Building a 4.7L low compression, supercharged S65 stroker motor - Page 4 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe
Like Tree8Likes
Old 29th May 2012, 08:35   #31
Revo
Revo's Avatar
Garage: 2006 E60 M5 Black on Black
No one would sell you a few rods of it?
The M5 is my dad's - but I drive it more than he does!
Revo is online now   Reply With Quote
Old 15th June 2012, 06:18   #32
PencilGeek
Garage: Melbourne Red E92 M3
625 material fell through. We ended up going another route with 8740. Studs are now in progress. We have enough material for at least two sets of head studs...maybe three. Final specs will be about 220k PSI. 625 material would have been 260k PSI.
If you need a set, PM me.
PencilGeek is offline   Reply With Quote
Old 17th June 2012, 06:46   #33
Revo
Revo's Avatar
Is that the yield strength?
Old 17th June 2012, 16:20   #34
PencilGeek
ARP calls is "bolt strenth index" -- but I've also seen them call it "bolt tensile strength."
Old 21st June 2012, 02:55   #35
redefined
Garage: '93 332
wow awesome build!
redefined is offline   Reply With Quote
Old 21st June 2012, 07:22   #36
Revo
Revo's Avatar
Those are impressively high numbers then. Well beyond that of Titanium - about 30% higher, in fact. Is this hardened steel?
Old 22nd June 2012, 16:38   #37
PencilGeek
Here's what ARP says about 8740, 625, and Titanium:
8740 CHROME MOLY: Until the development of today’s modern alloys, chrome moly was popularly considered a high strength material. Now viewed as only moderate strength, 8740 chrome moly is seen as a good tough steel, with adequate fatigue properties for most racing applications, but only if the threads are rolled after heat-treatment, as is the standard ARP production practice. Typically, chrome moly is classified as a quench and temper steel, that can be heat-treated to deliver tensile strengths between 180,000 and 210,000 psi.
CUSTOM AGE 625 PLUS®: This newly formulated super-alloy demonstrates superior fatigue cycle life, tensile strength and toughness – with complete resistance to atmospheric corrosion and oxidation. ARP is the first to develop manufacturing and testing processes for fasteners with Custom Age 625+. Best of all it is less expensive and expected to soon replace MP-35 as the material of choice in the high strength, super-alloy field. Typical tensile strength is 260,000-280,000 psi.
TITANIUM: ARP now offers special order fasteners made of an alloy (Ti6Al-4V) that is specially heat-treated (a process developed by ARP's own Russ Sherman) and provides superior strength to other titanium alloys employed in racing and aerospace. The material has a nominal tensile strength of 180,000 psi, and is very corrosion resistant. The main advantage of titanium, of course, is its weight – which is about 40% lighter than a comparable fastener made of steel. Head studs and accessory bolts are ideal applications for this lightweight material.
Old 5th August 2012, 20:48   #38
M V10
M V10's Avatar
Garage: M5 E60 Silverstone II
Anything new?
M V10 is offline   Reply With Quote
Old 10th August 2012, 05:36   #39
PencilGeek
Originally Posted by M V10 View Post
Anything new?
Head studs are at the grinder right now getting threads put on.
Old 30th August 2012, 21:57   #40
PencilGeek
Head studs are done and stretch test was completed. Without stretch test, no way to know proper torque specs. Ready to assemble top end of motor.
Somebody told me yesterday that I was being asked on another forum why I didn't just buy head studs from his favorite company. Since I know he reads this thread, here's my simple answer:
  • They never sent me the specs they promised, and they couldn't tell me what material was used.
  • The initial quote was overpriced -- approximately 2x what ARP charges for 8740, and 1.2x what ARP charges for 625...and I still didn't know what material they used.
  • I didn't feel comfortable using this company because I'm not convinced they have enough technical expertise to design the studs themselves.
  • Based on above point, I don't know if they would have even known to run a stretch test before trying to use the studs.
E60 For Sale: FS: M5/M6 5.8L Dinan Stroker Motor and Mods darren_dallas Cars For Sale or Wanted 75 30th September 2011 18:10
5,8L stroker motor, rev limit daytonaM5 E60 M5 and E61 M5 Touring Discussion 2 19th April 2011 09:33
I need to be talked out of a stroker motor.. Streetking E60 M5 and E61 M5 Touring Discussion 75 25th July 2008 23:52
HP rating, low compression tropical versions? Donati E34 M5 Discussion 1 11th June 2006 19:45
3.6 LOW COMPRESSION ON 4&5 alpinaman E34 M5 Discussion 12 30th November 2004 16:46
