20,000 V10 engines already built by BMW Motorsport (now with english text) - BMW M5 Forum and M6 Forums
Old 13th November 2006, 14:13   #1
kees
Administrator
Garage: magic moderator wand
Pressrelease from BMW AG today (both in english and german now)
Originally Posted by bmw.com
STRONG PERFORMANCE FROM A POWERFUL ENGINE: BMW M has built 20,000 of its V10 engine
11/13/2006
"Engine of the Year" from the BMW M5 and M6 is much in demand.
Munich. It has been on the market for just two years and its output of 500 bhp (SAE rating) already ensures outstanding performance figures for 20,000 BMW M5 and M6. A few days ago, the 20,000th specimen of the high-performance engine was produced on the so-called Special Engine Line at the BMW plant in Munich. Since the start of serial production in 2005, the V10 has won the internationally renowned "International Engine of the Year" twice and also has 5 category wins in the 'International Engine of the Year' awards.
The engine boasts extraordinary qualities and specifications: after all, it was based on the 10-cylinder BMW Formula 1 engine which was the most powerful engine in the top discipline of motor racing until the rules were changed in 2006.
But the V10 of the BMW M5 and M6 not only has the same number of cylinders as the racing engine, it also shares the same high-speed concept. This principle, only mastered by a few automobile manufacturers, generates enormous thrust from high engine speeds and is characteristic of all high-performance naturally aspirated engines made by BMW M GmbH.
The technical specifications of this extraordinary engine: ten cylinders, a capacity of five litres, an output of 373 kilowatts or 507 bhp, a maximum torque of 520 Newton-metres and a maximum engine speed of 8250 rpm. Impressive on paper, these figures really come alive in practice: the engine accelerates the various BMW M models M5, M6 and M6 Convertible to 100 km/h in under 5 seconds.
For BMW M, the high-speed concept - more power from higher engine speeds - has traditionally been the preferred strategy. However, the V10 engine moves into an engine speed range which was previously regarded as out of the reach of serial production engines due to the enormous stress to the materials.
At 8,000 crankshaft rotations per minute, each of the ten pistons travels around 20 metres per second - almost as much as the pistons in a Formula 1 engine. But while long-term resilience is a relative factor in motor racing, an M engine has to last for the whole lifetime of the automobile - in every climate, in every road situation and with all driving styles.
The technical highlights of this engine, now celebrating an impressive landmark in its production lifetime, include a torsionally stiff bedplate construction, weight-optimised full slipper pistons, single-section cylinder heads made of aluminium and the so-called cross-flow cooling concept which ensures an even temperature throughout the cylinder head. This V10 M engine also has the variable camshaft control system double VANOS, port throttles as in motor racing and a system which - like a dry sump - always ensures a permanent oil supply to the engine even at high levels of transverse acceleration.
Finally, the engine management system for the V10 high-performance engine was developed by BMW M's own engineers - an area in which BMW M occupies a leading position. The system's modern 32-bit processors can process over 200 million individual operations per second: for each separate cylinder and firing cycle they calculate ignition timing, charge, injection quantity and timing.
Photos of the BMW V10 engine are available at www.press.bmwgroup.com
Originally Posted by bmw.de
Starke Leistung für ein starkes Triebwerk: BMW M hat schon 20.000 V10-Motoren gebaut
13.11.2006
München. Seit knapp zwei Jahren ist er auf dem Markt, jetzt treiben seine 507 PS Leistung weltweit bereits 20.000 BMW M5 und M6 zu überragenden Fahrleistungen an. Vor wenigen Tagen wurde im BMW Werk München am so genannten Sondermotoren-Band das 20.000ste Exemplar jenes High-Performance-Motors produziert. Seit dem Start der Serienproduktion in 2005 wurde dieses V10-Aggregat zudem mit bereits sieben Preisen des weltweit renommierten "Engine-of-the-Year-Award" ausgezeichnet.
Tatsächlich kann dieses Triebwerk mit herausragenden Eigenschaften und Werten glänzen: Schließlich stand für diese faszinierende Maschine der Zehnzylinder-Formel-1-Motor von BMW Pate, der bis zum Reglementswechsel 2006 als stärkstes Aggregat in der Königsklasse des Motorsports galt.
Mit diesem Rennsportmotor hat der V10 aus BMW M5 und M6 aber nicht nur die Zylinderzahl, sondern auch das Hochdrehzahlkonzept gemeinsam. Dieses Prinzip, das nur wenige Automobil-Hersteller beherrschen, generiert enorme Schubkraft aus hohen Drehzahlen und ist charakteristisch für alle Hochleistungs-Saugmotoren der BMW M GmbH.
Die Daten dieses außergewöhnlichen Motors: zehn Zylinder, fünf Liter Hubraum, 373 Kilowatt oder 507 PS Leistung, ein maximales Drehmoment von 520 Newtonmetern und eine maximale Drehzahl von 8250/min. Was bereits auf dem Papier beeindruckt, sorgt erst recht in der Fahrpraxis für Begeisterung - in deutlich unter fünf Sekunden beschleunigt dieses Triebwerk die verschiedenen BMW M Modelle M5, M6 und M6 Cabrio auf Tempo 100.
Für BMW M ist das Hochdrehzahlkonzept - mehr Leistung durch höhere Drehzahlen - schon traditionell die bevorzugte Strategie. Dabei stößt der V10-Motor in eine Drehzahlregion vor, die wegen der enormen Materialbelastung zuvor für Serienmotoren als unerreichbar galt.
