Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > GTboard.com: Discuss other sportscars > GTBoard.com: General Sportscars
GTBoard.com: General Sportscars See the GTboard.com DVD. This form also contains a BMW X6 and X5 Forum.
Old 22nd May 2009, 18:44   #21
Myke951
Myke951's Avatar
Garage: 944 Turbo White
Send a message via AIM to Myke951
Originally Posted by G ///McGregor K View Post
A week from Sunday.
Awesome! let me know! Ill organize a meet for all of us here in socal!
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
Myke951 is offline
Old 22nd May 2009, 20:07   #22
m5baller
m5baller's Avatar
Garage: 2008 saphire black m5
Send a message via AIM to m5baller
Hey Graeme,
Your stealing my heart with this car. My first new car was a '77 Firebird. My father had a great '68. One of my favorite cars of all time is a '68 Camaro.
The Firebirds had a series, which included the Trans Am and the "Formula 400". The Formula was a sleeper. The motor had plenty of room to build. If you are restoring the car, keep the motor and build/bore it and try to bring it to stock looks. Include the GM rims and body molding.
Good luck!
P.S. Lets get together when you get into LA.
________________________
'08 M5, SMG - Black Sapphire / Black Merino
'07 X5 3.0si - Jet Black / Tobacco Napa Leather
'04 M3 Conv, SMG - Jet Black / Black Merino (Gone 9/11/07 )
'04 Mini 'S' - Dark Silver/White Top, (mucho mods)
'86 Porsche 951 -White (Son's money pit)
Past Rides (worth mentioning)
'98 M3 -Titanium Silver /Black Merino -Sold
m5baller is offline
Old 22nd August 2009, 01:06   #23
G ///McGregor K
G ///McGregor K's Avatar
Garage: '08 M5 Space Gray
A little update. Just got back into town about a week ago after spending the summer hanging out in CA with Baller and Myke. Got a few things done including putting in a new windshield, bolting in some racing seats and 4 point harnesses and I ordered a new motor. It should be in by next week sometime. I went with a 540 cubic inch Chevy big block with 677hp and 582tq, aluminum heads, full stainless roller rockers, forged crank. In case anyone is interested in the specs of the motor and its internals, here they are:
ffice:smarttags" name="place"> Machine Work
  • 502 4 BOLT BLOCK NEW GEN 6 WITH FUEL PUMP BOSS OIL COOLER PROVISIONS UPGRADE FROM 08 MODEL
  • align bore and or check for run out.full race clearancing
  • Bore Torque Plate Hone ... Torque Plate Gives True Finish
  • Dynamic balance assembly..
  • File fit rings - blue print clearance...
  • Install cam bearings - freeze plugs...
  • Port blue print cylinder heads...
  • Final assemble full rotating and top end
    • Parts including final torque - clearance - and geometry of all parts...
All new Performance Internal Parts
  • JE SRP FORGED pistons 10.7 to 1 piston set[ PUMP GAS OK]
  • Childs & Albert - zz gapdura Moly File Fit Rings... [provides the ultimate in ring sealing making more power!!
  • EAGLE STROKER STEEL CRANK...
  • EAGLE 4340 FORGED RODS LONGER .200 WITH FLOATED PINS AND ARP BOLTS
  • Clevite- -bearings tri metal 77 - rod and main...
  • custom hi output cam lifter set ..
  • Cloyes - true roller set...
  • Comp - cams cam locks...
  • FULL RACE xe chrome moly pushrods ULTRA ALLOY 080 WALLS NO FLEX UPGRADE FROM 08
  • Dyna gear race - oil pump...
  • Dyna gear - pickup...
  • ARP - steel drive...
  • After market - oil pan. baffeld 7 qt
  • After market - timing cover... NEW GEN 6 ALUMINUM POLISHED UPGRADE FROM 08
  • pioneer/arp - head bolts...
  • ARP/ - rocker studs 7/16... PRO SERIES UPGRADE FROM 08
  • Fel Pro RACE MARINE blue - gasket sets...
Power Making Featured Parts PRO ALUMINUM 325 RUNNER RECTANGLE PORT ALL NEW PORTED HUGE FLOW STAINLESS VALVES STAGE 1 PORT WORK MAJOR POWER GAINS 2.25 VALVE 1.90...WITH 540 CU IN
    • Features - - -severe duty STAINLESS 2.25/1.90 valves plus ... 1.55 springs 10 degree super locks comp cam parts..good porting..7/16studs guide plates.gasket match p.c seals.chrome moly retainers.. YOU NEED THIS SIZE VALVE TO MAKE THE POWER ALONG WITH THE CAM!!
  • hi perfromance STAINLESS FULL ROLLER rockers-1.7 ratio... UPGRADE 08 MODEL
  • custom series- -muscle car cam RADICAL IDLE.MAJOR LOW RPM TORQUE WITH EXTENDED RPM RANGE[1800 THRU 6000]
  • Features - 108 center line 618 - 618 lift corrected 1.7 ratio = . 246/246 dur @ 050 awesome power range 3000 stall. lopey muscle car idle. 100% streetable and will run vacum access VAC CAN SUGGESTED
The place I got it from had a bunch of inventory on hand so they needed to get rid of some stuff so I got a really good deal. It is going to come with a 950 dominator carb and it's turnkey, so I'll just drop it in. I'm going to pair it with a Turbo 400 tranny (which, from what I've heard were overbuilt in the first place and should be able to handle all the power fine).
