Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > F10 M5 Discussion
F10 M5 Discussion 2010- Discussion about the next upcoming generation M5 based on the next generation 5-series, the F10.
Old 30th January 2009, 07:05   #1
Bimmerbear
Bimmerbear's Avatar
Garage: BMW M5 (LeMans Blue)
Brilliant (BMW's new twin turbo V8)
I just read this and thought everyone would be interested.
Turbo Placement on BMW V-8 May be New Design Trend
By Drew Winter - WardsAuto.com
Critics who think the V-8 engine is a bloated dinosaur headed for extinction should take a close look at BMW AG’s new twin-turbo 4.4L in the X6 and upcoming 750Li.
Efficient and capable of meeting Euro 5 and U.S. ultra-low emissions (ULEV) standards, experts say the new engine also is capable of producing far more than its current 400 hp without breaking a sweat.
Environmental Protection Agency fuel-economy numbers are not yet available for the 750Li, which is due in the U.S. in the spring, but it is safe to say it will not threaten the Toyota Prius’ lock on fuel-efficiency leadership. However, it is a plausible replacement for BMW’s much larger, and thirstier, V-10 and V-12 engines.
The new gasoline V-8 has been downsized from 4.8L and replaces the effective-but-cumbersome Valvetronic system with direct fuel injection and twin turbochargers. The new design makes 40 more horsepower and 90 more lb.-ft. (122 Nm) of torque than the previous engine.
Most significantly, the 4.4L is extremely compact and generates a prodigious 450 lb.-ft. (610 Nm) of torque across a broad power band from 1,750 to 4,500 rpm. It is all due to a new design that situates both turbos and catalytic converters in the “V” section of the block, rather than the outboard sides of the cylinder banks.
BMW says the configuration is a world first for an 8-cyl. gasoline engine.
“The design is indeed unique, with the main advantages being higher performance (especially torque for a gasoline engine) and lower fuel consumption,” says analyst Mike Omotoso, senior manager-Global Powertrain at J.D. Power & Associates, noting “600 Nm of torque at only 1,800 rpm is impressive. Those torque specs are what you would expect from a diesel.”
BMW says the torque peak is about the same as delivered by the auto maker’s 6.0L V-12.
For a Detroit comparison, Chrysler LLC’s naturally aspirated 5.7L Hemi produces 376 hp and 410 lb.-ft (556 Nm) of torque.
Of course it was not just a matter of moving turbos to and fro. The change also requires a new configuration of the intake and exhaust ducts, BMW says. This, in turn, demands the exhaust camshafts and valves be placed inboard, so the path for the exhaust gas from cylinders to turbochargers is shorter. The intake camshafts and valves then are positioned outboard.
Dean Tomazic, vice president-Engine Performance and Emissions Div. at FEV Inc., an independent engine and powertrain systems research and development company, says all this rearranging results in three major benefits: better packaging, improved cold-start emissions and the elimination of turbo lag.
Moving the turbos from outside the cylinder banks to the center of the engine shrinks the powerplant’s footprint and creates more room in the engine compartment for the steering column and other mechanisms that cause packaging headaches for vehicle designers, Tomazic says. It also eliminates the issue of installing bulky heat shielding on both sides of the engine to protect other components from the high temperatures the turbos generate.
Locating turbos and catalysts in the center of the engine also improves emissions, he says.
Turbochargers complicate cold-start emissions because they absorb exhaust gas heat and slow the time it takes catalytic converters to “light off” and reach optimum operating temperature. By placing the turbos and converters on top of the engine close to the combustion chamber exhaust ports, they heat up faster, providing cleaner emissions during startup.
The short path from exhaust port to turbine also minimizes heat losses and improves turbocharger efficiency.
The third benefit of a centralized turbo arrangement is what Tomazic calls “improved transient response,” otherwise known as reduced turbo lag.
“A more compact exhaust system means minimizing the volume between the pistons when they push out the exhaust and the (turbocharger) turbine. With this arrangement you can’t get smaller than that, therefore you have optimized transient response,” he says.
Auto makers have experimented with the concept for years, but until recently were fearful. “They were afraid of overheating turbochargers, overheating the entire engine compartment. We know of cases where the paint on the hood (of a test vehicle) peeled off.”
Now, the need to improve transient response and meet more stringent emissions standards is forcing auto makers to deal with the heat issues and move forward.
General Motors Corp.’s new 4.5L light-duty diesel, due soon, features a forced-induction system similar to BMW’s. Tomazic predicts more turbocharged gasoline and diesel V-8s will use the centralized layout in the future, as well as V-6s.
Meanwhile, J.D. Power’s Omotoso predicts the 4.4L will grow stronger. “There is speculation that the next M5 will use this engine instead of the current V-10, and an M5 with less than 500 hp is unlikely,” he says. “I suspect the current engine in the (BMW) 750 and the X6 has been de-tuned to sacrifice horsepower in favor of fuel economy. Fuel economy is not really a consideration in the M5 and M6, so look for 500-550 hp in the next year or two.”
