HELP, 2008 BMW M6 DSC malfunc, EDC Error - BMW M5 Forum and M6 Forums
 22Likes
post #1 of 80 Old 6th November 2012, 07:14 PM Thread Starter
nitinj
Hey guys,
Recently my 2008 BMW M6 Coupe gave me the following errors: EDC malfunction, DSC malfunction, Start-off assistance, DBC malfunction. This is the 1st time I am getting these errors.
Have any of you had these errors before? What kind of repairs do you think I might need to fix this? How much money would you estimate these repairs might cost (I understand this is just a guess)? I am just trying to figure out how skewed I might be here.
I have had the errors for a few days, and they come and go. In the morning, when I start the car for the 1st time the errors are gone, and I get a “All systems are okay”. At this time I am able to switch between comfort EDC mode to Sport stiff EDC mode successfully with no problems. But after about 20 mins of driving these error reappear.
Earlier this year I had the Dinan Stage 2 suspension installed on my car. I am scheduled to take my car to the same shop to have them fix this.
Also, recently my battery has been running low. About 2 months ago, after a 1 week long business trip away, upon starting the M6 it warned me that the battery voltage was low. Eventually after driving the car around for 30 mins the warning went away.
Honestly, driving around town with these errors, the car seems fine and safe. So it will be hard to justify spending a lot of money (like over ~$2000) on this repair, but we will see.
Here are some photos of the errors.
nitinj is offline
post #2 of 80 Old 6th November 2012, 07:37 PM
Muscles
Muscles's Avatar
If your battery was low, it could be that you just need to go the dealer to get these codes reset and cleared and problem solved
Would then recommend to buy a trickle charger to ensure the battery is always at it's optimum to prevent possible future error codes
M6 SMG Convertible (e64 2006)
Exterior
Interlargos Blue, Full AC Schnitzer bodykit inc boot spoiler, AC Schnitzer front grill, AC Schnitzer bonnet & boot badges, Carbon fibre rear compartment lid, front kidney grills (inc fins), wing mirror lower covers & front wing grills, 15% window tints, Custom 21" Monotec T07 forged monoblock alloys “Chrome face / Gloss black inserts", Yokohama ADVAN Sport tyres: 255x30x21 fronts, 295x25x21 rears, BMW blue/silver carbon fibre wheel caps, H&R pro kit lowering springs, MGP Black Brake Calliper Covers, steal braided brake lines, Ice white angel eye bulbs, LED number plate lights, Nanoversiegelung (nano paint sealant).
Front 405mm dia / 8 pot calipers BBK kit (planned)
Rear 380mm dia / 6 pot calipers BBK kit (planned)
Interior
Silverstone 2 extended marino leather inc centre console and dash, HUD, Voice Activation, LED interior lights, MB Quart DKH110 centre speaker, Carbon fibre / Alcantara flat bottom & flat top steering wheel c/w M stitch, Carbon fibre interior (std), Carbon fibre tweeter covers, speaker grills, window switch covers, door handle cups, steering wheel multi function switch surrounds, rear seat access levers & surrounds, idrive cover plate, cup holder & mounting bracket, Aluminium Air Con dial surrounds, Custom Car Matts (2cm thk) /silverstone leather trim, ///M pedals, Custom ///M logo wind deflector, Alcantara SMG gaiter and hand brake gaiter c/w M stitch.
Carbon fibre seat trim covers (planned)
Carbon fibre HUD surround (planned)
Engine
Full AC Schnitzer exhaust system, aFe stage 2 cold air intake system & RPI air scoops , ECU stage 2 Re-Map (vmax 340kmh/212mph), Sprint booster V2
Muscles is offline
post #3 of 80 Old 6th November 2012, 08:10 PM
tayvid
tayvid's Avatar
tayvid is offline
post #4 of 80 Old 6th November 2012, 08:23 PM Thread Starter
nitinj
I was suspecting the battery for a couple days also. But in the morning the errors on the car go away, and the check on the car says "All Systems Okay". And only after 20 mins of driving do those errors reappear.
Hopefully it is just the battery, which should not be too expensive to replace (anyways battery replacement is part of regular maintanance on the car).
nitinj is offline
post #5 of 80 Old 6th November 2012, 08:48 PM
CatsFan
CatsFan's Avatar
Check the voltage on the battery, but it may be the alternator. Battery must be registered and replaced with a proper AGM battery.
