DIY: Side marker LED upgrade - BMW M5 Forum and M6 Forums
Like Tree55Likes
Old 10th December 2012, 05:13   #1
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
Here you go for sharing.
Replace the dull and boring OE bulb with LED bulbs. Your choice, you can either go with cool white, amber or red LED bulb.
The bulbs I ordered are error free. It has a built in load resistor so that it wont throw any fault light message.
These bulbs will also work for our license plate lamps.
Cheap and easy mod. Takes about 2 minutes each side, bulbs fit perfect, no fault light errors. Highly recommended.
Here are some photos and links. Hope that helps some of you.
2X 194 2825 921 W5WB W5W 2821 5 SMD Canbus White LED Dome Lights Map Lamps | eBay
Dan
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is offline   Reply With Quote
The Following User Says Thank You to whatheheck For This Useful Post:
MKSixer (22nd December 2012)
Old 10th December 2012, 05:20   #2
zerocks1
zerocks1's Avatar
Garage: 2007 M6 Cab Sapphire Black
Another big 'Like'. I had to code out the bulb check on the pre 08's, or a bulb out error displayed. This was one of my favorite, simple light mod's.
Again, nice job and great writeup.
zerocks1 is offline   Reply With Quote
The Following 2 Users Say Thank You to zerocks1 For This Useful Post:
MKSixer (22nd December 2012), whatheheck (10th December 2012)
Old 21st December 2012, 22:26   #3
Lummox
Lummox's Avatar
Garage: 2007 Dinan M6 Black Sapphire & CF
Hi Dan,
I've got these License Plate Bulbs, and they don't turn on. I see that you are using the 121 w/resistor built in for both the side marker and the license plate. As you can see, I have the 221 w/resistor built in. Did I get the wrong part #? 121 vs 221??? Any input would be greatly appreciated!
Thank you very much!
Big Mike
Mike's Ride = 2007 e63 M6 SMG Black Sapphire Metallic w/CF
Evolve Alpha N Tune
Dinan High Flow Throttle Bodies
Dinan High Flow Middle Racing Exhaust with 4" Resonators
Dinan Free Flow Exhaust Cans (No Drone at All)
Dinan 21mm Adjustable Rear Anti-Roll Bar
Dinan CF Rear Shock Tower Brace with Spring Perch Mod
Dinan CF Front Strut Tower Brace
Dinan High Flow Air Mass Meter/Intake Assemblies
Dinan 3:91 LSD
Dinan Lower Control Arm Monoball Kit
Dinan Pedal Set
RPI Scoops
Brembo 6-Pot Font Brakes with Slotted Rotors
Brembo 4-Pot Rear Brakes with Slotted Rotors
KW V3 Coilovers
Motorsport Hardware Wheel Studs and Lug Locks
H&R Spacers Front 12mm Rear 15mm
Facelifted Front LED Turn Signals
Facelifted Rear LED Brake and Turn Signals
Rear 3 Tinted 5%
Side 2 Tinted 15%
ACS Rear Spoiler
Lummox is offline   Reply With Quote
Old 22nd December 2012, 10:35   #4
whatheheck
whatheheck's Avatar
Sales Feedback: (4)
Hi Big Mike,
Those should work for both side markers and license plate bulbs.
All LED's all polarity sensitive or they wont work. Which basically means 12 volts power needs to be connected to the + side of the LED in order for them to work.
So this is what needs to be done: turn on your parking lamps, remove the original bulbs and insert the LED bulbs, if the LED bulbs dont light up - remove the bulb and rotate it 180 degrees then replug it back in and it should work.
Do the same to the other bulb and it should work. If they still dont work, then the LED bulbs are defective.
Hope that helps.
Originally Posted by Lummox View Post
Hi Dan,
Big Mike
Old 22nd December 2012, 14:16   #5
Lummox
Lummox's Avatar
Thanks Dan! Getting the fenders rolled this morning. I'll try them again this afternoon.
The Following User Says Thank You to Lummox For This Useful Post:
whatheheck (24th December 2012)
Old 22nd December 2012, 19:30   #6
Jackson1019
Jackson1019's Avatar
Garage: Crown Royal XR
Pictures of the rolled fenders after please
I don't like driving a car with traction-control lights flashing all the time. It's like having sex in a wetsuit
Horacio Pagani
Anthony
08 E64 Alpine White BMW M6 Drop Top
RPI Red Ram Air Scoops, BMC Air Filters, and Block Off Plates
Eisenmann Race Exhaust
Matte Black OEM M6 Wheels
5 % tint all the way around
Black M6 Badges
Matte Black Kidneys
Red Calipers w/ M logo
Vorsteiner Black W/ White Trim Door Mats
Valentine 1 Radar hardwired w/ Blendmount
WeissLicht all interior lights LED Upgrade
WeissLicht License Plate LED
Eisenmann Race exhaust sound:
http://www.youtube.com/watch?v=AovubpAeilo
WWW.AMERICANFRICTION.COM
Jackson1019 is offline   Reply With Quote
Old 23rd December 2012, 18:45   #7
Lummox
Lummox's Avatar
Sorry guys, Christmas is getting in the way. Gotta go out of town until just before New Year's. Had no idea Dan that the bulbs were polarity sensitive. Must have put them both in backwards, then went away scratching my head. I'll post up some pix when I get the new spacers.
Fender roll came out great, and can be done by anyone who is careful. Had to trim the inner apron a bit, but I'm not too worried about that. Shooting for 15mm rear, and 12 mm front. I'll be happy with that for a while. May adjust the drop a bit when she goes to Dinan for corner balancing.
Old 24th December 2012, 06:32   #8
GIFF
GIFF's Avatar
Garage: 2007 M6 Grey
These lights are awesome, not only do they have an improved appearance, they also light up my mail box on these short daylight days. Thank's to Dan I get ALL my bills now! ..... LOL
~Gary
GIFF is offline   Reply With Quote
Old 24th December 2012, 16:26   #9
whatheheck
whatheheck's Avatar
Sales Feedback: (4)
You're welcome Gary!
And thanks for the acknowledgement and appreciation!
Old 29th December 2012, 22:15   #10
sattman
sattman's Avatar
Garage: 2010 M6 space grey metalic
Dan,
Thank you once again. I replaced my side markers with the white LED's, and while i was at it i replaced the license plate bulbs. Looks much better.
2010 M6 Space grey metallic
Aluminum pedals
3M clear bra
Eurocharged handheld tuner
RPi GT exhaust Sec. 1, 2 & 3
RPi Scoops & Block off plates
H & R Springs
21" HRE 597r
2006 M6 Interlagos blue - silvertone interior
- sold
ACS Trunk Lid Spoiler
ACS Springs
ACS White carbon interior
ACS rep Front splitters
sattman is offline   Reply With Quote
Check Side Marker lights jack eiler E39 M5 and E52 Z8 Discussion 15 15th August 2012 00:47
How to take off the side grilles and marker lights? STS-V E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 6 23rd May 2012 14:59
Quick Side Marker question.... Fast.M5 E60 M5 and E61 M5 Touring Discussion 1 15th January 2011 15:26
For Sale E39 OEM Clear Side Marker NEW ///WeissM Parts / Other For Sale or Wanted 0 5th July 2009 22:23
m6 side marker beside the side grille api3 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 10 22nd February 2009 04:36
