"M-specific chassis, electronically controlled dampers, M Dynamic Mode": BMW Official Press Release - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > F10 M5 Discussion
F10 M5 Discussion 2010- Discussion about the next upcoming generation M5 based on the next generation 5-series, the F10.
Old 16th June 2011, 16:22   #1
Gustav
Administrator
Gustav's Avatar
Garage: BMW M3 DCT Sedan / Limousine
M-specific chassis, electronically controlled dampers, M Dynamic Mode. All High Resolution pics here: http://www.m5board.com/vbulletin/f10...tion-pics.html
The new BMW M5 comes with bespoke chassis technology whose construction and set-up are defined by extensive expertise from the race track. Specially developed axle kinematics and newly developed components boasting impressive strength and minimised weight meet both the requirements of everyday road driving and the specialised demands of track use. Chassis mountings using large panels at the front and rear axle ensures dynamic forces are passed evenly through to the body. The chassis transfers the potential wrapped up in the engine’s remarkable output onto the asphalt with assurance and a finely-honed sense of dynamic drama. All of which allows the BMW M5 to set new benchmarks in its segment not only in terms of sprinting power and elasticity, but also lateral acceleration, handling properties and braking performance. As with every BMW M car, the engineers carried out the fine-tuning that underpins the perfect M experience during extensive testing on the Nürburgring’s Nordschleife circuit.
The new BMW M5 is equipped as standard with electronically controlled dampers. Dynamic Damper Control uses electrohydraulic damping force adjustment to provide a set-up suited to the driving situation or the wishes of the driver. The damper settings can be adjusted at the touch of a button. In “Comfort” mode the dampers respond adaptively to the condition of the road surface and the driver’s style. “Sport” mode activates a noticeably stiffer damper set-up, while “Sport Plus” allows further stiffening of the suspension to achieve maximum longitudinal and lateral acceleration in ultra-dynamic driving situations.
At the touch of a button the driver can also select from three settings for the Servotronic speed-sensitive power steering system, which has been fitted in the M5 in an M-specific configuration. “Comfort” mode requires only a small amount of steering force when parking or manoeuvring, but still provides the brand’s hallmark direction-changing precision at higher speeds. “Sport” ensures the driver enjoys more intensive feedback across all speed ranges. This steps up another notch in “Sport Plus”. With this mode selected, the driver is called on to use greater force with the steering wheel.
In addition to applying brake impulses and reducing engine output to stabilise the car, the DSC system in the new BMW M5 also employs the services of the Anti-lock Braking System (ABS), Cornering Brake Control (CBC), Dynamic Brake Control (DBC), Brake Assistant, Fading Compensation, Brake Drying function and Start-Off Assistant. M Dynamic Mode (MDM) can be activated to override the basic setting by pressing the DSC button on the centre console. This mode generates the familiar M self-steering response by raising the intervention thresholds of DSC. “DSC Off” mode can also be activated at the touch of a button.
Google+ LinkedIn Facebook Flickr
My email gustav@gtboard.com m5board Member visiting Stockholm, Sweden? PM me to and I'll show you Stockholm! gtboard.com
Gustav is offline   Reply With Quote
BMW North America Press Release on the F10 BMW 5-series: The Perfect Symbiosis of Modern Design and Dynamic Performance. Gustav F10 M5 Discussion 4 26th January 2010 00:34
BMW M6 Convertible Press Release 2: Chassis and suspension (in English and German) Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 1 22nd June 2006 23:05
BMW M6 Press Release no 4: The Chassis and Suspension of the BMW M6:Agile, Fast, Safe Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 15th December 2004 00:21
Official UK Press Release for B7 fastsaloons ALPINABoard.com | BMW Alpina Discussion 6 28th June 2004 16:53
It's Official...BMW Press Release 4/16/03 Z8Bob E39 M5 and E52 Z8 Discussion 26 23rd April 2003 05:07
