Nice 'bird! Sounds like a fun project for sure. Something to think about, I have always thought it would be cool to have a newer motor in a car like this, something like an LS1 or LS2. There are kits out there to do the swap.
BTW, I have a '67 Firebird convertible that my dad and I fixed up a few years ago. It has a bored and stoked Pontiac 400 block now displacing 467 ci. We did coil overs all around, 4 link in the rear, new front control arms, rack and pinion conversion, disk brakes (from drums), Tremec 5 speed, sub frame connectors. Dropped it a little bit and added Torque Thrust originals and to me the look is perfect. Here's some pics:
///M5
Eisenmann Sport
A1 Performance headers
SuperSprint X-pipe
Rogue V12 conversion stg 2 clutch
Rogue lightweight flywheel
Rogue short shift
Dinan stage 3 suspension
Dinan software
9.5" wheels all around with 275/35 Direzza Star Spec's
Cosmo Racing CAI
Opened brake ducts
The Following User Says Thank You to firebird400 For This Useful Post:
A little update. Over the past few days I've worked on the car a little bit. So far I've yanked out the windshield -- going to have it replaced within the next week or so. And I've started fixing the broken "teeth" on the hood. 5 down, 2 more to go. Found some motors I'm looking at (about 480+hp and 500+tq) and I've decided to go with 3.73 gears. Probably going to do a 2500 stall converter. Just like anything, when I do my research, I keep finding more and more stuff I "have to have" for this car. Oh well, it is what it is and y'all know how it goes...
__________________ 2008 Space Gray/Black Full Merino Leather/Alum. trim Loaded - every option (minus heated steering wheel) Interior:Hardwired Valentine One with Concealed Display, Blinder Xtreme M25 (J16) Laser Jammer, Bimmian Interior Xenon Lighting Kit and ///M Racing Pedals Exterior: Hartge Front Spoiler Lip, Hartge Rear Diffuser, Vorsteiner Vented and Domed Hood (Double-Sided CF), Hamann Roof Spoiler, H&R Springs and 15% Tint "Performance": ASR Cold Air Intake, RPI GT Section 3 Muffler, Custom Fabbed Straight-Pipe Section I, Evosport Power Pulley and Hybrid Rear Badge
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
