J
Doctor J's Avatar
Garage: 2001 BMW M5 LeMans Blue
The inline-6 engine configuration is inherently strong by design.
01' BMW E39 M5 - BBS CH 19s, Bilstein PSS9s and Dinan exhaust
00' Acura Integra Type R - uber modified track car
http://www.drsuzuki.com
Doctor J is offline
3.8 not as strong as 3.6? Mpowersurge E34 M5 Discussion 5 30th August 2007 23:44
Panke in Detroit: strong 2003 and strong demand for new 5-series Gustav E60 M5 and E61 M5 Touring Discussion 23 8th January 2004 05:17
New Dinan software = high idle & strong engine CM5GO E39 M5 and E52 Z8 Discussion 13 28th June 2002 15:03
Quite strong M5.... T5 E39 M5 and E52 Z8 Discussion 10 4th March 2002 17:15
Page generated in 0.16560 seconds with 11 queries
