Anyone have the ESS SMG software upgrade done? - BMW M5 Forum and M6 Forums
Like Tree2Likes
Old 22nd August 2012, 03:10   #1
built240
built240's Avatar
Garage: black 2006 M6
A guy in my local shop just got it done to his M6 says it makes a world of diff. Shifts much faster, no lag,etc... I paid $200 to have BMW upgrade my smg software a while back and didnt notice a thing from it. Apparently ESS's upgrade is different. Anyone think its worth it? Could it possibly wear the tranny at all?
S85 SMG Transmission Software - ESS Tuning | BMW Tuning Parts | BMW Racing, Tuning, Aftermarket, Performance Parts | Engine Power Chips | Performance Upgrades Chip
For warranty purposes, all modification talked about on my M6 is for role play only. My M6 is currently 100% stock and the mods I am referring to are from a friends M6 i'm posting about. Thanks
built240 is offline   Reply With Quote
Old 22nd August 2012, 07:52   #2
Hasan Shaikh
Hasan Shaikh's Avatar
Garage: E63 ///M6 - White
I have the Manhart Racing SMG software, and it really makes a big difference.
Hasan Shaikh is offline   Reply With Quote
Old 23rd August 2012, 10:02   #3
built240
built240's Avatar
Hmmmmm so no power increase obviously but how about improvement on 1/4mile times 60mph-130mph, top end shifts,etc....
Will it wear the smg tranny at all?
Old 23rd August 2012, 10:06   #4
Hasan Shaikh
It should improve your 1/4 mile times. The shifting is faster at all RPMs.
It would put more stress on your SMG pump and reduce some of the wear on your clutch.
Old 24th August 2012, 02:16   #5
built240
built240's Avatar
Hmmmmm well my NAC warranty covers the pump but the clutch is not always covered. This may be a good option now that I think about it. How is low end driving? Like around town?
Old 24th August 2012, 07:42   #6
KennethH
KennethH's Avatar
Garage: BMW M5 E60 ESS VT2 SC, Carbon Black.
I have the ESS SMG Tune on my M5, but I also had the VT2-650 installed at the same time, so it's difficult to say about the shifting time and lag, since it has almost 200 chp more to handle now.
However I can say something about the everyday performance and it's at least not worse than stock (euro spec). From what I have been told, this software is only a minor upgrade compared to late versions of BMWs stock euro spec software.
As I see it, there are a few ways to re-program it to shift quicker and all of them will result in more wear and tear. Either you do the physical gear shifts faster, using higher hydraulic pressure. Or allowing shifts at higher engine power output. Or do the clutch engagement/disengagement movement quicker, using higher hydraulic pressure. Or a combination of the three.
Edit: Less shifting time/quicker and more brutal shifts, WILL wear the components quicker. No doubt about that! One simple way of putting it, is that you have a given (fixed) amout of energy beeing transferred through the drivetrain when shifting. Transferring that energy in less time, will result in higher peak stress value AND higher peak temperature in the clutch (same amount of energy, but less time to absorb it evenly and to cool the surface). And we have seen evidence on the forum, showing that the stock cluch gets worn and damaged from high temperatures. Poor clutch function have been seen, even if it's not very worn down. Burn marks and spot oxidisation have been the cause of this. And they come from too high temperatures. Slipping the clutch at WOT and 4k rpm is no good either (as when using LC).
BMW M5 ESS VT2 SC (601 RWHP @ 99 RON)
Options (a selection of all 31 options)
Fully extended Merino black leather
BMW Individual Carbon black
BMW Individual Alcantara black headlining
BMW Individual Black piano paint trim
BMW Individual Shadowline
BMW Individual Tinted Windows
BMW Individual Silverstone II color rims
Climate comfort windows
Glass sunroof
Active sport seats
Navigation Professional
Radio Professional Logic7
Bluetooth
DVD/TV
Voice command
All mirrors auto shade
PDC front and rear
Heated back seat
Mods
ESS Tuning VT2-650 (http://www.m5board.com/vbulletin/e60...60-m5-s85.html)
ESS Tuning SMG software
Lowtec Lowering springs (front) (http://www.m5board.com/vbulletin/e60...nd-e60-m5.html)
LED Exterior Lighting
LED Angel eyes (6000 k)
Xenon bulbs 50 W (6000 k)
Matt black kidney grilles
BBS lug bolts with Silverstone II paint
Custom painted wheel hubs
Full paint correction work (http://www.m5board.com/vbulletin/e60...polishing.html)
Paint top coat sealant (6 layers)
Glass treatment (6 layers)
KennethH is offline   Reply With Quote
Old 24th August 2012, 22:00   #7
built240
built240's Avatar
^^^^ Hmmmm seems our clutches and pumps are so poorly built this has me reconsidering. Thank you.
Old 25th August 2012, 01:17   #8
guess55
Garage: 2010 M6 Coupe AW
we know there is a spec clutch and for hydraulic bump whoelse is making it other than oem one?
guess55 is offline   Reply With Quote
Old 25th August 2012, 03:51   #9
irishbimmer
irishbimmer's Avatar
Garage: 2010 M6 Sapphire Black, Black Full leather, Carbon Fiber, Fully-Loaded, Manuafactured April, 2010
I may be incorrect but I believe there are later iterations available at EAS in Anaheim-the other upgrade used to require sending in your unit and being without the car for quite some time. Software downloaded on site-30 minutes maybe at EAS and you get launch control euro spec.
I don't use it-but my car is running beautifully!
irishbimmer is offline   Reply With Quote
Old 25th August 2012, 20:45   #10
Manhart Racing
m5board.com Site Sponsors
Garage: All Manhart Racing Cars
Hey Hasan, first of all i would like to thank you for the nice post
Since we are an official Vendor here i allow myself to post something about the MHR ECU/SMG Upgrade.
Currently we have a special offer going on where we are upgrading the SMG Software with the MHR Software vor the V10's "Free of Charge" in case somebody purchases a Manhart Racing ECU Software.
FYI, we do both jobs simply via OBDII
www.manhart-racing.de
http://www.facebook.com/ManhartRacing
for any inquiries please contact: simon@manhart-racing.de
Instagram: MANHARTRACING
Manhart Racing is offline   Reply With Quote
The Following User Says Thank You to Manhart Racing For This Useful Post:
Hasan Shaikh (26th August 2012)
ESS SMG software WallyM5 E60 M5 and E61 M5 Touring Discussion 28 10th February 2012 19:41
ESS smg upgrade or factory upgrade? built240 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 29 7th February 2012 21:21
Who's actually done the smg software upgrade built240 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 8 8th December 2011 07:59
ESS tuning SMG / ECU software sale Roman@ESS M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 40 18th May 2011 17:34
ESS SMG Software tune MrSnrub187 E60 M5 and E61 M5 Touring Discussion 2 29th January 2011 00:52
