Not funny story and questions about somehow locking keys in car, and then power died. - BMW M5 Forum and M6 Forums
Like Tree6Likes
Old 12th August 2012, 17:59   #1
STS-V
STS-V's Avatar
Garage: 2006 BMW M6-Interlagos Blue/White Interior
Hello everyone, let me share a story with you. Previously I had a Cadillac STS-V with electronic locks and keyless ignition and entry. In the 2 years I owned the car, I locked the keys inside of it 2-3 times because if they were on a "dead spot" the doors would lock and not sense the transmitter inside the car to open the doors. And I always leave the keys in the car in my garage.
You would think after getting burned 2-3 times previously with this problem that I either would A) not leave the keys in the car; or B) get a spare door key for the M6 based on the fact it uses a very similar keyless system with electronic locks.
Fast forward to today, where somehow the battery on my M6 is dead (that is what it means when you pull the handle and the locks dont light up, correct?) and my only keyfob with the door key is in the glove box. Not too sure how this perfect storm of situations (battery dead, fob in glove box, doors locked) occurred, but I am quickly learning that it sucks.
Two of my personal friends are locksmiths, and both say that they cannot cut a key from scratch for the drivers door because it is a security key. That leaves me with the only option being to hopefully order a replacement door key from BMW, provided they have it on file. Oh yeah, to make matters even funnier, I left the title in the glove box and Im pretty sure they require that to give a replacement key.
Does anyone have any other suggestions?
2006 BMW M6-Interlagos Blue/White Interior - 420 hp / 300 tq.
Modifications Include:
Vossen VVS-CV3 Black/Machined Concave Wheels - 20x10.5 & 20x9
15% Tint All Windows / 50% Tint Windshield
Plastidipped Front Kidney Grilles / Lower Front Grille / Side Grilles
All Grilles Painted Carbon Matte w/ Shadowcast
Rear Tips Painted Carbon Matte w/ Shadowcast
Tinted Side Marker Lights
Silver/Black Headlight Turn Signals
All Emblems Replaced With Black/Carbon Fiber Emblems
Lumma Carbon Fiber Roof / Trunk Spoiler - Body Color Painted
CarbonFounder Carbon Fiber Front Bumper Splitter - Body Color Painted
Carbon Fiber Emergency Brake Handle, Steering Wheel Trim
Racing Industries Cat-Back Exhaust
Eibach Pro-Kit Lowering Springs
Tail Light / Reverse Lights Tinted
LED License Plate Lights
Front Turn Signals Tinted
HID 6K Angel Eye Rings
Silver Painted ///M Calipers / Hats
Rear Spacers / Black Lug Nuts
Performance:
RPI Scoops
RPI Filters
RPI Block Off Plates
Evolution Underdrive Pulley & Belt
Custom Magnaflow Exhaust w/ X Pipe
To do still:
Paint Bottom Grilles & Scoops Black(er)
Carbon Fiber Mirror Covers
LED Interior Conversion
Send SMG Module out for Software Upgrade to Vodik!
Previous Vehicle: 2006 STS-V - 573HP - See here: http://www.cadillacforums.com/forums...ged-573hp.html
STS-V is offline   Reply With Quote
Old 12th August 2012, 20:51   #2
intrepid one
intrepid one's Avatar
Garage: '01 M5 Carbon Black
Rock or hammer…apply to glass..
intrepid one is offline   Reply With Quote
Old 13th August 2012, 03:27   #3
MiamiSixer
MiamiSixer's Avatar
Garage: F13 M6 Alpine/Sakhir - On Order
Perhaps there is a way to pop the hood to jump it by removing the kidney grilles and looking in there?
MiamiSixer is offline   Reply With Quote
Old 13th August 2012, 03:33   #4
MiamiSixer
MiamiSixer's Avatar
Looked around a bit and on other models they have managed to pop the hood by accessing the cable through the fender by removing the liner. Might be worth a try.
Old 14th August 2012, 12:14   #5
tmiked
Garage: M6 Blue, E46 M3, MV Agusta F4 Senna
If your dealer has serviced your car and has records, he will probably order a key for you.
