" For a small car producer I have a good wine celler, and to be just a simple wine seller I make pretty good cars "
Burkhard Bovensiepen
Only 96 MY E36 M3 EVOs have alum. doors as well as 95 MY US Spec M3 LTW.
As for chassis, suspension parts are different. Sorry, can't help; don't know the name of the specific parts.
__________________ ONUR '11 M3 Coupe M-DKG AlpineWhite(ON ORDER)
'09 Audi TTS Coupe ibisWhite (SOLD)
'07 911 Carrera S Coupe MeteorGrey (SOLD)
'05 M3 Coupe SMGII SilverGrey (SOLD)
'03 M3 Coupe SMGII BlueWater/Black (GONE)
'96 M3 Coupe 3.2 EVO Estoril/Grey (SOLD)
Evo is just the name the English put on the car to separate the 3.2 from the 3.0, but the term My I dont get.
Are you sure that the 96 had aluminium doors, and not the rest.
97-98 ...
Erik [/b]
Sorry not to make it more clear. By MY I meant Model year. Only 96 model year cars have alu. doors. I'm 100% sure that 98 and 99 model M3s don't have alum. doors.
Only thing I'm not sure about is maybe the cars made end of 96 have alum. doors; but came out from the factory as 97 model. Because I saw a 97 model M3 with alum. doors; and don't know if they were retro fitted.
Also for the suspension components:
M3 has different front lower control arms as well as different bushings. Also rear A-arm is different. There are several structural supports, too.
When you say structural changes, you mean in the body of the car right. Do you know where in the body ?
BTW:
I have changed suspension on both a E 36 M3 and same year 325 Coupe and noticed that the complete rear achsel was different and much more rigid on the M3 than on the 325.
Structural supports under the body; especially around the rear suspension components. Front should have more supports to. Even there is a difference in lower control arms between 3.0L and 3.2L M3s. (3.0L has more neutral setup where EVO has more understeer behaviour)
Whole rear suspension setup is different than other models. This is why 245/40/17 tires don't look the same on 320/328. Eventhough E36 M3 doesn't have flared arches, 245/40/17 tires fit but on 320/328 they rub, and look different
Originally posted by Erik
The weight of the doors should be app 9.4 kg.
Yeap I know; approx. 9-10 kg lighter on each side. Alum. doors have different hinges, too.
96 models don't have side airbags, and from 98 they become standart feature on M3s. So weight difference should be approx. 25 kg in total.
