Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > GTboard.com: Discuss other sportscars > GTBoard.com: General Sportscars
GTBoard.com: General Sportscars See the GTboard.com DVD. This form also contains a BMW X6 and X5 Forum.
Old 6th October 2008, 21:10   #21
GEORGEV6V24
Banned
Garage: SUZUKI VITARA V6
Well, both cars are fantastic, but when it comes to value for money, there is no dilemma.....
GEORGEV6V24 is offline
Old 6th October 2008, 22:03   #22
NobleM400
Company Representative of RPI Power
NobleM400's Avatar
Garage: 06 BMW M5 Silver Gray Metallic
Send a message via ICQ to NobleM400 Send a message via AIM to NobleM400 Send a message via Yahoo to NobleM400
Originally Posted by Tom C View Post
Forgive me for being a little skeptical of the GT-R's performance given the extremely divegent test data from Car & Driver mag.
Tom
You're talking about the one that got the batch of bad gasoline, correct?
Gabe
Race Precision, Inc
NobleM400 is offline
Old 6th October 2008, 22:25   #23
MortenDK
MortenDK's Avatar
Garage: BMW E60 M5 in Sepang Bronze
Originally Posted by NobleM400 View Post
The cornering G's are going to depend heavily on the tightness of the turn (tighter the turn, the higher G's the Nissan will be able to pull over the GT2), and the worse the surface (Nissan will have a comparative advantage as the surface conditions degrade). On a very fast corner that's tire limited, the GT2 should have the advantage, since it has bigger tires with respect to the weight, as well as DOT-R tires instead of DOT.
Where are the physics in that? That's not true. Only advantage the Nissan would have is accelerating out of the turn, not going around the turn. What could play a role is downforce though, but we're not talking formula 1 cars here, I doubt any of them generate anymore than 300-400 kgs @ 300 km/h.
But back to the accelerating out of the turn, I'd say the GT2 has a very nice set of tires and some insanely wide rear wheels. It shouldn't do that much wheel spin when doing 100+ km/h. So from the average nürburgring turn I doubt the GT-R is any faster.
2005 BMW M5, it's not on order, it's here!
Sepang Bronze/Sepang Leather/Aluminium - It's in the garage!! And not so much on the road, stupid clutch!!
To clear something up that has been bothering me; my name is Gustav (hello board leader ), my dad's name is Morten. I post 99% of all posts under the MortenDK account - so call me Gustav
MortenDK is offline
Old 6th October 2008, 22:57   #24
NobleM400
NobleM400's Avatar
Steady state cornering is a very small portion of the anatomy of most turns. IMHO, trail braking will be much easier in the GTR, and (as you said) acceleration out will be as well. The GT2 should have a higher steady state speed.
The smaller (lower speed) the corner, the greater percentage of time the braking and acceleration out will take relative to the steady state. The faster the corner, the greater percentage of the time you'll be doing steady state.
Cornering load (that G force measurement) does not break down the anatomy of a corner into its basic parts, it merely takes the corner as a whole.
This is why the GTR will show a higher G force on slower corners relative to the GT2.
The physics hold, as does the logic.
Gabe
Race Precision, Inc
The Following User Says Thank You to NobleM400 For This Useful Post:
7 speed SMG (7th October 2008)
Old 7th October 2008, 04:32   #25
shchow
shchow's Avatar
Garage: 2008 E60 M5 Metallic Sapphire Black
I don't think you can compare spec sheets and say which car is faster. There's obviously alot of variables that cannot be quantified on paper.
Take for example the C63 vs M3. Shouldn't the C63 be faster around a track when compared to the M3? But it has been repeatedly demonstrated that that is not the case.
Shouldn't the new CTS-V be alot faster than the M5 around the track, but Auberlein proved that was not the case.
For the doubters out there, next time when/if you pull up next to a GT-R, don't tell me your confidence isn't going to fade a little...
Shih-han
2008 M5-metallic sapphire black, SMG
2007 MB GL450-black
Prior Rides:
2004 645Ci-metallic sapphire black, sport pack., SMG
1997 Nissan Maxima-black
1989 Honda CRX-white
shchow is offline
Old 7th October 2008, 18:11   #26
MortenDK
MortenDK's Avatar
Ok, explanation is accepted for now . But what is trail braking?
