Flat Tire monitoring system - BMW M5 Forum and M6 Forums
Like Tree21Likes
Old 1st September 2012, 18:15   #1
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
Question please:
On my 2006 M6 - BMW's ancient design used technology that measures rotation of the wheel to sense when we have a flat tire.
Problem with this design is two fold. There is no visible air pressure reading available, and also a Flat Tire monitoring system is a poor design as it is basically a dead person monitor. It only tells you when you already have a flat tire / person is already dad. Too late.
We want a system that warns us if we are losing tire air pressure and also the ability to read tire air pressure and tire temperature on command. So a Tire Pressure monitoring system is a better design.
That is the reason I installed a Hella TPMS on my 2006 M6. The Hella design replaces the stock air valve with one that reads and transmits air pressure reading and also temperature reading. Data is sent to a display installed inside the cabin.
See here: Installation of Hella TC-400 Tire Pressure Monitor System
My question is on LCI models 2009 and on (as I just bought a 2009 M6 Cabrio). Does your 2009 or 2010 LCI models still uses Flat Tire Monitor System or did BMW finally installed wheel air valves that sends air pressure reading that we can read on the Nav display inside the cabin?
Thanks in advance.
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is online now   Reply With Quote
The Following User Says Thank You to whatheheck For This Useful Post:
Hasan Shaikh (2nd September 2012)
Old 1st September 2012, 19:39   #2
zerocks1
zerocks1's Avatar
Garage: 2007 M6 Cab Sapphire Black
Dan, I don't believe the following has changed in an 09> MY. Your 06 had an FTM (flat tire monitoring system) which merely measured pressure in each tire against an algorithm in a module to alert the driver when any tire drops below a pre determined set threshold (which can be changed via coding)
The 07> models have a TPM (tire pressure monitoring system). The name is misleading as the system does not send the actual tire pressure to a display, but rather sends the measured tire pressure to a newer type module that has a different algorithm, which compares each tire pressure to each other from the moment you reset the TPM in the iDrive (usually when you check or change air pressure, done manually by you). If any tire changes pressure vs. the other tires by more than the preset amount (also changeable via coding), the iDrive and cluster indicator will display an error
Unfortunately the actual tire pressure is not displayed. Like you, I have the Hella system and plan to add the sensors in addition to the OEM sensors next time I need tires. I plan to mount them 180 degrees opposite location from the OEM sensors using a hose clamp type mounting system, which I already have from my HRE wheels. They currently hold the OEM sensors.
Let newer model year owners weigh in on anything different
Happy Labor Day
zerocks1 is offline   Reply With Quote
The Following User Says Thank You to zerocks1 For This Useful Post:
whatheheck (1st September 2012)
Old 2nd September 2012, 04:53   #3
SilberGrauE60
SilberGrauE60's Avatar
Garage: 2009 M6 SMG Coupe
Actually, FTM does not measure tire pressure. Instead, it uses the ABS sensors to measure tire rotation speed to tell if a tire has gone down. When a tire loses air, it's circumference decreases and thus spins faster to cover the same distance as the tires with the larger circumferences (full of air). The system is actually quite precise. I had a tire go down about 3-4 psi due to a nail in the tread and the FTM system alerted me. The only drawback is that it cannot tell you which tire has gone down, thus you need to use a tire gauge to measure all tires to see which has gone down. The big benefit is that it does not require the "expensive" TPM sensors in the wheels. If you change wheels/tires, all you need to do is re-calibrate so that the system knows the tire speeds for normal pressures.
Oh, and the '09 models have adopted TPMS (actual tire pressure monitoring) in place of FTM.
2009 M6 Coupe
2004 545i (Sold)
SilberGrauE60 is online now   Reply With Quote
The Following 2 Users Say Thank You to SilberGrauE60 For This Useful Post:
whatheheck (2nd September 2012), zerocks1 (2nd September 2012)
Old 2nd September 2012, 04:58   #4
whatheheck
whatheheck's Avatar
Sales Feedback: (4)
Thank you folks for the great info.
So I guess when its time for me to swap out my BBS rims from my 2006 M6 and move it over to my new 2009 M6 Cabrio FTM should work just fine because the 2009 Cabrio FTM system doesnt use tire air valves?
Old 2nd September 2012, 05:01   #5
zerocks1
zerocks1's Avatar
Thanks SilberGrau, I had understood what you wrote as well until a BMW engineer who visited my dealership some years ago disputed that belief and explained it to me differently. He stated that the tire pressure monitors are basically all the same in all cars. Different designs, different frequencies. They all measure actual pressure. The cars electronics uses the info differently. Your explanation makes more sense. But whichever way it works, glad we answered Dan's question
Old 2nd September 2012, 09:25   #6
Hasan Shaikh
Hasan Shaikh's Avatar
Garage: E63 ///M6 - White
WoW! Awesome info guys.
I have got to get me that Hella TPMS Dan had.
Hasan Shaikh is offline   Reply With Quote
The Following User Says Thank You to Hasan Shaikh For This Useful Post:
Old 2nd September 2012, 09:43   #7
carrisco
carrisco's Avatar
Garage: 2007 M6 Black Sapphire Metallic ☆ Aprilia RSV Mille R ☆ Suzuki GSX-R1000
Have you found a new M6? Or is this hypothetical planning?
-b.
Bryan
"Turbochargers are for people who can't build engines." – Keith Duckworth
• 2007 M6 | Sapphire Black • RPi GT Exhaust | Full System • RPI Scoops • Dinan Carbon Fiber Intakes • Dinan Stage 3 ECU • Dinan Carbon Fiber Front Strut Tower Brace • H&R Springs • 20" AC Schnitzer Type V Forged Magnesium Rims • 25mm Rear Spacers | 20mm Front Spacers • Hankook Ventus V12 evo K110 Tires •
carrisco is offline   Reply With Quote
Old 2nd September 2012, 09:46   #8
Hasan Shaikh
Hi Bryan!
I think Dan has already purchased the car and is expecting delivery very soon.
Looking forward to the pics Dr. Dan.
Old 2nd September 2012, 09:49   #9
carrisco
carrisco's Avatar
Originally Posted by Hasan Shaikh View Post
Hi Bryan!
Why is he so secretive?
Maybe he was worried someone else would swipe it before the transaction was completed?
I hope he found the colors he wanted -- as I remember it, they were a bit unique.
-b.
Old 2nd September 2012, 09:53   #10
Hasan Shaikh
-b.
Hahahaha!
I think he is just waiting to receive the car and the give it a nice lean and polish and then he will announce it with pictures and everything.
I am sure he has got what he was looking for. Otherwise, he would still be searching.
Tire pressure monitoring system panhndl E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 29th August 2008 00:21
Tire Monitoring System 1, BMW Mobility System 0 icsfsedod E39 M5 and E52 Z8 Discussion 6 11th June 2006 03:57
'03 M5 tire monitoring system kapi E39 M5 and E52 Z8 Discussion 4 12th February 2005 22:52
Tire Pressure Monitoring System GNALUZU E39 M5 and E52 Z8 Discussion 2 1st October 2001 19:33
Tire Pressure Monitoring System JLieb E39 M5 and E52 Z8 Discussion 1 18th March 2001 16:50
