18th July 2012, 01:28
#2
BMW
This can be accomplished fairly easily with coding.
It's called European Corner Delete.
On yours you only have the turnsignal on. On the E9x chassis there is the turn signal plus a seperate LED in the headlight housing and both can individually be turned on/off.
_________
Mike Benvo - BMW Coding / Programming Expert - E60 M5 Euro SMG Available
E60/E61 Coding List Available Here: http://www.bpmsport.com/Coding.pdf
Cars:
E90 M3 6MT - Akra Evo, Crank Pulley, Stage II BPMSport ECU Flash, BBS LM, LCI
E60 Silver Grey BMW M5 - Dinan Rear Section, Crank Pulley, Stage II Flash RIP
E60 2010 550i M-Sport Automagic - 100% bone stock other than window tint
1990 E32 735i -Low Comp M35B30 w/ GT35 Turbo, Air to Water intercooler @ 14 PSI
540HP 2003 BMW 330ci - Low comp, 15PSI ASA Supercharger, ~540WHP - RETIRED
mbenvo@gmail.com
