Find below mate it was full of them which im told was all because of the electrical fault since replacing the IBS and alternator they all disappeared except an increased emissions fault came on once and hasn't returned since! See below and see if you have any advice?
<TABLE class=ecxMsoNormalTable style="WIDTH: 443.25pt" cellSpacing=0 cellPadding=0 width=591 border=0><TBODY><TR><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm" colSpan=2>
Short Test
</TD><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 25.5pt" width=34></TD></TR><TR style="HEIGHT: 14.25pt"><TD style="HEIGHT: 14.25pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 22.5pt" width=30>
</TD><TD style="HEIGHT: 14.25pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm" colSpan=2>
</TD></TR><TR><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm">
</TD><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 320.25pt" width=427>
Engine module for S85
</TD><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 64.5pt" width=86></TD><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm">
</TD></TR><TR style="HEIGHT: 16.5pt"><TD style="HEIGHT: 16.5pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 22.5pt" width=30>
</TD><TD style="HEIGHT: 16.5pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm">
Current Fault Codes
</TD><TD style="HEIGHT: 16.5pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm"></TD></TR><TR><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 22.5pt" vAlign=top width=30>
</TD><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm" colSpan=2>
2AFE:
Voltage at terminal 87
Error will not cause a warning light
Error is not currently present
Test conditions have been completed
Short circuit or signal interruption
</TD><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm"></TD></TR><TR><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 22.5pt" vAlign=top width=30>
<IMG id=ecxPicture_x0020_3 width=23 height=22>
CD95:
Message (control FGR)
Timeout
<IMG id=ecxPicture_x0020_4 width=23 height=22>
2792:
Power management vehicle electrical system
<IMG id=ecxPicture_x0020_5 width=23 height=22>
CDBC:
Message (audio telephone control)
<IMG id=ecxPicture_x0020_6 width=23 height=22>
2744:
Lambda sensor heater diagnostic after START VKAT bank 1
Error will cause a warning light
<IMG id=ecxPicture_x0020_7 width=23 height=22>
2745:
Lambda sensor heater diagnostic after START VKAT bank 2
<IMG id=ecxPicture_x0020_8 width=23 height=22>
27C0:
Tankgeber elektrischer Fehler
Timeout
<IMG id=ecxPicture_x0020_9 width=23 height=22>
27B6:
VANOS oil pressure
Timeout
<IMG id=ecxPicture_x0020_10 width=23 height=22>
278C:
Generator
Timeout
</TD><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm"></TD></TR><TR><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 22.5pt" width=30>
</TD><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm" colSpan=3>
</TD><TD style="HEIGHT: 14.25pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm"></TD></TR><TR><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm">
Dynamic stability control DXC8 plus E60
Current Fault Codes
<IMG id=ecxPicture_x0020_11 width=27 height=28>
<IMG id=ecxPicture_x0020_12 width=23 height=22>
5E40:
Wheel speed sensor rear right: Signal edge missing (RDF-Typ 11i).
<IMG id=ecxPicture_x0020_13 width=23 height=22>
5DF7:
DSC-ECU: ECU-internal: Operating system: Low background-computing cycle(task)-activity - system overloaded!
