E36 M3 Track Car Build Log - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 74 Old 25th October 2007, 11:34 PM
J Irwan
J Irwan's Avatar
Originally Posted by Laidback View Post
G/L guys I will definitely be reading this thread
++1 bookmark it now.. and good luck..
Regardz,
J Irwan
02 Carbon Black ///M5
J Irwan is offline
post #12 of 74 Old 26th October 2007, 02:30 AM
jcrist
jcrist's Avatar
Attempted Kirk bar here at home instead of on the lift at the "Garaj Mahal". Not a good idea, the bolts are short, car is low, patience is thin, ARGHH. Did get the driver's seat in (so I could drive to the Garaj) so I will re apply myself on Sunday. How did you make out tonight R'man?
JCrist
97 M3/328 JP/GTS2 #360
01 Beast EveryBMW Silver
jcrist is offline
post #13 of 74 Old 26th October 2007, 05:31 AM Thread Starter
MRichmond
Moderator Emeritus
MRichmond's Avatar
Rear Suspension is In
The rear Ground Control sway bar, JRZ RS shocks, and rear springs are in (sway bar end links connection is pending corner balancing):
The fronts are waiting in the wings:
This weekend should see much activity.
2006 M5 Silver Gray/Silverstone/Madeira Walnut
Dinan Stage 2 Suspension System
Supersprint Race exhaust with X-pipe
1998 M3 Coupe Technoviolet #315 IP/GTS3
JRZ RS, Bimmerworld cage, Racetech halo seat, GC sway bars, control arms, AA headers and 3" race exhaust (loud and proud), etc., etc., etc. . . .
MRichmond is offline
post #14 of 74 Old 27th October 2007, 04:29 AM
905RMP32V1x
905RMP32V1x's Avatar
Originally Posted by MRichmond View Post
The Phase I plan is:
-- JRZ RS suspension (w/race plates, weight jackers, Eibach 700 F and 800 R springs)
-- Ground Control F and R sway bars
-- Ground Control adjustable rear lower control arms
-- F and R control arm bushings
-- Engine and transmission mounts
-- PWR radiator and Stewart water pump
-- Rogue short-shift kit
-- Kirk roll bar
-- Racetech 4000W seats
-- Teamtech 6-point harnesses
-- Kosei K1 wheels w/Toyp R888 235/40/17 rubber
-- AA Gen 3 exhaust
-- Various other upgrades, including stainless brake lines, brass brake caliper guides, new rotors, Hawk HT10 pads, Momo wheel, etc.
-- Also replacing some worn parts -- steering rack, front control arms, tie rods
The engine is the US 3.2L. Most likely, this winter I will do a cam/intake/headers upgrade. I am toying with the idea of doing a Euro 321-hp motor, but it appears that I can get nearly the same power with the former route. Flywheel/clutch also is on the horizon.
What do you estimate this project will cost you?
2006 Indy Red/Blk/Alum loaded,
H&R springs w spacers, 167(M6) wheels,
Dinan 3.91, Evo Pulley
CF grills, CF vents, ACS Spoiler
Vorsteiner CF Vented Hood, CF lower steering wheel
905R-driver
MP32-irons
ProV1x-ball
905RMP32V1x is offline
post #15 of 74 Old 27th October 2007, 04:51 AM
SeverelyOpinionated
Great choice!
Like I said before in your other thread.. you really don't need some 500+ hp car to be fast on the track. This car will really be quite fast.
How is the condition of the engine? I'd be worried about track duties without a rebuild.. but the engine could be in great condition.
Great suspension as well.. why not more aggressive tires? Also, how are you going to get this thing to the track?
Also, based on the parts you listed.. I'd recommend an engine oil cooler, transmission cooler, and a nice clutch-type limited slip. Once you are ready to go crazy.. start getting rid of those heavy steel panels and glass- although that'll require a full cage.
+1 on the someone else's comments about the rear subframe on the E36. Turner Motorsports has some solutions I believe.
"Fear is exciting for me." -Senna
12' 997.2 C2 GTS PDK
99' 996 MKI C2 6-Speed
12' E93 M3 DCT
07' E60 M5 SMGIII
04' E85 Z4
SeverelyOpinionated is offline
post #16 of 74 Old 27th October 2007, 04:55 AM
SeverelyOpinionated
Oh- and forgot.. a nice aggressive final drive gear should help as well.. Maybe not too aggressive for VIR.
I know it is your project- just some suggestions. Have fun!
12' E93 M3 DCT
07' E60 M5 SMGIII
04' E85 Z4
post #17 of 74 Old 27th October 2007, 05:10 AM Thread Starter
MRichmond
Moderator Emeritus
MRichmond's Avatar
I am keeping a detailed spreadsheet to track this, including even minor items. Including all the suspension pieces, seats, seat mounts, harnesses, roll bar, wheels, tires, AA exhaust, radiator, water pump, short shift kit, HANS, steering wheel, adapter and quick release, front strut brace, replacement steering rack, front control arms, and rotors, I am at around $14,000 in parts. Added to the $10,500 costs of the car, I will be a shade under $25,000 after this work is done, and before I get some money back by selling the parts I have removed.
post #18 of 74 Old 27th October 2007, 05:14 AM Thread Starter
MRichmond
Moderator Emeritus
MRichmond's Avatar
The engine appears to be in great shape -- the benefit of an apparently well-maintained one-owner car. But engine upgrade work is planned for this winter.
The R888 is the replacement for the RA-1, one of the better R-compound track tires. The RA-1 has a great reputation for grip and durability. It is a great track tire by any estimation, and I hope the R888 is at least as good. I may move on to the BFG R1 later, but I suspect the R888 will be plenty of tire for me as I learn the car. Until I get a trailer and tow rig (perhaps some time in '08), I will be driving it the 2 hours to the track.
post #19 of 74 Old 28th October 2007, 12:41 AM
jcrist
jcrist's Avatar
The RA-1's, R888 will migrate nicely into the rain tire as we get another set of wheels and BFG r-1's!
JCrist
jcrist is offline
post #20 of 74 Old 28th October 2007, 12:44 AM
jcrist
jcrist's Avatar
Just got home from the Chili Cook Off, I assume I have lost at least 6 work hours to you, I will be goign hard tomorrow finishing roll-bar, seats, and then maybe move into the radiator and cooling.
JCrist
jcrist is offline
The RUF experience, with a side order of M5 (very large and loads of pics :)) Adam E39 M5 and E52 Z8 Discussion 92 22nd August 2011 09:15 PM
24 hours and six fueltanks with the new BMW M3 V8! [Now with 10 minute video] Gustav E34 M5 Discussion 13 24th October 2007 06:34 PM
BMW M3 - english pressrelease (with lots of pictures) kees E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 43 18th May 2007 03:09 PM
New M3 Official greggb E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 140 17th March 2007 01:12 AM
My visit to the Old Timer Grand Prix on the 10th of August raymondw Most Memorable Threads' 2 26th August 2003 01:05 AM
