G-Power releases SKIII "Sporty Drive" BMW M3, over 700 HP - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe
Like Tree8Likes
LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 28th September 2011, 19:23   #1
Gustav
Administrator
Gustav's Avatar
Garage: BMW M3 DCT Sedan / Limousine
Wow MD A BMW M3 Sedan / Limousinde DCT DKG would be nice with SKIII
"After the 635hp-strong G-POWER M3 GTS caused a stir with the trade press and automobile enthusiasts, G-POWER unleashes another technical tour de force with its most recent creation – the G-POWER M3 TORNADO RS with SK III „Sporty Drive“ Supercharger System.
As demonstrated in G-POWER’s Supercharger Systems for the legendary BMW V10, the full potential of high-revving BMW engines and G-POWER superchargers can only be achieved through significant modification of the base engine. Fortunately, the V8 in the current BMW M3 (E9x) is essentially a „shortened“ version of the BMW V10 engine that G-POWER modified to create its world-record setting, 800hp G-POWER M5 HURRICANE RR. Thus G-POWER is able to leverage the proven forged pistons from that engine and developed through G-POWER’s technology partner MAHLE. These pistons are produced exclusively for G-POWER using a strengthening technology developed by MAHLE‘s Formula 1 division. The connecting rods also received a birth-by-fire in the engine bays of the countless G-POWER SK III Supercharger Systems delivered worldwide in BMW M5s and M6s.
However, the SK III „Sporty Drive“ Supercharger System for the M3 differs from the M5/M6 Supercharger System with an additional highlight in the engine bay. The follow-on system to that featured in the BMW M3 GTS includes a modified crankshaft. This new crankshaft increases the displacement of SK III-equipped M3s by 15%, from 4.0L to 4.6L.
The resulting modified V8 then meets the latest evolution of the world’s best-known components of G-POWER M3 „Sporty Drive“ Supercharger Systems. At its heart is the flagship of the ASA Centrifugal Supercharger product line – the powerful ASA T1-723. A maximum pressure of 0.5 bar can now be achieved and feeds air to the BMW V8’s individual throttle butterflies through the use of the optional carbon fiber airbox. Weighing in at just 4 kg, the G-POWER Carbon Fiber Airbox is nearly 8 kg lighter than the standard cast-aluminum variant. A tailor-made cooling system for the SK III Supercharger System increases the capacity of the oil and water cooling circuits of the V8 engine to keep temperatures in check.
A titanium exhaust system made specifically for G-POWER ensures that exhaust gases are discharged quickly and with minimum back pressure. This system features free-flowing 100 cpsi metallic catalytic converters.
When prepared with these options, the G-POWER M3 TORNADO RS produces a peak output of 720hp and 700Nm of torque. That is enough to catapult the G-POWER M3 TORNADO RS to 100 km/h in just 3.7 seconds. From a standstill to 200 km/h it takes just 9.5 seconds. Power and drag reach equilibrium at a maximum speed in excess of 330 km/h.
G-POWER continues the trend toward lightweight construction initiated by the BMW M3 GTS with its „RS“-labeled aerodynamics program. After all, weight reductions improve performance and ensure greater driving pleasure. This G-POWER "RS" aerodynamic program, made completely of carbon fiber, not only reduces the vehicle weight, but also increases the aerodynamic downforce. To be specific, it offers a carbon front spoiler for more downforce with optional brake cooling ducts for ventilation on the front axle, while a trunk lid, made entirely of carbon fiber and including a 3-piece carbon rear spoiler, increases the downforce on the rear axle.
The G-POWER "RS" aerodynamic program is manufactured from an ultra-light and extremely stable carbon fiber in a gas-tight autoclave. This production matches the OEM standards of the automotive industry and guarantees a perfect fit and a flawless surface structure.
The carbon fiber G-POWER VENTURI hood also contributes to reduced weight. The starting point for the development of the G-POWER VENTURI was the technical necessity to remove heat from the engine compartment of the uprated engines as quickly as possible. Otherwise a loss of performance can happen, since the ECU (electronic control unite) makes use of diagrams with reduced degrees of ignition when a fixed temperature limit is reached, in order to safeguard the engine.
The "DYNAMIC VENTING" Technology of the G-POWER VENTURI hood vents the engine compartment dynamically, allowing the otherwise untapped performance potential to be achieved with no additional thermal stress. Performance enhancement can not be supported more efficiently.