Bimmerbear is offline
The Following 13 Users Say Thank You to Bimmerbear For This Useful Post:
/\/\5Power (30th January 2009), bbigman2000 (21st April 2009), Black M5 (30th January 2009), bodaddy (30th January 2009), jimmyz2 (30th January 2009), kglesq (2nd February 2009), LI-M5 (30th January 2009), M5Express (30th January 2009), Olaf (30th January 2009), RussRamz (30th January 2009), Rutkowsky (14th February 2009), V10 Wardrobe (30th January 2009), wilsodh (30th January 2009)
Old 30th January 2009, 15:23   #2
Tiptronicsoldier
Tiptronicsoldier's Avatar
Garage: 2K6 M6 Blk/Blk
It would be sweet if they could incorporate the same technology into the V10s
"Men wanted for hazardous journey. Small wages. Bitter cold. Long months of winter. Constant danger. Safe return doubtful. Honour and recognition in case of success." - Ernest Shackleton, Ad in London newspaper 1913 for south pole expedition.
Tiptronicsoldier is offline
Old 30th January 2009, 16:10   #3
Bucking
Garage: 2006 E60 M5;2007 BMW Z4M Coupe; 2002 Porsche 996 turbo; 1991 Porsche 964 turbo; and 2006 Mitsubishi Evo 9 MR
Frankly, this engine bothers me. Its service life is greatly compromised by placing turbos in the engine valley. Turbos produce hugh amounts of heat which significantly impact engine life. To place them in a very confined area as BMW has done with this engine along with the hot exhaust from the turbos exhausted back and down between the block and fire wall further complcates the problem. This engine is not a good performance design; it is a significant compromise to minimize engine bay space so. Granted these are water and oil cooled turbos but, having said that, heat is still a problem; complex cooling, intake and exhaust plumbing is a problem; increased service issues; less differentiation between M and non-M cars; and even lower residual value with more depreciation. I've owned a number of turbo cars, Porsche and Audi to name two. Don't get me wrong, they can produce huge power, but with lag. In the real world of high performance cars, nothing works like a fast and high RPM engine. For example, virtually every M engine we've come to love plus, GT3 Porsche and Ferrari F430. BMW will sell the turbo because we're suckers for horsepower and they can stuff it in more engine bays. We'll probably sing its praises but it IS a real step down, in my humble opinion.
Bucking is offline
The Following 6 Users Say Thank You to Bucking For This Useful Post:
Clyde (30th January 2009), Gustav (3rd February 2009), M5Ranger (1st February 2009), Murtaza (30th January 2009), wilsodh (30th January 2009), xraym5 (30th January 2009)
Old 30th January 2009, 18:12   #4
unfoundhorsepower
unfoundhorsepower's Avatar
Garage: 2006 M5-E60, Interlagos blue,all options + 2004 Z4 Red loaded,2004 M3 Luguna Seca Blue, 2009 X5 35d Saphire Black.
A good twin turbo V-8 would SMOKE a V-10....ya baby
See you all at the:
Mmmmm meet...in Massachusetts, It was good to see all of you !!
unfoundhorsepower is offline
The Following 4 Users Say Thank You to unfoundhorsepower For This Useful Post:
alpywhite (1st February 2009), drewzMMM (4th February 2009), Rutkowsky (14th February 2009)
Old 30th January 2009, 19:23   #5
hbpetrides
hbpetrides's Avatar
Garage: BMW M6, silver grey
Send a message via AIM to hbpetrides Send a message via Skype™ to hbpetrides
Totally agree with you, but I am a sacker for a high rpm scream!!!
musclecar
hbpetrides is offline
Old 30th January 2009, 19:31   #6
M V10
M V10's Avatar
Garage: M5 E60 Silverstone II
A good turbo V10 would smoke a V8 turbo Personally I prefer a NA V10 550-600 hp for the next M5!
M V10 is offline
Old 30th January 2009, 19:45   #7
kosmo
kosmo's Avatar
Garage: M5 2002, LeMans Blue
Wait a min. Porsches GT2's 3.6L 6 puts out 530hp & 505 torq. the Bimmer's engine is bigger but puts out LESS? Is it cuz Porsche has more experience w/ turbos than BMW? I dont get it. BTW the comparo vs the Chrysler v8 is soo silly.
2002 M5 Lemans Blue
2000 Ferrari 456M
1999 Lexus Rx 300
2005 Vento Phantom Scooter (70mpg )
kosmo is offline
Old 30th January 2009, 20:13   #8
Clyde
Clyde's Avatar
Garage: Sepang Bronze M6 Coupe
You have expressed many of my concerns about this new design.
I will wait for the second generation of V8 turbos, if there is one
Clyde is offline
Old 30th January 2009, 21:09   #9
carlsturm
Garage: 06M5.Silver-03M3.Red
(thx for the post).
I'm happy to see the BMW engineers and brainiacs looking at forced induction (and electric). Their engineering leadership will prompt innovative advances in this space.
More horsepower is a must have. But you can't just keep building bigger & bigger combustion motors.
06M5 Silver
carlsturm is offline
Old 30th January 2009, 22:17   #10
NobleM400
Company Representative of RPI Power
NobleM400's Avatar
Garage: 06 BMW M5 Silver Gray Metallic
Send a message via ICQ to NobleM400 Send a message via AIM to NobleM400 Send a message via Yahoo to NobleM400
Because BMW focused on getting more economy and cleaner emissions, whereas Porsche focused on more power. It was an issue of priorities, not experience, IMHO.
Gabe
Race Precision, Inc
NobleM400 is offline
The Following 3 Users Say Thank You to NobleM400 For This Useful Post:
Clyde (30th January 2009), kglesq (2nd February 2009), unfoundhorsepower (31st January 2009)
Page generated in 0.31156 seconds with 11 queries
