Flat Tire monitoring system - Page 2 - BMW M5 Forum and M6 Forums
Like Tree21Likes
Old 2nd September 2012, 09:54   #11
carrisco
carrisco's Avatar
Garage: 2007 M6 Black Sapphire Metallic ☆ Aprilia RSV Mille R ☆ Suzuki GSX-R1000
Originally Posted by zerocks1 View Post
Thanks SilberGrau, I had understood what you wrote as well until a BMW engineer who visited my dealership some years ago disputed that belief and explained it to me differently. He stated that the tire pressure monitors are basically all the same in all cars. Different designs, different frequencies. They all measure actual pressure. The cars electronics uses the info differently. Your explanation makes more sense. But whichever way it works, glad we answered Dan's question
This makes sense because when I finally got around to putting my AC Schnitzer rims on, one of the tires hadn't sealed properly to the rim and was losing air. When I parked the car after driving it home from the tire shop, everything was fine with the TPMS (I had done the reset on the system after the new tires were installed). Four days later when I went to use the beast, it immediately alerted me about a tire pressure problem with my left rear tire. This was immediately upon starting the car -- I had not moved an inch.
It would not be possible for the system to alert me of the low (not flat) tire pressure in the left rear tire without being able to measure the actual pressure and compare it to my setting in iDrive.
-b.
Bryan
"Turbochargers are for people who can't build engines." – Keith Duckworth
• 2007 M6 | Sapphire Black • RPi GT Exhaust | Full System • RPI Scoops • Dinan Carbon Fiber Intakes • Dinan Stage 3 ECU • Dinan Carbon Fiber Front Strut Tower Brace • H&R Springs • 20" AC Schnitzer Type V Forged Magnesium Rims • 25mm Rear Spacers | 20mm Front Spacers • Hankook Ventus V12 evo K110 Tires •
carrisco is offline   Reply With Quote
The Following 2 Users Say Thank You to carrisco For This Useful Post:
Hasan Shaikh (2nd September 2012), zerocks1 (2nd September 2012)
Old 2nd September 2012, 16:16   #12
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
Hi B and Hasan, Yes, I found my next beast.
It's a 2009 M6 Convertible, Black sapphire metallic exterior with Sepang Bronze leather interior. Quite unique color combo.
Only 17,000 miles, all options including steering wheel heater, soft close doors, heads up display, individual audio system, comfort access, heated seats, alarm system, wood trim this time, navigation, etc.
Found her for sale on a dealership in Georgia. I bought it two days ago.
I am flying to Atlanta on Monday to close the deal, then I am having her transported to my home via an enclosed container next week.
Expected transport time is 10 days from Georgia to Everett.
Cant wait to welcome Betsy IV to her new home.
First mod is SmartTop module convertible control. Then all LED lights.
Photos of my new beast coming soon. I cant wait to have her.
Betsy III is now officially listed at Auto Trader and Cars dot com for sale.
Let the mods begin all over again!
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is offline   Reply With Quote
The Following User Says Thank You to whatheheck For This Useful Post:
Old 2nd September 2012, 17:22   #13
whatheheck
whatheheck's Avatar
Sales Feedback: (4)
Update
I just read my 2006 owners manual, and my soon to be 2009 Convertible owners manual.
Apparently, FTM / Flat Tire Monitoring System was the original design when E63 and E64 M6 came out.
Started on 2009 models, BMW introduced as an option TPM / Tire Pressure Monitor System.
As SilberGrauE60 have mentioned, FTM measures wheel / tire rotation speed. A faster spin reports as Flat Tire.
TPM System on the other hand actually installed wheel air valve that has built in electronics that reports air pressure.
Your iDrive will indicate whether you have FTM or TPM system.
Thanks again to everyone that replied.
Old 2nd September 2012, 17:52   #14
zerocks1
zerocks1's Avatar
Garage: 2007 M6 Cab Sapphire Black
I was reading up on this last night. My curiosity got the better of me. The older FTM system, (which I had on my 645), does mention measuring tire rotation, however when you dig deeper what it really did was send the pressure reading, which had +/- 5% accuracy, to the RDC or RDW module that was in those vehicles. The module calculated tire rotations per km and via a preset formula displayed a low (flat) tire condition to the CCC (iDrive display), when the calculated rotation speed differed from the last reset performed by the driver. The tire pressure sensors were/are actually made by Bosch and they did in fact read tire pressure not rotation itself. So the manual was giving us laymen's terms on its operation. There are two frequency bands (in the U.S.) that are used for FTM/TPM's. and the internal watch type battery is good for approximately 10 years.