MortenDK is offline
Old 7th October 2008, 20:48   #27
NobleM400
NobleM400's Avatar
Normally, the braking zone is considered to start at the point you need to stop accelerating and begin braking for a turn. The braking zone ends at the beginning of the turn, while you're still going straight.
With trail braking, the brakes are let up more progressively (instead of completely) as you enter the turn, which increases the load on your front tires. With more load on the front tires, initial turn in bite is increased.
Basically, it allows you to rotate the car better (and faster). Because you're loading the front tires, and unloading the rear, imperfect application will tend to unbalance the vehicle; it's a more difficult thing to do with rear heavy vehicles like the GT2.
Gabe
Race Precision, Inc
The Following 2 Users Say Thank You to NobleM400 For This Useful Post:
Daytona Bones (29th December 2008), shchow (8th October 2008)
Old 7th October 2008, 21:29   #28
Jad
Garage: M5 Interlagos Blue
Many, many and MANY assumptions have been made here, and all of u might be right. But in my opinion, Tom C's assumption could be true. "press cars" could be different than the showroom cars.
I highly respect Porsche as a company and they had never attempted to prove other companies wrong or provide false claims about their cars. Im also not trying to be biased, I could be wrong. What if Nissan tweaked their press cars to be better than the Porsche?
The problem with using the other tests of the GT-R is that each one was done with "press cars". I would think that the only way to verify the GT-R and for that matter 997TT and 997 GT2 claims is for someone to buy the cars off the showroom floor and hand the keys to the respective GT-R and Porsche (Walter Rohrl) test drivers.
Tom
Jad is offline
Old 8th October 2008, 18:57   #29
shchow
shchow's Avatar
Also, the level of confidence a driver has in his car will allow him to carry his speed deeper into the turn before applying the brakes and accelerate out of the turn sooner; in essence shortening the braking zone considerably.
All the reviews of the GT-R has the same theme, how well the chassis feels and the confidence it inspires in the driver on the track.
You can get a car with alot more horsepower (say the Corvette), but inspire little confidence by feeling skittish, and will adversely affect your time.
Shih-han
2007 MB GL450-black
Prior Rides:
shchow is offline
Old 8th October 2008, 19:36   #30
Ronin M5
Ronin M5's Avatar
Garage: 2001 BMW M5, Carbon Black Metallic
Nissan's response:
Nissan defends GT-R 'Ring time - Autoblog
I have no stake in this outcome either way.
2008 BMW X5, 4.8i Sport (Our Family Hauler)
2006 Ford GT, Heffner Pulley, Heffner Tune, Accufab Exhaust, Ford Racing SSK, Halon Fire Suppression, Crow 6 Point Harnesses, Setrab Transaxle Cooler
2006 Dinan Mini Cooper S, Dinan Valved Koni Shocks, Eibach Springs, Dinan 3 Piece Forged Wheels, Dinan 15% reduction Supercharger pulley Kit, Dinan CAI, Dinan Exhaust, Dinan Stage V Software, Alta Intercooler, LSD, Sport Package
2001 M5, Carbon Black Metallic, LOTS of mods, gone but fondly remembered
Dyno 395.5 rwhp
2004 BMW K12S, Nurburgring Test Ride Event, 1 of 4 USA Test Riders selected
BMWs Sold: 1987 535is, 1997 M3 Sedan, 2000 K1200RS, 2000 R1200C, 1997 328i Sedan, 2004 R1100S BMW Boxer Cup Replika #3/300, 01 M5
Ronin M5 is offline
Corvette C6 Z06 runs 7:43 at the Ring Zbad1 GTBoard.com: General Sportscars 31 3rd January 2006 01:00
Guess what guess what!!! + pic jajo E39 M5 and E52 Z8 Discussion 10 26th February 2004 08:15
i guess my car runs 12.60's. phillym5 E39 M5 and E52 Z8 Discussion 8 26th July 2003 20:04
Video: Porsche Carrera GT on the Ring! Gustav GTBoard.com: General Sportscars 0 30th December 2002 05:00
Who buys this Gustav GTBoard.com: General Sportscars 4 9th November 2002 12:06
Page generated in 0.17496 seconds with 11 queries