<IMG id=ecxPicture_x0020_14 width=23 height=22>
D373:
F-CAN: Message LENKRADWINKEL_OBEN_Gateway TimeOut (ID 0x0C9h) not received or wrong message length (DLC) [transmitter: SZL]
Timeout
Gearbox control unit
Current Fault Codes
<IMG id=ecxPicture_x0020_15 width=27 height=28>
<IMG id=ecxPicture_x0020_16 width=23 height=22>
5201:
<IMG id=ecxPicture_x0020_17 width=23 height=22>
5202:
<IMG id=ecxPicture_x0020_18 width=23 height=22>
5203:
<IMG id=ecxPicture_x0020_19 width=23 height=22>
5204:
<IMG id=ecxPicture_x0020_20 width=23 height=22>
520B:
<IMG id=ecxPicture_x0020_21 width=23 height=22>
520A:
<IMG id=ecxPicture_x0020_22 width=23 height=22>
5103:
<IMG id=ecxPicture_x0020_23 width=23 height=22>
4F40:
Signal or value below threshold
Gear lever (GWS)
Unable to parse fault information for: Gear lever (GWS)
Car Access System 3
Current Fault Codes
<IMG id=ecxPicture_x0020_24 width=27 height=28>
<IMG id=ecxPicture_x0020_25 width=23 height=22>
A0B5:
Signal identification peed error
Instrument cluster
Current Fault Codes
<IMG id=ecxPicture_x0020_26 width=27 height=28>
<IMG id=ecxPicture_x0020_27 width=23 height=22>
A557:
Debug info instrument cluster
<IMG id=ecxPicture_x0020_28 width=23 height=22>
A559:
Terminal 30g-f switch off
<IMG id=ecxPicture_x0020_29 width=23 height=22>
931D:
vehicle electrical system voltage, excess voltage or low voltage
Light module
Current Fault Codes
<IMG id=ecxPicture_x0020_30 width=27 height=28>
<IMG id=ecxPicture_x0020_31 width=23 height=22>
9CC2:
Hardware line to SZL missing
<IMG id=ecxPicture_x0020_32 width=23 height=22>
E516:
Telegram Handling of steering column timeout
Timeout
Body Gateway Module (KGM)
Current Fault Codes
<IMG id=ecxPicture_x0020_33 width=27 height=28>
<IMG id=ecxPicture_x0020_34 width=23 height=22>
93BD:
Servotronik: Speed invalid
Body Basic Module (KBM)
</TD><TD style="HEIGHT: 16.5pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm"></TD><TD style="HEIGHT: 16.5pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm">
</TD><TD style="HEIGHT: 16.5pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm"></TD></TR><TR><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 22.5pt" vAlign=top width=30></TD><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm" colSpan=2>
No Faults Found
</TD><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm"></TD></TR><TR style="HEIGHT: 14.25pt"><TD style="HEIGHT: 14.25pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 22.5pt" width=30>
Heating / air conditioning unit
<IMG id=ecxPicture_x0020_36 width=27 height=28>
No Faults Found
Electronic fuel pump (EKP
Unable to parse fault information for: Fuel pump (EKP)
Seat module - driver (SMFA)
Unable to parse fault information for: Seat module - driver (SMFA)
Central control unit
<IMG id=ecxPicture_x0020_37 width=27 height=28>
No Faults Found
Anti-theft system
Current Fault Codes
<IMG id=ecxPicture_x0020_38 width=27 height=28>
<IMG id=ecxPicture_x0020_39 width=23 height=22>
9D12:
Error is currently present
Central information display
Current Fault Codes
<IMG id=ecxPicture_x0020_40 width=27 height=28>
<IMG id=ecxPicture_x0020_41 width=23 height=22>
A46D:
Malfunction because of head-unit reset
Timeout
Advanced Crash Safety Module (ACSM60)
Current Fault Codes
<IMG id=ecxPicture_x0020_42 width=27 height=28>
<IMG id=ecxPicture_x0020_43 width=23 height=22>
93FB:
Speed - speed signal missing
<IMG id=ecxPicture_x0020_44 width=23 height=22>
93D1:
Supply voltage - Overvoltage
Seat module - passenger
Unable to parse fault information for: Seat - passenser (BFS)
Audio / Video control unit
Unable to parse fault information for: Audio/video control (CHAMP)
MOST/CAN radio gateway CD73/MD73
Current Fault Codes
<IMG id=ecxPicture_x0020_45 width=27 height=28>
<IMG id=ecxPicture_x0020_46 width=23 height=22>
E18F:
E18F Central registry does not match with debit configuration (Error_Registry_New).
