Splicing wires - BMW M5 Forum and M6 Forums
 4Likes
  • 1 Post By whatheheck
  • 3 Post By tampamark
post #1 of 8 Old 22nd August 2012, 03:19 PM Thread Starter
whatheheck
whatheheck's Avatar
Splicing wires
I received a few eMails asking me questions on what my recommendations are after I posted on this thread about how crappy those T- Tap splices are (post number 20).
Unfortunately folks, I am not aware of any T-Tap splices that are worth using. Everything that I have tried out there I cannot recommend anyone using on their vehicles as you are bound to have electrical connection problems later if you use those T tap splices.
All you need to do is Google it and I cant find anyone that recommends those T tap splices:
Tapping and splicing wires
The Problem with Wire-Tap Connectors Bareass Choppers Motorcycle Tech Pages
I can only recommend either soldering your wires or using high quality butt splices from makers like Tyco for a solid connection.
When using butt splices - Key is using a good butt splice crimper for a solid reliable connection.
Anyone that needs more info on what I personally use can post here so that others will benefit from the same information too.
Dan
whatheheck is online now
The Following 6 Users Say Thank You to whatheheck For This Useful Post:
chowdah (24th August 2012), deusExMachina (22nd August 2012), MKSixer (22nd August 2012), pizdous (22nd August 2012), tampamark (22nd August 2012), zerocks1 (22nd August 2012)
post #2 of 8 Old 22nd August 2012, 03:31 PM Thread Starter
whatheheck
whatheheck's Avatar
Found this great video on YouTube.
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Dan
The Following 5 Users Say Thank You to whatheheck For This Useful Post:
Bavarian Beast (23rd August 2012), MKSixer (22nd August 2012), pizdous (22nd August 2012), tampamark (22nd August 2012), zerocks1 (22nd August 2012)
post #3 of 8 Old 22nd August 2012, 11:28 PM
tampamark
Dan, I have been splicing wire most of my adult life. That website you referenced had a simple, but genius, illustration of how to strip the wire, spread open the wire, insert the new wire in between, then solder and wrap. I have never seen this method for splicing into a wire without having to cut it, just goes to show you that there is always something new to learn, even something as elegant and simple as this! The information regarding Butt splices is great also and a new path for me to follow when appropriate.
tampamark is offline
The Following 3 Users Say Thank You to tampamark For This Useful Post:
chowdah (24th August 2012), whatheheck (23rd August 2012), zerocks1 (22nd August 2012)
post #4 of 8 Old 22nd August 2012, 11:44 PM Thread Starter
whatheheck
whatheheck's Avatar
You got it Mark. No one knows everything and we always learn something new everyday.
I saw that too and I thought it was genius! That's why I thought I'd post and re-share.
Dan
post #5 of 8 Old 24th August 2012, 03:28 AM
sattman
sattman's Avatar
Dan, I like that crimping tool in the video i was wondering what you used and where to find it to buy. thanks in advance for your advice. Also a good striping tool.
2015 Lamborghini Huracan
2015 S63AMG coupe - White
2016 S550 Coupe - White
2010 M6 Space grey metallic - SOLD
Aluminum pedals
3M clear bra
Eurocharged handheld tuner
RPi GT exhaust Sec. 1, 2 & 3
RPi Scoops & Block off Plates
H & R Springs
RD Sport Sway bars
21" HRE 597r
2013 GTR premium Sllver on white - For Sale
SBD 700 package with asnu injectors and polished intakes
Cobb AP NIS-006 V3 Tuned by Billet
KW sleeves
SPL adjustable front control arms
SPL adjustable rear camber links
Expel Clear bra full bumper, hood and fenders
Durement steering wheel cyber model
2006 M6 Interlagos blue - silvertone interior
- sold
ACS Trunk Lid Spoiler
ACS Springs
ACS White carbon interior
ACS rep Front splitters
sattman is offline
post #6 of 8 Old 24th August 2012, 03:42 PM Thread Starter
whatheheck
whatheheck's Avatar
Here you go, here is what I can recommend.
(The ones I use are aircraft grade and are way too expensive if bought brand new.
I buy mine at the surplus store or I find them in eBay once in a while.)
But the ones below are great for the price and I have recommended them to my friends and family and they are all very happy with it.
1) Wire stripper: Automatic, nice clean insulation cut and will not nick the wires. (Almost aircraft grade)
Amazon.com: Klein Tools 11063 8-22 AWG Katapult Wire Stripper: Home Improvement
2) Butt splice crimper: Automatic, perfect crimp all the time, will not damage the insulation nor the splice.
This will also crimp terminals and lugs.
Amazon.com: Ratcheting Crimp Tool For Insulated Terminals: Electronics
NOTE: I have no affiliation to Amazon.
Hope that helps.
Time to get back to work.................
Dan
The Following 3 Users Say Thank You to whatheheck For This Useful Post:
MKSixer (24th August 2012), tampamark (25th August 2012), zerocks1 (24th August 2012)
post #7 of 8 Old 24th August 2012, 03:57 PM Thread Starter
whatheheck
whatheheck's Avatar
More horror stories on crappy Tap Splices:
Why Tap Splices Should be Illegal - Ford Truck Enthusiasts Forums
My message is simple: Do not use Tap Splices. They are no good and will give you electrical problems later.
Nothing worse than trying to troubleshoot a system that works intermittently, and try to find the root cause of a bad connection somewhere.
And if you are taking your car to a shop to have some electronics installed - tell them NO TAP SPLICES.
Either solder the wires together or use high quality butt splices. And make sure the butt splices are crimped properly. There is also such a thing as bad crimp.
Dan
The Following User Says Thank You to whatheheck For This Useful Post:
post #8 of 8 Old 24th August 2012, 07:45 PM
sattman
sattman's Avatar
Dan, Thanks for the info. I just ordered both tools. Also i will no longer be using those tap splices.
Aluminum pedals
3M clear bra
H & R Springs
RD Sport Sway bars
21" HRE 597r
KW sleeves
- sold
ACS Springs
sattman is offline
The Following User Says Thank You to sattman For This Useful Post:
whatheheck (27th August 2012)
ignition wires roortube E34 M5 Discussion 6 21st February 2009 09:01 AM
splicing in..... gavinp E39 M5 and E52 Z8 Discussion 0 23rd November 2008 11:36 PM
Which wires to tap into? ccm241 E39 M5 and E52 Z8 Discussion 2 20th August 2007 09:14 PM
Ignition Wires Deano E34 M5 Discussion 4 24th April 2007 08:38 PM
Seen this about ground wires?! BURTON E34 M5 Discussion 45 5th June 2006 11:33 PM
