Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E63 BMW M6 Forum and BMW M6 Convertible | m6board.com
Old 7th June 2006, 03:09   #1
mkerouac
mkerouac's Avatar
Garage: M6 w/Black Int
H&R Springs Install Report
Just had the H&R Springs for the M6 installed. Some Good news and bad news.
The good news. The car looks great. Front dropped 1" and the back about 3/4". It actually looks much lower than that. The front air dams will easily scrape a speed bump.
The bad news. The ride is much harsher than I expected. I hit a small dip in the road and I literally was lifted out of the seat. The car also seems to transmit every little bump in the road, even on the highway. Tracks well on sweepers, but I don't think the loss of daily ride quality is worth the looks.
I'm going to give it a bit of time, but I think I'll eventually pull them off. At this point I would not recommend them.
Hopefully H&R can come out with a new revision with a little more forgiveness. .
mkerouac is offline
Old 7th June 2006, 03:53   #2
Jamie140
Jamie140's Avatar
Garage: '03 360 spider, '06 M5
That's too bad. The M6 is way too high and really does need to be dropped.
'08 997TT Cab.
'04 Carrera GT
Jamie140 is offline
Old 7th June 2006, 04:04   #3
MaxTimeOff
MaxTimeOff's Avatar
Garage: M6, X5, Boxster S
Mkerouac,
When I saw your post I couldn't click on it quick enough. So sorry to hear about your results and I must say I am surprised. Your post was the first that I have read that said lowering had a significant impact on ride quality. I agree that the car will look a lot better lowered, but at what cost?
I had a Porsche with sports suspension (option 030 I believe) and it seemed stiff but very usable for daily driver. Do you have any experience with factory sports suspensions on other cars for comparison?
Ha...Ha you drive a Bimmer, said the Ferrari driver! Yes, but my car is faster, more comfortable, has a superior motor, and, it sounds really awesome. But, that F-car is pure sex and the chicks really dig 'em....said the M/// driver!
MaxTimeOff is offline
Old 7th June 2006, 04:59   #4
Wolverine
Wolverine's Avatar
Garage: BMW E60 M5 Silverstone II/Silverstone/Aluminum
That's a shame. The springs on the M5 have a small effect on ride, but nothing drastic. As someone previously said, 'comfort' mode becomes halfway between 'comfort' and 'normal', and the same with the other modes. I wonder why the springs have such an effect on the M6? Are they the same springs as for the M5?
2006 E60 M5 Silverstone II/Silverstone/Aluminum, All Options, 35% tint, Aluminum Pedals, Valentine V1 and Passport 9500i Hardwired, Blinder Xtreme M40, Michelin PS2's on 20 inch BBS RS-GT's, Winter Pirelli Sottozeros on OEM 19 inch wheels, Resonator Delete, Charcoal Filters Removed, Eibach Springs and Spacers, Active Autowerks ECU, BMC Filters, RPI Air Intakes, Evosport Pulley. Retired from track duty 10/08. Dinan diff replaced with OEM at my cost due to failure at 56,000 miles.
Wolverine is offline
Old 7th June 2006, 05:04   #5
mkerouac
mkerouac's Avatar
I had a 2004 Corvette Z06 and now I also have a 2006 Corvette C6 Coupe. The C6 in sport mode gives a stiff ride but it soaks up moderate bumps. I've never been lifted out of the seat by a bump in the road. The Z06 had heavy duty sway bars and a track tuned suspension, even it may have been slightly more forgiving than these springs. Either way, I would expect more from this setup. The M6 is still in comfort mode with the H&R's, I haven't even tried sport mode yet. I think the biggest disappointment was the highway. I don't think I can accurately describe the feeling. If you hit some wavy surfaces, the car feels like it's riding on top of the bumps and moving around a bit. Hard to explain. I don't think there is any real loss of control, just a sensation. The car simply wasn't absorbing the road irregularities. I could feel every little bump. My client advisor is an ex BMW racer. He test drove the car first. He actually called me the day before pick up to give me a heads up. He doesn't like the feel either. At this point I would suggest saving the $1,000 until more options are available.
mkerouac is offline
Old 7th June 2006, 05:30   #6
MaxTimeOff
MaxTimeOff's Avatar
I have purchased Euro or RoW factory springs in the past and have considered doing this for my M6. Maybe now I will more seriously consider this.
Up until your post I was going to put on H&R's or ACS springs (Eibachs I think, ACS switches OEM's every now and then). To clarify, I'm talking about getting the Euro BMW part numbers for the springs on Euro spec M6's, order from say a German dealership, and install them on my U.S. spec M6.
I think this would give a much better look without sacrificing ride quality at all. My feeling with this is the car would be set up as the factory intended, and would look much better.
It worked on my Porsche, will it work on the M6? Can't imagine why it wouldn't. Anyone care to comment?
Finally, and most importantly, could someone please provide me with the Euro M6 spring part numbers (front and rear).
Old 7th June 2006, 06:12   #7
PPG4
PPG4's Avatar
Garage: 2006 M5 Silverstone
Real OEM lists the front spring as part number 31332283075. There are two part numbers listed for the rear; 33532283076 and
33532283077 for "Vehicles with HiFi Professional DSP"
Unfortunately, they don't have US spec part numbers for the M6 up yet, so there's no way to know if there is a difference.
PPG4 is offline
Old 7th June 2006, 06:24   #8
Wayward
Wayward's Avatar
Garage: 2006 M6 - SB/Black
Argh. Am in California again tonight fellas, and won't be posting at length, but thanks mkerouac, MTO, and PPG4, I also would not have expected this.
mkerouac, I empathize here, being a guinea pig is not fun...we're learning though, .
Wayward is offline
Old 7th June 2006, 06:34   #9
EM5PWR
EM5PWR's Avatar
Garage: 02 M5
thats what happens when you only lower it half way , you need the proper length shocks now...
EM5PWR is offline
Old 7th June 2006, 06:40   #10
MPULSV6
MPULSV6's Avatar
Garage: Audi RS6
Gosh, that really blows. I was going to take the plunge and order the Springs tomorrow before I took off to London. I was looking at my car today and was thinking what it would look like with 21's without being lowered so I had decided to get springs.
After reading this, I will take your advice and just wait for better alternatives as I don't want to sacrifice ride quality for better looks at this point since the M6 is stiffer than the M5 in Sport setting, but seemed softer in Comfort setting (strange).
I'm learning more and more about the car. I initially was going to get an exhaust system but opted not to since the car sounded pretty good. It is noticeably louder than the M5 with a much deeper growl while the M5 seems to have a more of a "whine" to it.
I guess I may just go with 20s and not even bother lowering it, but will Chip it and remove the charcoal filters.
Thanks for the write up.
MPULSV6 is offline
'00-'02 M5 Sirius Install Tips ///M_Addict E39 M5 and E52 Z8 Discussion 4 5th May 2009 02:54
New HR springs install....do I adjust SLS? Jahangeer E34 M5 Discussion 13 16th June 2005 13:58
H&R springs racer_xbr E34 M5 Discussion 4 3rd May 2002 00:26
h&r springs racer_xbr Owners Gallery 0 1st May 2002 02:09
Page generated in 0.24557 seconds with 12 queries
