Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe
Old 30th August 2007, 21:51   #101
MarkQC
MarkQC's Avatar
Garage: M5 E39 Carbon Black -silverstone/black interior
Frits - - - OH YEA...... looks awesome !
Best looking set of M stripes I've seen...
I'll check the calendar for the 5th & 9th...
MarkQC is offline
Old 1st September 2007, 00:23   #102
Frits
Frits's Avatar
Garage: E36 M3 alpine white E39 M5 carbon black E24 M635CSi royal blue
And today, I installed the adjustable camber plates. Fart's set is on the mail. He should have them by Tuesday or Wednesday.
I had to get 6 m8 bolts of 25mm to get them installed, they were not included...
Since the camber plates are lower than the OEM top mounts, the car is lower at front now. I will adjust that tomorrow. At the Ring, we'll need enough ground clearance...
I installed the first plate in a way that one adjustment only adapts camber, and the other adjustment only adapts caster. But I couldn't get enough negative camber. So I turned the plate 120°. Now both adjustments do a mix of camber and caster, but you can get a lot of negative camber.
Pictures tell more than a thousand words...
Frits is offline
Old 1st September 2007, 02:32   #103
PsynceFiction
Garage: E46 320i Steptronic
Looks totaly insane mate!! Can't wait to see it on the Nordschleife!
PsynceFiction is offline
Old 1st September 2007, 12:26   #104
Frits
Frits's Avatar
Some more pictures...
Frits is offline
Old 1st September 2007, 19:11   #105
RussRamz
Garage: BMW Z4M
Send a message via ICQ to RussRamz
Frits! Congratulations! Looks like you have a great car going there. I am really becoming tempted!
"Quitters never win, winners never quit. But those who never win and never quit are idiots."
2008 BMW Z4M Coupe
2007 BMW M6 Coupe--SOLD!
2004 VW Passat W8 4Motion
1993 BMW 318i
2010 335d--on order
RussRamz is offline
Old 1st September 2007, 21:28   #106
Frits
Frits's Avatar
Watch mobile.de, and see how cheap they are Russ
Frits is offline
Old 1st September 2007, 21:59   #107
Fart
Fart's Avatar
Garage: E60M5 silber grau metallic
Send a message via MSN to Fart
Originally Posted by Frits View Post
The stripes are on!! I really like the new look.
Y E S
1995 E36 M3 GT #111
-370mm Carbon-Ceramic disks / 8 Piston Brembo calipers / Steel brake:lines
-H&R Clubsport Coilovers / H&R adjustable sway bars F/R / Intrax adjustable camber/caster plates / Powerflex bushes Front/Rear
-BBS 18x8.5 CUP 235F/265R
-Scorpion Exhaust / SuperSprint De-cat
-OEM Cabrio X-brace:Carbon fiber Porsche style seats:Momo Corsa weel:Heigo halfcage, Schroth 4points
-Forged pistonsa (CP) 8.5:1 / Forged conrods / coated bearings / ARP / Cometic MLS
-Twin Turbo Garrett GT2252 / Custom tubular manifolds (ceramic coated)
470hp/560nm at 12psi, now running 20psi
Pix
Fart is offline
Old 7th September 2007, 11:17   #108
Frits
Frits's Avatar
I took a day off on Wednesday, and went to the Ring.
I took it easy for the first few laps, just to feel what the differences with the camber plates are. First thing I noticed, on the way to the Ring, was that the car feels a little less steady at high speeds. Anyway, nothing to worry about, but it felt more steady before the plates...
Then, in the first few laps, it felt like there was less grip on the rear wheels while turning (I think it only feels like that, just because there is more grip on the front wheels). I was afraid the car would oversteer every now and then. It didn't. In fact, it felt great!
I did experiment a bit to see if the understeering disappeared, like in Adenaur Forst. There is less understeer, but I can still get it to understeer if I want to. Anyway, I like it like this!
I managed to do 16 laps, and was extremely tired at the end of the day.
That's 36 laps in the Ringtoy so far, without any issue!!!
Attached is a picture I found on the net from Schwalbenschwanz.
Frits is offline
Old 7th September 2007, 12:25   #109
PsynceFiction
Great looking car and a fantastic driver!
Old 10th September 2007, 10:34   #110
Frits
Frits's Avatar
Had a rather good day again at the Ring yesterday. However, I did something stupid. At a moment, I thought the engine died... I could turn it on again, and drive calm to the Breidscheid exit, and then back to the entrance of the Nordschleife.
When investigating the problem, I noticed that the (don't know the word in English...) tool that looks like a cross, and is used to tighten the wheel nuts, was loose in the trunk. Every now and then, it made a short circuit on my battery
Now I attached that tool to the inner side of the spare wheel, issue solved...
46 laps and counting. Well, 46 and a half
Frits is offline
Page generated in 0.34138 seconds with 11 queries