Immerhin legt bei 8.000 Kurbelwellenumdrehungen in der Minute jeder der zehn Kolben etwa 20 Meter Weg in der Sekunde zurück - fast so viel wie die Kolben eines Formel-1-Motors. Doch während im Motorsport dauerhafte Belastbarkeit eine relative Größe ist, hält ein M Motor ein ganzes Autoleben lang - bei jedem Klima, in jeder Verkehrssituation und bei jeder Fahrweise.
Zu den technischen Besonderheiten dieses Motors, der ein beeindruckendes Jubiläum feiert, gehören unter anderem eine verwindungssteife Bedplate-Konstruktion, gewichtsoptimierte Kastenkolben, einteilige Zylinderköpfe aus Aluminium sowie das so genannte Querstromkühlungskonzept, das eine gleichmäßige Temperaturverteilung im Zylinderkopf garantiert. Zudem besitzt dieser V10-M Motor die variable Nockenwellensteuerung Doppel-VANOS, Einzeldrosselklappen wie im Rennsport sowie ein System, das wie ein Trockensumpf die permanente Ölversorgung im Motor selbst bei hohen Querbeschleunigungswerten unter allen Umständen sicherstellt.
Letztlich, darin ist BMW M führend, wurde für den V10-Hochleistungsmotor von den Ingenieuren dieser Gesellschaft auch die Motorsteuerung selbst entwickelt, deren moderne 32-Bit-Prozessoren mehr als 200 Millionen Einzeloperationen pro Sekunde verarbeiten können. Zylinderindividuell und für jeden Arbeitstakt errechnen sie Zündzeitpunkt, Füllung, Einspritzmenge und -zeitpunkt.
Fotos zum BMW V10-Motor finden Sie unter www.press.bmwgroup.com
kees is offline   Reply With Quote
Old 13th November 2006, 15:09   #2
holmesmd
holmesmd's Avatar
Garage: 540i 00', M5 03',06' E63 M6, 08' E90 M3
hmmmmm???
Not sure how to respond as I do not read German. What implications does this have? They must be planning to use this engine in a different production line I can't believe that they would dilute the exclusivity of the M5/M6 by producing that many cars. What do you think?
holmesmd is offline   Reply With Quote
Old 13th November 2006, 15:20   #3
Habib_2
Habib_2's Avatar
Garage: Prius
English translation (well sort of):
Habib_2 is offline   Reply With Quote
Old 13th November 2006, 16:02   #4
Terk
Terk's Avatar
Garage: '07 997 Turbo
That's a lot of horses.
Tony
07 997TT Basalt Black/Natural Grey
05 X5 4.8is LeMans Blue/Black Nappa
05 X5 4.4i Titanium Silver/Black
69 Firebird Carousel Red/Black
03 ///M5 LeMans Blue/LeMans Blue (sold )
Terk is offline   Reply With Quote
Old 13th November 2006, 16:43   #5
holmesmd
holmesmd's Avatar
Originally Posted by Habib_2
Thanks Habib, I know you meant well but the paragraph I just read made no sense to me. The phrase"lost in translation" comes to mind.
Old 13th November 2006, 19:47   #6
Gustav
Administrator
Gustav's Avatar
Garage: BMW M3 DCT Sedan / Limousine
Impressive that so many have been sold so far! Outselling the M Power V8 as of today!
Google+ LinkedIn Facebook Flickr
My email gustav@gtboard.com m5board Member visiting Stockholm, Sweden? PM me to and I'll show you Stockholm! gtboard.com
Gustav is offline   Reply With Quote
Old 14th November 2006, 08:18   #7
Chet814
Chet814's Avatar
Garage: Black Sapphire E63 M6/Blk Interior/Carbon Fiber, HD/Sat Radio, HUD
Originally Posted by holmesmd
...I still don't understand the significance.
I guess this is just a PR thing released from BMW on how cool the V10 engine is--which I agree--and the 20,000 unit production is supposedly some sort of cool milestone. This would just keep people talking about it--and drum up more sales as a result.
C
Chet814 is offline   Reply With Quote
Old 14th November 2006, 14:22   #8
kees
Administrator
Added english version of same pressrelease
Old 14th November 2006, 14:23   #9
kees
Administrator
The 20.000 units is significant because BMW only sold around 20.000 E39 M5...the E60 M5 & E63 M6 has now already outsold that.
Old 15th November 2006, 14:49   #10
Mr. BMW
Mr. BMW's Avatar
Garage: 2008 Alpine White M5, M3 and Sapphire Black 750Li
Something New About Your V10
BMW V10 Marks 20,000 Milestone [Sold]
Check it out.
http://www.worldcarfans.com/rsslink.....000-milestone
2008 Alpine White, Portland Brown M5 (SMG)
2008 Alpine White, Fox Red M3 (6MT)
2008 Sapphire Black, Black 750Li
Mr. BMW is offline   Reply With Quote
BMW speech at Geneva MotorShow alsahher E60 M5 and E61 M5 Touring Discussion 0 3rd March 2005 13:53
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav Most Memorable Threads' 43 1st November 2004 19:16
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav E39 M5 and E52 Z8 Discussion 11 30th October 2004 14:36
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 21:23
The Press Releases: no 1 BMW M5: MUSCLES FROM MUNICH Gustav E60 M5 and E61 M5 Touring Discussion 12 1st July 2004 14:54
