Here you go for sharing.
Note, I have a 2009 M6 Cabrio.
BMW doesnt have "standard" connectors so you will have to check yours and may need to modify to make it fit as some are not plug and play.
Also, thanks to Jaff for posting on this thread that inspired me to do mine too.
http://www.m5board.com/vbulletin/e6...10563-oem-license-plate-leds-installed-2.html
Now:
1) You will need to order two 63 267 193 294. I believe they are $18.00 each.
2) To remove the license plate lamp assembly - using plastic wedge tool push the light assembly to the right, then down as shown on photo below.
3) I have a 2009 M6 and the LED license plate connector is NOT plug and play with my 2009 M6. Sucks....
So I figured out the difference. Simply put, you will need to cut, remove the inside connector tab as shown on photo below with red stripes.
4) One you remove the tab, then it becomes plug and play.
Note the difference between LED and BMW stock from factory. LED is white and consumes much less power while OE is yellow, consumes good power and bulb gets real hot.
Another note: The BMW LED license plate color is 6,000K white. I like cool white so I may to upgrade mine again later and find a 8,000K LED bulb.
Enjoy.
Now:
Enjoy.