I ordered one and my dealer did not need any verification.
tmiked is offline   Reply With Quote
Old 14th August 2012, 18:57   #6
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
First things first:
1) Battery should not go completely dead. Not unless you left the headlights on or battery simply reaches it usable life.
And FYI, this is where BMW failed on the M6 design. On my previous 528i, 520i and E39 M5 - BMW has current sensing system that anything that draws power after 15 minutes - the system will shut down to prevent battery from going dead.
For some reason, they didnt put this same design on the M6 and I dont know why.
If you leave your headlights on or parking lights on - the battery will die in about 6 hours.
At any rate, once you get your car door open - fully charge the battery overnight and it should read 12.7 volts.
Anything less than that - its time for a new battery as it wont hold a full charge already.
Battery life is 6 years max. I recommend replacing preventively every 5 years.
2) I am not aware on how to manually open an M6 without a key.
I recommend just bring your car registration and title to your local BMW dealer showing proof you own the car and have them cut you a new key. It is usually between $100 - $200.
If you have a good working relationship with an SA, you wont need any proof and key will run about $80.00
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is offline   Reply With Quote
Old 14th August 2012, 19:43   #7
Clyde
Clyde's Avatar
Garage: Sepang Bronze M6 Coupe
Originally Posted by whatheheck View Post
...Battery should not go completely dead. Not unless you left the headlights on or battery simply reaches it usable life.
BMW includes a "kill the battery" feature
It is actually a parking warning light feature common on most European cars. The turn signal stalk will turn on the marker lights on one side of the car, and they will stay on until the battery is dead
Clyde is online now   Reply With Quote
The Following User Says Thank You to Clyde For This Useful Post:
whatheheck (15th August 2012)
Old 14th August 2012, 21:20   #8
M6Meister
M6Meister's Avatar
Garage: BMW M6 - MATTE WHITE
im glad i read this post in time and recently logged on.
the EXACT same situation happened to me. I had forgotten the angel eyes on and left the keys in the trunk for about an hour or so. This made the battery so weak, the keyless go was completely inoperable when trying to open the doors or trunk.
long story short TAKE ADVANTAGE OF THE PILLAR-LESS DOORS.
After a few calls i found a locksmith that couldnt cut the door key but rather slipped that pop-a-lock air pump between the rubber weatherstripping and window glass just above the door handle.
he then slid a very malleable rubber wrapped metal cord with the end bent into an L shape and hit the unlock botton on the center console triggering the alarm.
then he bent the metal to pull the inner drivers door handle twice which opened the door.
there with the alarm still ringing i opened the zipper to the ski bag between the two back seats and grabbed my car keys from the trunk and VIOLA i started the M6 easily.
Although i was happy to have had my keys and car back it easily showed my how someone would have access to my cars interior.
M6Meister is offline   Reply With Quote
Old 14th August 2012, 23:02   #9
imycool
imycool's Avatar
Garage: M6 Black saphire, indianopolis red
If i accidentally lock the keys in the trunk, the car beeps a few times and the trunk opens up again. It won't let me lock the trunk with the keys in the trunk? It won't let me even close the trunk!
imycool is offline   Reply With Quote
Old 15th August 2012, 00:57   #10
B767capt
B767capt's Avatar
Garage: 2008 M5 SMG
Just thinking out loud, we all just had that battery recall done and even pictures here on the site. Under the trunk and above the rear axle is the bottom of that recall bolt. I would get under there with jumper cables being sure and careful on the hook up. Then power the cables from above and the car should have voltage. I'm lucky because I park mine in the garage on a hyd lift.
Recall
Clydes post #73
B767capt is offline   Reply With Quote
'90 M5 3.6 EU Foldable keys + central locking LarsLaursen E34 M5 Discussion 3 27th May 2009 08:01
Funny story GBPackerfan1963 E39 M5 and E52 Z8 Discussion 9 23rd November 2008 04:41
Funny Story ROBBYD23 E39 M5 and E52 Z8 Discussion 21 21st April 2001 23:21
