Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > Regional Forums and Events and group meetings for M5, M6 and Alpina owners > Local BMW M Forums > European Forum
European Forum For Europan BMW M and Alpina owners and enthusiasts of m5board.com and gtboard.com
Old 1st July 2009, 15:29   #1
Sulli
Sulli's Avatar
Garage: E39 M5 (02)
Fault Code Reading - Midlands?
I have the "Increased Emissions" warning light on my car, it came on yesterday, I left it overnight, but still on this morning, so possibly not caused by the heat.
Having searched the forum I am thinking it will most likely be an O2 sensor failure, but wanted to get it on a diagnostic first to be sure. I called a local M specialist and they charge £55 to read fault codes! A friend of mine has an independent garage with a general OBD reader, and he'll check for free if I know where the OBD plug is. Any ideas?
Also, what is the worst case scenario if I leave it?
E39 M5, 2002
Eisenmann Race System
Fully Decatted
Hamman Front Splitter
Hamman Fog Light Surrounds
Black Kidney grills
Black BMW badges front and rear
Red/Black leather interior
Brushed Titanium trim
Custom M-plates
BBS LMs
DSC: OFF
Sport: ON
Sulli is offline
Old 3rd July 2009, 01:08   #2
m5osc
m5osc's Avatar
Garage: E39 M5 Estorill Blue
Not being funny mate but if he doesn't know where the diagnostic socket is, what is he going to do with the info when he gets it?
I run a small Independant BMW garage & I charge £55 aswell, but the computer I use cost me 9k & is a dealer level tool, not some generic obd reader.
Reading the faults is not the be all & end all. It could be a faulty sensor that generates a fault in another one, or a wiring issue. It could be LOADS of different things. Leave it to the pro's mate. It's what they/we do best.
As for charging £55, it's less than a tank of fuel. How cheap do you want it??
A little knowledge is a dangerous thing mate. Guessing whats wrong with your car to save £55 is not the way forward.
Just my opinion mate...... good luck!
m5osc is offline
Old 3rd July 2009, 10:38   #3
m5osc
m5osc's Avatar
Whoops, forgot to add the connector is above the drivers right knee in RHD models & left knee in LHD.
m5osc is offline
Old 3rd July 2009, 23:31   #4
Sulli
Sulli's Avatar
Garage: E39 M5 (02)
He just asked if I knew where the OBD socket was before I came up to save time, and he said it was probably where you said it was. He's a mechanic at a garage that works on most cars, not specialising in BMWs, so doesn't see them everyday. He did however rebuild my 205 gti engine for me when I blew it up 10 yrs ago, and worked on virtually every other car I've had in past 10 yrs, Scooby, VR4, LCR, M3 etc, and never put a foot wrong, takes nearly as much care as I do, and more than most garages so I trust him
55 for a diagnostic isn't so bad, but I am guessing most places simply read the fault code, and 55 for that is a rip off.
By the way, where are you based, so I know for future reference?
Anyway, fault found: coolant thermostat. Took less than a minute. Fault code cleared and it hasn't come back, so I guess the unseasonable heat might have been somewhat to blame. Will keep an eye on it, and if it comes back I know what to replace first.
Cheers
E39 M5, 2002
Fully Decatted
Black Kidney grills
Custom M-plates
BBS LMs
DSC: OFF
Sport: ON
Sulli is offline
HTML code is Off
Trouble reading code vabchbmw E39 M5 and E52 Z8 Discussion 3 17th August 2007 23:57
Reading Fault Codes - B10 BT quattroboy ALPINABoard.com | BMW Alpina Discussion 1 3rd June 2007 23:04
Reading OBC Fault Codes baf3472 E39 M5 and E52 Z8 Discussion 1 3rd August 2005 19:25
Oxygen Sensor false Fault Code Reading tmlesko E39 M5 and E52 Z8 Discussion 0 12th July 2005 00:19
Reading fault codes with a PDA lasseoe E39 M5 and E52 Z8 Discussion 4 24th April 2003 18:43
Page generated in 0.10490 seconds with 11 queries
