Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E63 BMW M6 Forum and BMW M6 Convertible | m6board.com
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 14th December 2004, 13:53   #1
kees
Administrator
Garage: magic moderator wand
Full set of official BMW M6 pictures & press release
m6board.com Interview with BMW M Manager Ulrich Bruhnke
High res pics in the bottom of this press release
Links to the official Press Releases:
BMW M6 Press Release no 1: World Debut of the new BMW M6 (short version)
Press Release no 2: The new V10 Power Unit in the BMW M6: A Masterpiece in Engine...
Press Release no 3: The Seven-Speed SMG Gearbox
BMW M6 Press Release no 4: The Chassis and Suspension of the BMW M6:Agile, Fast, Safe
BMW M6 Press Release no 5: Body, Design, Equipment: Light and Safe, Sporting and...
Short summary:
The rebirth of an icon
The announcement of a new M car remains a rare and exciting occasion, and the launch of the new M6 in 2005 will reveal a potent new combination of BMW engineering and M power.
Hot on the heels of the new M5, and taking lightweight design solutions from the M3 CSL, the new M6 combines supercar presence with Grand Touring potential. Joining an exclusive club, the fourth new M car of the decade sets a new performance benchmark for a production car. The beauty of the M6 is also its ability to comfortably crush kilometres on a cross-country cruise.
The BMW M6 is the new standard-bearer for BMW’s M car range, as well as the return of a much loved and highly regarded BMW badge. The latest M car features:
* 5.0-litre V10 engine producing 507bhp
* Seven-speed SMG (personally programmable)
* Lightweight body panels including carbon fibre roof
* 0 – 62mph in 4.6 seconds / 62 – 0 in 36 metres
* 155mph limited top speed
* MDrive Manager control settings
Like its predecessor - the legendary 1985 M635CSi – the new M6 resets the sports GT benchmark, with supercar performance, dispatching the zero to 62mph sprint in 4.6 seconds and achieving a limited top speed of 155mph. If derestricted, the M6 would be capable of a 200mph+ top speed. During tests at the famous Nürburgring Nordschleife circuit, the new M6 regularly clocked
eight minutes lap times. These rarefied performance statistics are, however, backed up by ‘real world’ economy and efficiency - the new M6 delivers a combined EU fuel consumption of 19.0mpg and a CO2 rating of 357g/km.
Powered by the same 4,999cc engine that set new standards in the M5, the 507bhp power output ensures that the new M6 maintains the M car tradition of breaking the 100bhp per litre benchmark. Peak power is developed at 7,750rpm with the red line set at 8,250rpm. Peak torque of 520Nm is developed at 6,100rpm of which 450Nm is available from just 3,500rpm. The 90-degree V10 aluminium-silicon alloy engine block is extremely light yet robust and is the first V-arrangement engine to use a bedplate construction. The aluminium bedplate with cast-iron inlays ensures the engine’s rigidity throughout the rev range, but the complete unit still weighs just 240kg.
The capable chassis of the new M6 permits lateral acceleration in excess of 1g. To cope with such forces, the V10 engine features a lateral force-controlled oil supply that, from 0.6g of lateral movement, activates one of two electronic oil pumps to draw oil from the cylinder head and delivers it back into the sump to ensure perfect lubrication even in the most extreme situations. It is because of the extreme forces that can be induced by the M6 that the car also makes use of a semi dry sump lubrication system with an oil reservoir on each side of the front subframe.
Masterminding all the M6’s engine electronics is one of the most advanced engine control systems ever developed. The MS S65 control unit coordinates all engine functions using three 32-bit processors that handle more than 200 million operations per second from over 50 incoming signals. Each of the 10 cylinders has its own throttle butterfly, with its position being monitored 200 times per second. Reacting to changes in throttle position, the butterfly can move from closed to fully open in a mere 120 milliseconds (approximately three times faster than the blink of an eye).
Like the M5, the new M6 also uses BMW’s new third-generation seven speed Sequential Manual Gearbox (SMG) with Drivelogic. Drivelogic offers the choice of 11 different change patterns, depending on the speed of change required. Six change patterns are available in the manual mode and five in the ‘automatic’ mode, in which the gearbox will automatically select the most appropriate gear depending on driving conditions.
The new SMG gearbox also offers safety benefits when downshifting on slippery surfaces. If it detects the rear wheels locking up, the clutch opens for a fraction of a second to ensure traction is maintained. Hill Detection is another SMG feature. In automatic mode, the SMG gearbox recognises that the car is travelling on an incline and holds gears uphill to maintain acceleration and selects lower gears when progressing downhill to make the most of the available engine braking.
The suspension of the new M6 is based on the ‘standard’ 645Ci geometry. With the exception of components such as tie bars, wheel mounts and bearings, the double-arm spring strut front axle is made completely of aluminium. The U-shaped front subframe houses the rack and pinion steering assembly, anti-roll bar and track control arms.
