Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe
Old 17th September 2007, 15:30   #121
RussRamz
Garage: BMW Z4M
Send a message via ICQ to RussRamz
Originally Posted by Frits View Post
@Russ: the toe on the rear wheels is 1°, with the wheels looking like this: \ / if the car would ride upwards on your screen. That would make sure the wheels are perfectly straight under acceleration. How would you do it? I'm still learning about camber/caster/toe, so all input is appreciated.
I've been thinking about a spoiler, and a have an OEM GT spoiler laying around somewhere. But I really like the look of the coupe without any spoilers, and I only want to put a spoiler on if I really really really need it.
I'm used to the current feel now, and have no issues with it. Maybe I'll change my mind later on.
If I understand your explanation, it seems you might be running toe-out on the rear wheels which will add some instability, but give you a sharper turn-in. It is my understanding that toe-out is more for the front wheels than the rear since the instability can be managed by attention at the steering wheel. This set-up makes your turn-in better, but doesn't allow for relaxed highway driving...
"Quitters never win, winners never quit. But those who never win and never quit are idiots."
2008 BMW Z4M Coupe
2007 BMW M6 Coupe--SOLD, but not forgotten!
2010 335d
RussRamz is offline
Old 17th September 2007, 15:37   #122
Frits
Frits's Avatar
Garage: E36 M3 alpine white E39 M5 avus blue E24 M635CSi royal blue
At the front wheels, I have a 0° toe setting... At the rear wheels, I have toe out indeed. 1° at each wheel.
Actually, the first time I had an alignment done, was before the first Ring trip. The high speed stability was OK then.
Then I installed the camber plates, and had them re-align the front wheels: just make sure the toe is 0° again at both front wheels. That's all they changed. The rear axle was untouched. And the next trip, I felt 'some' instability at high speed.
I want a setup that performs good on the track, and is OK on the highway. A perfect stable car at high speeds is a nice extra, but not required.
Frits is offline
Old 17th September 2007, 23:31   #123
///Mster
///Mster's Avatar
Garage: E34 3.8 M5
Thanks for the info!
Nope I haven't started a new thread on my project yet...and it looks like I may be doing part exchange deal on an already modified track M3. I wanted to start from scratch and do it exactly how I wanted, probably gradually over time but the car I'm interested in has pretty much exactly the modifications I would have eventually done anyway.
Anyway the deal is two weeks away, if it comes off I'll start a new thread on it.
As for toe-in at the rear, as RussRamz says toe-out at the rear makes the rear less laterally stable. A rough guide for rear toe is 0 or +1 degree and similar for the front. Toe-out on the front is better for turn in but not so stable in the straight line. Toe settings are pretty much a personal preference to be honest so there are no ideal settings.
You may want to play with adding more castor angle too as that translates to more dynamic camber, i.e. camber when you need it, in the corners.
///Mster is offline
Old 21st September 2007, 00:04   #124
Blue Thunder
Garage: 1999 M5 Avus Blue Metallic
Nice project Frits!!!
Congrats
1999 M5 Avus Blau Metallic
Twin Rotrex superchargers, Front mount intercooler, Steel sleeved block, Forged CP pistons, 10.5:1 compression, SS Headers, SS race cats, TUBI Rumore,
UUC 11" V12 cerametallic clutch + flywheel, UUC EVO3 SSK w/DSSR, Brembo GT4 brakes front/back, KWv3's, Angel Eyes + Angelibrights, Celis
19" Hamann PG2īs, Strongstrut front Strut Brace, BMW fire extinguisher, Phatbox MP3 player, CF interior trim, Voltphreaks battery
http://www.cardomain.com/ride/2417213/1
1989 E30 M3 White - track toy
S50B32 with a supercharger - 500+ hp, 1300kg rocket for the Ring
Blue Thunder is offline
Old 24th September 2007, 10:55   #125
Frits
Frits's Avatar
Yesterday I did the BMW M training on an airfield, with the E36. I took 2 extra wheels with Wanli tyres. For those that don't know Wanli tyres: PS2 is THE reference for a good street tyre. Wanli is THE reference for a poor street tyre. they have no grip at all.
Before the training started, I mounted these tyres on the rear axle.
In the morning, there were some exercises with changing lanes, changing lanes 2 times in a row, braking and changing lanes, etc. Compared to the other participants, my car was more unstable (tyres, tyres, tyres), so I had to adjust and correct more, and be more gentle with the steering.
In the afternoon, most exercises were cornering techniques. With my setup, this meant oversteering, and sliding! Great!!! Approach the corner, break, shift down, turn in, accelerate gradually, and start oversteering, and push push push!! Great! In the 90° turns, I could control the car most of the time (meaning, drift nice straight next to the outer line of cones, full throttle). In the 180° turns, I only managed to do a smooth run when I started drifting at the end of the turn. The instructor showed me a few times how to put it in drift at the beginning of the turn, and slide through it. I'm not up to that yet. I tryed quite some times, but never successful...
Oh, by the way, the rear tyres were almost new at the beginning of the day, and I won't pass the technical inspection with these anymore...
Frits is offline
Old 27th September 2007, 21:57   #126
MarkQC
MarkQC's Avatar
Garage: M5 E39 Carbon Black -silverstone/black interior
Kewl
Sounds like you had a blast...
When are you going to take her back to the ring?
...looking forward to a lap in the M3, and you're new techniques!
MarkQC is offline
Old 27th September 2007, 22:05   #127
Frits
Frits's Avatar
If the weather is OK, I'll be there on Sunday. You're welcome for a lap in the M3. There won't be any (planned) drifting though. I never intentionally drift, and the car has a power/grip ratio that is bad enough so there won't be too much oversteer when accelerating out of a corner.
Frits is offline
Old 28th September 2007, 12:45   #128
Fart
Fart's Avatar
Garage: E60M5 silber grau metallic
Send a message via MSN to Fart
Frits.. be there, even if there is some rain..
I will be going no matter what, and I will be going on my slicks even if its raining.
1995 E36 M3 GT #111
-370mm Carbon-Ceramic disks / 8 Piston Brembo calipers / Steel brake:lines
-H&R Clubsport Coilovers / H&R adjustable sway bars F/R / Intrax adjustable camber/caster plates / Powerflex bushes Front/Rear
-BBS 18x8.5 CUP 235F/265R
-Scorpion Exhaust / SuperSprint De-cat
-OEM Cabrio X-brace:Carbon fiber Porsche style seats:Momo Corsa weel:Heigo halfcage, Schroth 4points
-Forged pistonsa (CP) 8.5:1 / Forged conrods / coated bearings / ARP / Cometic MLS
-Twin Turbo Garrett GT2252 / Custom tubular manifolds (ceramic coated)
470hp/560nm at 12psi, now running 20psi
Pix
Fart is offline
Old 28th September 2007, 12:49   #129
PsynceFiction
Garage: E46 320i Steptronic
lol... slicks in the rain! You daredevill!
www.boelsphotography.be
PsynceFiction is offline
Old 28th September 2007, 13:59   #130
Fart
Fart's Avatar
Its just a question of controling the right foot.. not trying to beat any lap records. Ill go up there just to have some fun.
Fart is offline
Page generated in 0.21309 seconds with 11 queries