-David
2013 F12 M6 - Alpine White - Black Merino - Loaded
2014 Porsche 911 C2S - Carrera White - Two tone Espresso/Cognac - Aerokit Cup
Member: BMWCCA #471614
CatsFan is offline
post #6 of 80 Old 6th November 2012, 09:25 PM
whatheheck
whatheheck's Avatar
I am betting your battery is going dead as well. Replace ASAP before you get stranded somewhere and will need a flatbed as the car wont start anymore.
Driving the car for 30 minutes will make the fault messages go away because the alternator takes over once the car is started.
I have a post on here on how to replace the battery and with what aftermarket brand that works great and fits well.
Battery life on our beast is good for around 4 - 5 years. I highly recommend replace it preventively to avoid throwing fault codes or car will no longer start one day as battery will no longer hold a charge and not enough reserve to start the car.
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is offline
post #7 of 80 Old 6th November 2012, 11:18 PM
Clyde
Clyde's Avatar
The errors could be caused by the steering angle sensor, and low battery voltage aggravates the issue.
Turn signal not clearing after a turn is another symptom of a faulty steering angle sensor.
I had similar intermittent errors and keeping the battery charged with a Battery Tender decreased the frequency of errors.
Cleaning the steering angle sensor solved the problem.
No matter what the cause of your errors, deal with the low voltage problem first.
Clyde is offline
The Following User Says Thank You to Clyde For This Useful Post:
whatheheck (7th November 2012)
post #8 of 80 Old 7th November 2012, 12:16 AM Thread Starter
nitinj
nitinj is offline
post #9 of 80 Old 7th November 2012, 05:10 PM
0gravity
I agree with Clyde, look up steering angle sensor errors with the diagnostic tool and see what faults come up first. Then check your battery and alternator. There are numerous threads regarding the SZL (steering angle sensor) on here.
0gravity is offline
post #10 of 80 Old 7th November 2012, 09:04 PM
TZ04XJR
TZ04XJR's Avatar
It could be any of the following..
Battery- $200-$600
Alternator / Voltage Regulator- $1,000 Indy Shop
SZL / Steering Angle Sensor- $1,000 Indy Shop
Idle Actuator- $980 Indy Shop
Throttle Actuator- $1,800 Dealer
I've had everything in the list above replaced on my beast. You need to get a proper scan done to identify the specific cause. You have 2 throttle actuators and 2 idle actuators, 1 on each bank. I went through major issues getting the correct one diagnosed. You can swap them from side to side to see if the faults move to the other bank.
Good luck, update this thread with the repair for others in the future.
-TZ
E60 M5 SMG - Sapphire Black exterior, Black interior, Full leather, Ventilated comfort seats, Aluminum trim, Alcantara Headliner, Matte Black front/side grills, 20% window tint, Black Plasti Dipped Wheels, Hardwired 9500ix, RPI scoops(Red), Block off plates, BMC filters (c/f delete), Evolve-R Stage 2 Tune, Muffler & Secondary Cat Delete
P500s S6 DSC OFF- ALL DAY, EVERY DAY.. Unless it's wet out
Daily:
2008 C63 AMG, Black, Stock fo now..
Past:
2009 Cadillac CTS-V, Black Raven Sedan, Auto, Recaros
2004 Jaguar XJR- Platinum Silver Metallic exterior, Charcoal interior
2001 Jaguar XJR- Platinum Silver Metallic exterior, Charcoal interior
TZ04XJR is offline
The Following 2 Users Say Thank You to TZ04XJR For This Useful Post:
KILLZBUGZ (8th November 2012), whatheheck (8th November 2012)
Increased Emissions error and DSC Malfunction.... NateO E60 M5 and E61 M5 Touring Discussion 1 1st July 2011 12:37 AM
Help Please ! EDC mulfunction error freets E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 3rd May 2010 09:54 PM
Graphs: BMW M3 Convertible E93 Launch Control EDC Hard / EDC Soft / Top Down EDC Soft Gustav E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 1 6th September 2008 08:08 AM
Correction, Problem with EDC not DSC Marchitect E60 M5 and E61 M5 Touring Discussion 3 23rd July 2007 08:23 PM
Advice on DSC error message? sulaiman E60 M5 and E61 M5 Touring Discussion 2 17th March 2006 05:14 AM
