25th December 2012, 05:40
#6
Ran across this by accident, but thanks for the kind words WallyM5.
pyro (we chatted a couple of times on one of the coding boards regarding P500S on startup), I'm not sure I understand what isn't working. If you are referring to the the E60 -> Engine -> S85 from INPA, there are two different versions of the DME. I forget the cut-off date, but I think it is very early on, like 9/05 build dates or so.
If the second entry is simply missing, you're in luck. The menu layout is set by a configuration file (INPA/CFGDAT/INPA.INI). If the only thing that has happened is the config file was changed, you are in luck. If the actual ECU files are missing, it's a little harder. If you look in your EDIABAS\ECU folder, the should be two files for the MSS-65 DME. One is called MS_S65.PRG and the newer one which you probably need is MS_S65_2.PRG. If you have both of those files, post your INPA.INI here and we can see what is wrong with it.