When it comes to suspension systems, the G-POWER M3 TORNADO RS is fitted with the G-POWER CLUBSPORT coil-over suspension and weight-optimized 20-inch G-POWER SILVERSTONE CLUBSPORT forged wheels. The tires are Michelin Super Sport tires in the dimension 255/30 ZR 20 on the front axle and 295/25 ZR 20 for the rear axle to keep the vehicle in contact with the road. Braking is done with the G-POWER-ceramic brakes on the front and rear axle, which provide low-weight and reliable high-performance braking. „Fade“ is therefore a foreign word for the 6-piston brake calipers in front which bite on 396 mm rotors and the 4-piston calipers at the rear axle which clamp on 380 mm rotors.
Naturally, all of G-POWER products showcased on the G-POWER M3 TORNADO RS are also sold separately."
Google+ LinkedIn Facebook Flickr
My email gustav@gtboard.com m5board Member visiting Stockholm, Sweden? PM me to and I'll show you Stockholm! gtboard.com
Gustav is offline   Reply With Quote
The Following 2 Users Say Thank You to Gustav For This Useful Post:
airgith76 (12th October 2011), herrubermensch (18th July 2012)
Old 28th September 2011, 19:44   #2
D-RodM5
D-RodM5's Avatar
Garage: 2001 M5 Carbonschwarz Metallic
Gustav, a video of this thing in action is needed!
/// M5
Umnitza VXX
BeastPower Brackets
Schmiedmann Blck Chrm Grills
AFE Power Air Filters
XPEL Protection Film
StopTech ST-40
SlimmBones Finned Diffuser
CarbFib ACS-style Front Splitters
TimmayTips
Mesh Fog Housings
Style 65 275/35/18 x 4
Evolve Alpha-N
D-RodM5 is online now   Reply With Quote
Old 28th September 2011, 20:25   #3
Gustav
Administrator
Gustav's Avatar
Maybe an upgrade from SKII to SKIII M3 Sedan
Old 29th September 2011, 14:25   #4
m630
m630's Avatar
Garage: '13 640i Gran Coupe
That was my first question, when are you upgrading!!!!!
'13 640i Gran Coupe ...Black Sapphire Metallic / Cinnamon ...Lux seats/CWP/Premium Sound
'13 335i M Sport...Destroyed by SANDY Estoril Blau II / black
Dearly departed: MY08 ///M6 Interlagos Blau/Silverstone II full merino/Carbon Fiber/SMGIII...fully loaded ...Dinan S1 remap
05 645Ci...Sport...Stratus Grey/Black
m630 is offline   Reply With Quote
Old 29th September 2011, 21:04   #5
m3smeden
m3smeden's Avatar
Garage: M5 E60 -05 Black
Now we are talking some real power. An upgrade is a must what is the cost of the package?
m3smeden is offline   Reply With Quote
Old 29th September 2011, 21:16   #6
Gustav
Administrator
Gustav's Avatar
Sadly it is for GTS engine. Quite expensive to buy a GTS engien for this
Old 29th September 2011, 21:57   #7
m630
m630's Avatar
Ahhhhh, now I see ! Well you need to do something I say so that you can whipp that S63Tu F10 when they come out
The Following User Says Thank You to m630 For This Useful Post:
Gustav (29th September 2011)
Old 29th September 2011, 22:03   #8
Gustav
Administrator
Gustav's Avatar
Yes! I hope I already whip it
Refreshed ECU, new belt, new sparkplugs, bypassvalves and new wastegate for some refreshed power
Old 3rd October 2011, 21:47   #9
m630
m630's Avatar
Nice!!! Somehow I think that will be the case! (just dont tell our friends over on the F10 thread, they are very sensitive to this subject!!!)
Old 3rd October 2011, 23:34   #10
Garage: E36 M3,E90 M3
That car looks sick !
Ess VT2 625
60-130MPH 7.5sec on stock internals
ESS VT3
img is offline   Reply With Quote
G-Power BMW M3 GTS SKII Club Sport Sporty Drive, X5 M Typhoon, M6 SKIII RR, G-Power BMW M3 CSL SKII and BMW M3 Sedan Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 3 18th April 2011 10:41
"Engine Malfunction: reduced power!" & "Increased Emissions" OTDoc E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 16 2nd November 2008 00:15
Anybody drive in "M" mode and with power button for daily? ThisFlyGuy E60 M5 and E61 M5 Touring Discussion 31 6th February 2008 05:47