The Integral IV rear axle assembly is also made from aluminium to reduce unsprung masses. In addition, the new M6 features BMW’s variable, speed-sensing M Differential Lock. Featured on all current BMW M models, the M Differential Lock builds up locking action whenever one of the rear wheels begins to spin, channelling drive to the wheel with the most grip to improve handling and stability.
Electronic Damper Control is also standard on the M6. Offering the driver three suspension settings – Comfort, Normal and Sport, drivers can select the most appropriate setting for their driving style or road conditions. The new BMW M6 also features a BMW M version of Servotronic steering with two specific settings corresponding to the Electronic Damper Control settings, Sport or Comfort.
BMW’s DSC stability control system has been adapted for the M6. Featuring M Dynamic Mode (first seen on the new M5), drivers can take their cars to the limit of the laws of physics, allowing considerable angles of controllable oversteer when circumstances allow.
The new BMW M6 comes with a Power button (pioneered in the M5) in the centre console. Initially the car pre-selects the P400 setting, delivering 400bhp for town or city driving, for example. Engaging the Power button modifies the response of the throttle and enables the P500 setting to deliver the full 507bhp generated by the V10 engine.
Control of all of these features has been brought together using the M6’s MDrive Manager. MDrive allows the driver to pre-select specific settings for the Power button, SMG gearbox, DSC, EDC and Head-up Display. With one push of the steering wheel-mounted button, the driver selects his or her chosen character. For example, the car can be set up for an exciting 30 mile A-road drive to and from work or, on the other hand, for a city commute. More extreme settings can be pre-programmed for track use.
For a car with such potential, high performance brakes are needed and the new BMW M6 doesn’t disappoint. Using aluminium double piston callipers and cross-drilled disc brakes, the car can stop from 62mph in just 36 metres and from 124mph (200km/h) in only 140 metres – equivalent to 1.3g deceleration.
Specially developed tyres ensure that the prodigious horsepower and braking power are transferred to the road. Measuring 255/40ZR19 on the front and 285/35ZR19 on the rear, the tyres are mounted on lightweight five-spoke 19-inch forged aluminium wheels, each weighing 1.8kg less than a normal cast alloy wheel.
Like other 6 Series models, the new BMW M6 uses a hybrid construction of aluminium, thermoplastics and SMC (Sheet Moulding Compound). This mixture of materials delivers an extremely rigid, yet light, body structure. The front wings are made of thermoplastics, the doors and bonnet of aluminium and the boot lid, SMC. Like the legendary M3 CSL, but unlike the 630i and 645Ci, the new BMW M6 also uses carbon fibre in the construction of the roof panel to reduce the weight yet further – this feature alone saves nearly 5kg and contributes towards the overall weight of just 1710kg.
Visually, the new M6 differentiates itself from the 6 Series by a deeper front valance with air intakes for the engine and brakes, more contoured sills and rear valance that includes a diffuser to increase aerodynamic efficiency. Nestling under the rear valance are BMW M’s telltale four rear exhaust pipes. To complement the changes in body styling, the new M6 is available in four exclusive M colours – Indianapolis Red, Sepang Bronze, Interlagos Blue and Silverstone alongside three other 6 Series colours.
Inside, the new M6 comes with fully adjustable M sports seats that include lumbar support and an adjustable backrest width as standard. They are covered in extended Merino leather, with the owner able to choose between Black, Silverstone or Sepang. As an option, full Merino leather can be specified in Indianapolis Red and Portland Natural Brown alongside the other three colours that includes a leather covered dashboard and Alcantara headlining.
The new BMW M6 also features BMW M’s version of the new Head-up Display system. Unlike the standard Head-up Display available on 5 and 6 Series models that offers navigation instructions and cruise control information, the system on the M6 projects driver-focussed information such as engine speed, gear selected and road speed directly into the driver’s view, obviating the need for the driver to take his or her eyes off the road ahead.
The new M6 will go on sale towards the end of 2005. Dates and prices will be announced in due course.
Sources: BMW AG
Very high-res pics on the following 14 links:
1 2 3 4 5 6 7 8 9 10 11 12 13 14
Additional low-res pictures in this post.
kees is offline
Old 14th December 2004, 21:10   #2
Opposite_Lock
Opposite_Lock's Avatar
Garage: E39 M5, Carbon Black
Send a message via MSN to Opposite_Lock
Re: Full set of official BMW M6 pictures & pressrelease
Thanks for the update.
Those rims are hideous! They look almost ricey.
And that interior is pretty ghastly, too, with that dark wood. Really clashes with the soft silver SMG surround.
The rear bumper also looks too busy.
That red wouldn't be my first choice, either.
I think the transformation of the E60 into an M turned out much better.
