Why n62b48 parts won't fit if crank, con rods are in use.
The rods are junk, the bolts come in from a angle.
The pistons are 1mm larger(93MM)
The main and rod bearings are much larger diameter.
The stroke of the crank is 88.3
You can bolt in everything from the S62 except the pistons, which you could get aftermarket cheaper then factory anyway.
You could also do slight machine work(machine rod journals to 1.890") to the crank and use longer rods and light weight pistons.