I was thinking pretty hard about rebuilding the Pontiac 455 motor currently in it, but it just didn't make sense because of their propensity for catastrophic failure since they inherently weaker than their Chevy counterparts (454/502). It should be a fun motor to have in this car. I'll add some pics of it in the car when I get it in within the next 3 weeks or so.
2008 Space Gray/Black Full Merino Leather/Alum. trim
Loaded - every option (minus heated steering wheel)
Interior:Hardwired Valentine One with Concealed Display, Blinder Xtreme M25 (J16) Laser Jammer, Bimmian Interior Xenon Lighting Kit and ///M Racing Pedals
Exterior: Hartge Front Spoiler Lip, Hartge Rear Diffuser, Vorsteiner Vented and Domed Hood (Double-Sided CF), Hamann Roof Spoiler, H&R Springs and 15% Tint
"Performance": ASR Cold Air Intake, RPI GT Section 3 Muffler, Custom Fabbed Straight-Pipe Section I, Evosport Power Pulley and Hybrid Rear Badge
G ///McGregor K is offline
Old 3rd November 2009, 02:58   #24
G ///McGregor K
Update:
So I've got the car in the shop having the motor installed. Just waiting for the ceramic coated headers, subframe connectors and Flowmaster Mufflers to come in. I decided to pair the motor with a Turbo 400 with a 3000 stall. I expect the car to be driveable within the next 10 days and will post back once I get her back.
On a side note, I will be selling the old 455 motor paired to the Turbo 350 with a shift kit
Numbers of interest are as follows
Date Code: K092 = November 1972
Casting Number: 485428 = 1974 engine
I do have other information on the engine if anyone is interested PM me
Old 3rd November 2009, 03:24   #25
m5baller
m5baller's Avatar
Update:
A car like that can only be enjoyed in California!
I would be willing to drive it out here for you!
I also know someone who can detail it for you!
m5baller is offline
Old 3rd November 2009, 03:31   #26
Myke951
Myke951's Avatar
LMAO... DO IT! DO IT! I will meet you halfways... lets say... texas?
Myke951 is offline
Old 3rd November 2009, 03:59   #27
G ///McGregor K
Haha done deal only if I can get one of those "HOV Access OK" stickers like the Priuses, I should be on par with fuel efficiency!
Btw, think I may be coming back in 2 weeks for one more football game if y'all will be around.
Old 3rd November 2009, 05:00   #28
Tiptronicsoldier
Tiptronicsoldier's Avatar
Garage: 2K6 M6 Blk/Blk
Cool Project, I looked into getting a 68-72 Nova last summer for a while but decided to mod my M and save for an E36. I still want to build a Nova/Camaro with a BB and Turbo 400 at some point to cruise and work on.
"Men wanted for hazardous journey. Small wages. Bitter cold. Long months of winter. Constant danger. Safe return doubtful. Honour and recognition in case of success." - Ernest Shackleton, Ad in London newspaper 1913 for south pole expedition.
Tiptronicsoldier is offline
Old 3rd November 2009, 05:56   #29
bzabodyn
bzabodyn's Avatar
Garage: 2008 BMW M5 AW/SB/SG (shopping)
Very cool to see M5 guys appreciate the classics! That was actually the reason I got out of my last BMW (335i) - so I could buy a truck to haul around my project car, parts car, etc... 1969 Hemi Charger 4spd, track pack - red on black, black vinyl top, black R/T stripe - all matching numbers - originally sold in my hometown also and only one original owner previous to my with only 59k original miles... quite the gem!
A shot when it was first taken to start restoration and a pic of one about a month ago after all the metal work was finally complete...
2001 BMW M5 - TiAg/Black - Mods - SOLD!
2007 BMW 335i - Montego Blue/Tan - Procede/Wheels/Coilovers - SOLD!
**Looking for low mileage E60 M5 - caught the bug again!!!**
...formerly AMGKiller
bzabodyn is offline
Old 3rd November 2009, 11:34   #30
Myke951
Myke951's Avatar
Sooo.... i guess ill take that as a no... ... as far as being around in 2 weeks... we will be here!
Myke951 is offline
New project, M5 GTR 540is E39 M5 and E52 Z8 Discussion 168 30th September 2009 04:48
Project Calypso - E34 M5 3.6 Track Day Project FinalEditionE34M5 E34 M5 Discussion 80 23rd April 2009 04:27
new project ;) Payam972 E39 M5 and E52 Z8 Discussion 20 4th April 2009 09:31
E60 M5 S85 V10 CAD Project e31bimmerman E60 M5 and E61 M5 Touring Discussion 37 13th December 2006 04:45
project using the s62 Quadcammer E39 M5 and E52 Z8 Discussion 12 12th September 2004 22:20
Page generated in 0.12755 seconds with 12 queries