The web is a dangerous place. But back to the original post by Dan, the actual tire pressure in lbs. is not displayed anywhere. It's still just an indicator of less pressure on each individual tire against the pressure measured from the previous reset and displays a warning The module also takes into consideration the outside temperature and speed the car travels. I couldn't find how often that algorithm updates during a drive, but I do know you can code the pressure change you want the indicator to alert you using nettodat. (the first screen you see when you read a module).
Way TMI, but thought this might make interesting reading. So I still like the Hella system and will install it one of these days. I have the TPM system on my 07. I think they switched in build month 9-06 thereabouts.
zerocks1 is offline   Reply With Quote
The Following 3 Users Say Thank You to zerocks1 For This Useful Post:
carrisco (2nd September 2012), Hasan Shaikh (2nd September 2012), whatheheck (2nd September 2012)
Old 2nd September 2012, 19:40   #15
Hasan Shaikh
Hasan Shaikh's Avatar
Garage: E63 ///M6 - White
Thanks Dan!
That will be a gorgeous M6. Looking forward to the pics.
Hasan Shaikh is offline   Reply With Quote
The Following User Says Thank You to Hasan Shaikh For This Useful Post:
whatheheck (3rd September 2012)
Old 3rd September 2012, 05:09   #16
gkinvest
gkinvest's Avatar
Garage: Jack Daniels
Having seen Dan's new car, may I reassure everyone that it is at least as beautiful as his old M6.
George
Porsche Gemballa Avalanche (4.3 litre), RSR 1600-RR - 1600 hp on race gas
Porsche Gemballa Gt600 - Carrera 4s compressor ( VF-Engineering ) 600 hp
Porsche Gemballa Cayenne Gt650-R. 650 hp
Ferrari 599 GTB Novitec Rosso SuperSport - 888 hp
Lamborghini Aventador LP-760 Mansory Edition - 754 hp
Aston Martin 1-77. V12 - 770 hp. No 57 out of 77
Bmw X3-F25 35i Xdrive M-Pack 380 hp - AC Schnitzer
Bmw M6-E63 Schnitzer 600 hp - Heavily modded
gkinvest is offline   Reply With Quote
The Following User Says Thank You to gkinvest For This Useful Post:
Old 3rd September 2012, 07:17   #17
carrisco
carrisco's Avatar
Oh, well aren't you special, George? You got to see it before everyone else?
How are you? How's life with Gemballa in stereo and a side of Italian?
-b.
George
Old 3rd September 2012, 07:36   #18
gkinvest
gkinvest's Avatar
Bryan, my good friend.
I am doing ok I guess. As usual with ups and downs. Not good to be 54 years old.
Wife drives the X3 35i MPack and now she wants the Gemballa Gt550 for a more 'sporty look' when she goes out, not for business.
So I need a daily ( exotics are excluded ).
I placed few months back an order for the new M6 with G-Power. I cancelled it and I am back again. Now I have a firm order for the new M6, delivery January 2013.
It is deep sea blue with sand beige interior and most options.
We will see. If it plays tricks on me like the old M6, then M// is permanently terminated from my wish list.
I might try the new Porsche 991 then.
We will see.
George
Tire pressure monitoring system panhndl E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 29th August 2008 00:21
Tire Monitoring System 1, BMW Mobility System 0 icsfsedod E39 M5 and E52 Z8 Discussion 6 11th June 2006 03:57
'03 M5 tire monitoring system kapi E39 M5 and E52 Z8 Discussion 4 12th February 2005 22:52
Tire Pressure Monitoring System GNALUZU E39 M5 and E52 Z8 Discussion 2 1st October 2001 19:33
Tire Pressure Monitoring System JLieb E39 M5 and E52 Z8 Discussion 1 18th March 2001 16:50