Sam
'03 Carbon Black M5
'04 Sterling Grey X5 4.4 Sport
Opposite_Lock is offline
Old 14th December 2004, 22:13   #3
Lupo///M5
Lupo///M5's Avatar
Garage: 2003 Dinan S2 M5/Carbon Black
I like the wheels, kinda Foose looking. No big deal, easily changed.
I like the interior, but agree that SMG plastic cover is horrible. Not only in this car, but also in the E60 M5.
I find the rear very aggressive, and rather clean. The "hidden" taillights are a plus in my book.
Color is definitely a personal choice. For me Black is the color I love BMW in.
My opinion on the "transformation", the E63 M6 makes the E60 M5 look like a soccer mom's car.
'03 Dinan S2 M5 Carbon Black/Black/Birch Blue Trim
AA CAI, StopTech BBK, Eisenmann Race Exhaust, Rogue Octane SSK&WSR, Euro Dash, Rear console Cooler, BlueTooth.
Lupo///M5 is offline
Old 15th December 2004, 00:06   #4
M6 Forever
Garage: E63 M6 coupe
I'm not so sure about the new 5 spoke wheels. I think I'll get the 10 spoke M5 wheels. They look great. That's the only thing that bothers me. Otherwise, the car looks stunning. They've kept the 645Ci side gill metal, which means no standard M gills; interesting. Carbon fibre roof is interesting too. I've always guessed the M6 will look better than the M5, and I'm right!
Geneva March 2005 should be the presentation in complete form.
M6 Forever is offline
Old 15th December 2004, 02:10   #5
Opposite_Lock
I get that the wheels can be easily changed, but for me, pretty much every single M-Car in history has had gorgeous rims that I wouldn't touch. IMO, this M6 is the first exception. They should've just put the E60 M5 rims on.
Sam
'03 Carbon Black M5
Old 15th December 2004, 02:23   #6
Wake Champ
Wake Champ's Avatar
Garage: M6
Those wheels look terrible. As for the rest...it seems fine.
Wake Champ is offline
Old 15th December 2004, 02:45   #7
M6 Forever
The new 5 spoke wheels seem deliberately designed as such with weight savings in mind.
"With their five contoured double-spokes, these wheels not only look delicate, but are 1.8 kilos lighter than conventional cast aluminium wheels".
Nice try, but I'll be using the M5 wheels.
Old 15th December 2004, 16:19   #8
Adam
Adam's Avatar
Garage: R32
Send a message via ICQ to Adam
Not bad, not bad at all!
all the best
adam
1995 Alpina B8 4.6 #10-(engine blew up. sold)
2001 BMW ///M5(sold)
2003 RUF R turbo
1990 RUF CTR
2006 VW Golf R32 DSG
2005 e60 M5 (sold)
2007 997 GT3 RS Carrara White
2008 Renault Clio 197
"You know it is kinda ironic, these old people are being kept alive by the organs of the young people they ran over" - Chief Clancy Wiggum
Adam is offline
Old 15th December 2004, 20:24   #9
beckhammania23
beckhammania23's Avatar
Garage: What do you think :P
That's great Gustav
Thanks for sharing
Beckhammania23
www.automanias.nl
beckhammania23 is offline
Old 15th December 2004, 23:54   #10
foxyboym5
foxyboym5's Avatar
Garage: BMW E30 M3 1987 & 996 TT 2002
Send a message via MSN to foxyboym5
let us reminisce.....
Full set of official BMW M6 pictures & pressrelease & Bruhne Interview-01.jpg
Full set of official BMW M6 pictures & pressrelease & Bruhne Interview-m635csi.bmp
2002 BLACK 996 TURBO
TRACK TOY/PROJECT 1987 E30 M3 Black. Roll cage, Leda/Koni adjustables, Koni springs, camber plates, sparco seats & full race harnesses, Splitsec MAF kit, EVO2 engine, Schrick Cams, 245bhp.
PREVIOUS CARS:
1989 BMW M5 E34
2000 BMW M5 E39
1998 BMW 323Ci
1990 BMW 325i
1981 BMW 635CSi
1995 BMW M3
1995 BMW 328i
1990 BMW 525i
1988 BMW 316
foxyboym5 is offline
Specifications of every BMW Der Abt Off Topic Forum 10 7th June 2008 15:16
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav E60 M5 and E61 M5 Touring Discussion 53 12th May 2005 02:51
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav E39 M5 and E52 Z8 Discussion 11 30th October 2004 15:36
official pictures (autoweek) fcbblue E60 M5 and E61 M5 Touring Discussion 128 5th July 2004 15:51
Interesting official BMW page regarding BMW technologies Gustav E39 M5 and E52 Z8 Discussion 0 7th January 2001 00:32
Page generated in 0.22717 seconds with 12 queries
