PDC error after car wash? - BMW M5 Forum and M6 Forums
Like Tree1Likes
  • 1 Post By tampamark
Old 7th August 2012, 20:43   #1
STS-V
STS-V's Avatar
Garage: 2006 BMW M6-Interlagos Blue/White Interior
Went through the laser wash yesterday. While it was finishing, I saw the "PDC Malfunction!" warning on the speedometer. Figured it had got wet or something. Now it only works 1 in 5 times. Any idea what happened? Is the plug possibly lose or something? Where is it located?
2006 BMW M6-Interlagos Blue/White Interior - 420 hp / 300 tq.
Modifications Include:
Vossen VVS-CV3 Black/Machined Concave Wheels - 20x10.5 & 20x9
15% Tint All Windows / 50% Tint Windshield
Plastidipped Front Kidney Grilles / Lower Front Grille / Side Grilles
All Grilles Painted Carbon Matte w/ Shadowcast
Rear Tips Painted Carbon Matte w/ Shadowcast
Tinted Side Marker Lights
Silver/Black Headlight Turn Signals
All Emblems Replaced With Black/Carbon Fiber Emblems
Lumma Carbon Fiber Roof / Trunk Spoiler - Body Color Painted
CarbonFounder Carbon Fiber Front Bumper Splitter - Body Color Painted
Carbon Fiber Emergency Brake Handle, Steering Wheel Trim
Racing Industries Cat-Back Exhaust
Eibach Pro-Kit Lowering Springs
Tail Light / Reverse Lights Tinted
LED License Plate Lights
Front Turn Signals Tinted
HID 6K Angel Eye Rings
Silver Painted ///M Calipers / Hats
Rear Spacers / Black Lug Nuts
Performance:
RPI Scoops
RPI Filters
RPI Block Off Plates
Evolution Underdrive Pulley & Belt
Custom Magnaflow Exhaust w/ X Pipe
To do still:
Paint Bottom Grilles & Scoops Black(er)
Carbon Fiber Mirror Covers
LED Interior Conversion
Send SMG Module out for Software Upgrade to Vodik!
Previous Vehicle: 2006 STS-V - 573HP - See here: http://www.cadillacforums.com/forums...ged-573hp.html
STS-V is offline   Reply With Quote
Old 7th August 2012, 22:27   #2
tmiked
Garage: M6 Blue, E46 M3, MV Agusta F4 Senna
I have had the ones in the rear bumper 'pop out' a little.
You might check them physically, and any that look to be in non-original position, check its wiring.
tmiked is offline   Reply With Quote
Old 7th August 2012, 22:29   #3
STS-V
STS-V's Avatar
Thanks for the response - can I do it from under the bumper?
Old 8th August 2012, 00:35   #4
STS-V
STS-V's Avatar
Nope they are all secured to the bumper and you cant reach but the outer two from under the car. Any idea where else these things connect?
Old 8th August 2012, 03:45   #5
tampamark
Garage: 650 convertible, Triple Black
First thing you want to do is determine if any of them have gone out. It is not uncommon to have one fail, if it does then the system gives you a PDC Failure error.
Get the car in the open away from any objects, activate the PDC by pressing the button above the gear shifter. These are Ultrasound Proximity sensors, you will need to check every one of them by placing your finger or hand in front of them, when you do this you will hear a very faint ticking sound. Plus the system will beep in the car. You know that it is working when you hear that slight ticking, you may need to get pretty close to hear this.
There are four in the front and four in the rear, if one is not working you will need to replace it. The only way to get to these is to remove the bumper, I am sure there are instructions on the forum for bumper removal in that instance, I can't recall seeing this but I am sure someone else has that covered! The TIS instructions are below for removing the sensor once you have the bumper off. It is rare but I have seen the PDC control unit go out, it is in the trunk and got water damage (PDC Malfunction - Bimmerfest - BMW Forums)
BMW TIS - 66 20 520 Removing and installing/replacing an ultrasonic transducer at front (Park Distance Control)
BMW TIS - 66 20 540 Removing and installing/replacing a rear ultrasonic transducer (Park Distance Control)
If you do determine that this is the culprit the sensors the 6 guys have had good luck buying them from an ebay seller:
Ebay Listing: BMW Ultrasonic Front Bumper Sensor # 66200306567 | eBay
PDC control parts: http://parts.bmwofsouthatlanta.com/p...209145158.html
tampamark is offline   Reply With Quote
The Following 2 Users Say Thank You to tampamark For This Useful Post:
STS-V (8th August 2012), whatheheck (8th August 2012)
Old 8th August 2012, 21:54   #6
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
Great info. What a guy.
Thanks Mark!
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is offline   Reply With Quote
The Following User Says Thank You to whatheheck For This Useful Post:
tampamark (14th August 2012)
Old 16th August 2012, 14:47   #7
STS-V
STS-V's Avatar
Thanks for the info! I made sure the connections were tight and that seemed to fix it.
PDC error cant find fault any ideas jamiechapman E60 M5 and E61 M5 Touring Discussion 2 2nd May 2012 08:35
Error beep on PDC activation gherardini E39 M5 and E52 Z8 Discussion 17 25th February 2011 12:54
Blocked LCM/PDC, Error coding index for RAD! Htp E39 M5 and E52 Z8 Discussion 0 21st July 2010 16:34
Error with rear PDC? dookie E39 M5 and E52 Z8 Discussion 11 8th December 2006 20:24
How often do you wash your car? Bluewater M5 E39 M5 and E52 Z8 Discussion 46 7th April 2002 07:50
