Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe
Old 14th December 2001, 02:56   #1
M PWR
M PWR's Avatar
Garage: E46 M3 Alpine White
Exclamation Don't try this at home!!!
To all of you who read the newest Car and Driver issue that talks about the cabrio E46 M3 don't do what I did!!! I switched off traction control activated sport mode 4500rpms dumped the clutch!!! The car car accelrated slowly but the rpm went in less that a sec to 8000, I shifted into second sofast and again the rpm was at 8000 but the car began moving fairly quickly. At that instant I didn't know what was going on!? Wheather I had a wheelspin all through 1st&2nd gear or the clutch was slipping??? Anyways I tried it twice. In notime my car was filled with burnt clutch smell My clutch when I press it made a small sqeaky sound and was softer than before now I was really I went back home and slept!!! The next day I started the car the clutch was not quite okay but much better than it was!! But I can smellthe burnt clutch in my till the next night!!! I think and yes I did burn 60% or more of my clutch on that stupid take off, and at that time I think my clutch was very hot and thats why it was softer when I pressed it. Guys, DON'T BELIVE WHAT YOU READ!!! belive me youdon't want to experiance what I did!!
M PWR
M PWR is offline
Old 14th December 2001, 23:47   #2
teezm3
teezm3's Avatar
Garage: 2001 E46 M3 IR/Blk
Very bad behaviour M PWR ... I didn't know it would burn so much of the clutch at 4500. Anyway most of the tests by the car magazines say 1200-2000 is a good lauch rpm range.
So are you getting your clutch replaced?
teezm3 is offline
Old 15th December 2001, 15:02   #3
M PWR
M PWR's Avatar
Well yeah 4500rpm launchs is alot of power for clutches to lock, but I thought I would give it a try since Car&Driver did. Didn't realize exactly what would happen but it happened I heard alot of M5 drivers complain about clutch slippage. I think that the stock clutch can't handle the power and torque that the car has, many are thinking of replacing it with after market heavy duty /racing clutches. I hope also thats not the case for M3s but never know so far I didn't need to. Well I have a appointment for replacing it late January.
M PWR
M PWR is offline
Old 15th December 2001, 15:07   #4
M PWR
M PWR's Avatar
Well yeah 4500rpm launchs is alot for the clutch to handle(lock). But Car&Driver did it thought I would give it a try not knowing exactly what will happen next. Alot of M5 drivers complain about clutch slippage. I think thats because the stock clutch can't handle the power and torqe the M5 has. Many are thinking of replacing it with aftermarket heavy duty/ racing clutches. I never saw anyone yet complain about E46M3 clutches but hope not the same case for us too. Well I have an appointment for late January.
M PWR
M PWR is offline
Old 15th December 2001, 18:13   #5
johann
Administrator
johann's Avatar
Garage: BMW E39 M5, Carbon black
Send a message via MSN to johann
Jetboy,
I do agree that the M5 clutch is not weak but I would say it's pretty sensitive and there is very little room for driver mistakes.
As for the E46 M3 the clutch seems to take a little abuse with a smile. But I guess letting it slip too much at 4500rpm is a little to much even for the M3 clutch. However there is no problem using 4500rpm and just sidestep the clutch at least not for the clutch. The tires will spin a lot and the drive train may wear out prematurely if you do that often
M PWR,
I guess that C&D were discussing launching at or close to max torque. Maybe you can do that once or twice but you really have to be fast with the clutch but still not to fast otherwise you'll end up with a burned clutch or a sever wheelspin. Is that what C&D were trying to accomplish?
I know the SMG II uses 3500 when you use the launch control and then regulate or more correct minimize wheel spin with the clutch. That is very effective but for a quick launch but very tough on your clutch. Therefore you can only use the launch control a specific number of times and the car will also prevent use of several "launch control launches" in a row before a certain cool down time have extended.
Cheers,
/Johan
johann is offline
Old 15th December 2001, 18:24   #6
JetBoy
JetBoy's Avatar
Garage: .
Send a message via MSN to JetBoy
Well, If you drive that way any clucth won't handle the power. You are going to burn it again and again....
I don't think the stock M5 clucth is weak, I know several good drivers who own M5s and never happened that to them !! Of course if you have been abusing the car, for example what you did or starting the car in 2 nd or changing the gears without pressing the clucth all the way or reving hard the car in cold etc etc sure you are going to burn the clucth. It is very easy to flame Bmw saying that their clucth is weak.
No offense intended. Just my opinion.
JetBoy is offline
Old 16th December 2001, 14:38   #7
M PWR
M PWR's Avatar
Johan,
hehehe , what the hell was C&D thinking of doing to our cars!!
Johan I did it twice, belive me I was so fast dumping the clutch. Belive me , I smoked a 00M5 that had Kelleners exhaust system, Dinan chip, UUC short shift and my M3 was bone stock. But I managed to be ahead of him by one car length until 4th gear 120mph after that the M5 was passing me with momentum
You can ask him too he is registered on the web (M5ER). Wow SMGII 3500rpm lock thats really phat!! But even at that range of RPM you get wheelspin, I belive a good launch is 1500-2000. What about you how do you launch your car?
M PWR
M PWR is offline
Old 16th December 2001, 16:23   #8
johann
Administrator
johann's Avatar
M PWR,
3500 will give you wheelspin but the SMG II uses the clutch to regulate wheelspin, i.e. slips the clutch.
I use low rpms 1000-1400, otherwise I get wheelspin unless the road is absolutely smooth. You can ask Gustav if it works.
Cheers,
/Johan
johann is offline
Old 16th December 2001, 16:32   #9
JohnH
JohnH's Avatar
Garage: 2004 Porsche 996 GT3 II Clubsport
I agree with Johan and tend to get the best starts 1000-1500 revs. Part of the problem is that the M3 revs so quickly that if you start off at too higher revs not only does it induce wheelspin but you hit the limiter in no time which then screws you completely. From 1000ish you seem to have far more control and time and without all the smoke and wheel spinning.
2006 750i Sport, Monaco Blue, Cream Beige Pearl leather
JohnH is offline
New home for the Beast M-Fünf E39 M5 and E52 Z8 Discussion 6 10th December 2003 14:14
My baby finds a new home today MarkM5Lauderdale Off Topic Forum 61 9th October 2002 04:53
Motor home towing...M5 chunpng E39 M5 and E52 Z8 Discussion 12 4th September 2002 17:30
(Way OT) Any Home Theater people out there? TonyS555 Off Topic Forum 14 17th July 2002 06:19
Page generated in 0.16966 seconds with 11 queries