Tire pressure control module
Unable to parse fault information for: Tire pressure
Rain and light sensor
<IMG id=ecxPicture_x0020_47 width=27 height=28>
No Faults Found
Sunroof module
Current Fault Codes
<IMG id=ecxPicture_x0020_48 width=27 height=28>
<IMG id=ecxPicture_x0020_49 width=23 height=22>
93BD:
Siren / tilt sensor
Unable to parse fault information for: Tilt sensor
Airbag, steering column (SZL)
Current Fault Codes
<IMG id=ecxPicture_x0020_50 width=27 height=28>
<IMG id=ecxPicture_x0020_51 width=23 height=22>
951B:
System over voltage
Switching centre, Centre Console (SZM)
<IMG id=ecxPicture_x0020_52 width=27 height=28>
No Faults Found
Motorola TCU - US
Current Fault Codes
<IMG id=ecxPicture_x0020_53 width=27 height=28>
<IMG id=ecxPicture_x0020_54 width=23 height=22>
A36D:
Transmission distribution module
Unable to parse fault information for: Transfer case
Active cruise control for E65
Unable to parse fault information for: Active Cruise control (ACC)
Active front steering for E70
Unable to parse fault information for: Active steering (AFS)
Trailer module
Unable to parse fault information for: Trailer module (AHM)
Active backrest width adjustment - passenger
Unable to parse fault information for: Backrest - passenger (ALB)
Top hi-fi amplifier version 1.08
<IMG id=ecxPicture_x0020_55 width=27 height=28>
No Faults Found
Convertible soft top module E64
Unable to parse fault information for: Convertible top (CVM)
Digital terrestrial radio
Unable to parse fault information for: Radio (DAB)
Full beam assistant
Unable to parse fault information for: Full beam assistant (FLA)
Tailgate lift
Unable to parse fault information for: Tailgate (HKL)
Head-up-display (HUD)
Current Fault Codes
<IMG id=ecxPicture_x0020_56 width=27 height=28>
<IMG id=ecxPicture_x0020_57 width=23 height=22>
A4EB:
Power supply voltage, overvoltage or undervoltage
<IMG id=ecxPicture_x0020_58 width=23 height=22>
A4F5:
CAN: Failure / error telegram status KOMBI
Hybrid radio USA
Unable to parse fault information for: Radio - Hybrid (IBO)
Longitudinal dynamic manager
Unable to parse fault information for: Longitude manager
Aerial / Antenna tunre (ANT)
Unable to parse fault information for: Aerial / Antenna tuner (ANT)
Professional Radio / User interface (CIC / CCC-BO / M-ASK-BO / RAD2-BO / RAD)
<IMG id=ecxPicture_x0020_59 width=27 height=28>
No Faults Found
Night vision camera
Unable to parse fault information for: Night vision
Park Distance Control (PDC)
<IMG id=ecxPicture_x0020_60 width=27 height=28>
No Faults Found
Passive go system
<IMG id=ecxPicture_x0020_61 width=27 height=28>
No Faults Found
Rear seat entertainment
Unable to parse fault information for: Rear entertainment
Additional heater diesel / park heating
Unable to parse fault information for: Park heating
Lane departure warning
Unable to parse fault information for: Lane departure
Central input device (high) E60
<IMG id=ecxPicture_x0020_62 width=27 height=28>
No Faults Found
</TD><TD style="HEIGHT: 14.25pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm"></TD></TR><TR style="HEIGHT: 16.5pt"><TD style="HEIGHT: 16.5pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 22.5pt" width=30>
The following modules were not found in the vehicle
</TD><TD style="HEIGHT: 16.5pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm"></TD></TR><TR style="HEIGHT: 14.25pt"><TD style="HEIGHT: 14.25pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 22.5pt" width=30>
</TD><TD style="HEIGHT: 14.25pt; PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm"></TD></TR><TR><TD style="PADDING-BOTTOM: 0cm; PADDING-TOP: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; WIDTH: 22.5pt" width=30>
Backrest - driver (ALB)
</TD></TR></TBODY></TABLE>
<!--tmpl() _1-->
