First Wet System M6 Nitrous Install Going Well... - BMW M5 Forum and M6 Forums
Like Tree93Likes
Old 30th July 2012, 23:37   #1
USAF
Garage: 07 M6 6-Speed Black, 67 Chevelle SS Marina Blue 5 Speed, 72 Ford F-600 Green 4 speed, 62 Studebaker P/U 4-speed, 01 Chev S-10 5 Speed, 1959 Chevy Viking Dump Truck 4-Speed, 2007 Can Am Outlander
Not aware of any others that have installed a wet nitrous system yet but I know there's a few M6 dry nitrous systems out there. Am mostly finished with the installation of all the components and lines. Just got more fittings in the mail a few minutes ago so have more parts to now continue with the install. There's a requirement for LOTS of fittings and adapters and have no local source for those so have to wait for mail delivery. Am using all crimp fittings on the stainless braided lines and not using connections that are just clamped. The last fittings I'm waiting for are one NX part # 16077 & one 16078 1/8 NPT to 3AN Y's that go from the outlets of the solenoids. Also have to plug the purge ports on the 2 main solenoids with 1/8" NPT plugs.
If you're considering an install like this, start looking for 4AN & 6AN braided line on Ebay or other racing team sites that sell their used lines. These are usually Aeroquip and they are in almost perfect condition since the NASCAR race teams replace their lines very frequently. You'll get the 4AN main feed line with your Nitrous Express 20816-10 Nitrous System but you won't get a 6AN feed line with the SAFE Fuel System.
You'll need the following:
12" 6AN line to go from the SAFE Fuel System mounted in the trunk to the fuel pump mounted below the trunk. There's no need to drill a hole for this line as there's a rubber plug in the perfect place to route the line already. Just remove the plug. From the pump you then run your 6AN main fuel line. You'll need about 18 feet to go from the pump to the fuel pressure regulator/pressure gauge depending on how you route the line. I ordered 20 feet and just coiled the extra near the pump under the trunk. Then you'll need 18" of 6AN line to go from the regulator to the fuel filter/fuel solenoid. You'll get the 3AN lines that go from the nitrous & fuel solenoids to the nozzles with the 20816 kit but because of where I mounted the solenoids I used two additional 4' 4AN lines and 2 of the short lines that came with the system. You do get the fuel pump & regulator with the SAFE fuel system part # 15003.
For the nitrous lines you'll get the main feed line that goes from the bottle in the trunk to the nitrous filter/pressure gauge/purge valve assembly under the hood. From this assembly you'll need a 12" 4AN line to the nitrous solenoid. From the purge valve you'll need a 3' 4AN line to go to the NX part # 16082 Y-fitting to split into 2 purge lines if you want dual purge lines. Then you'll need a 4' 4AN line for the purge line to the drivers side and a n 8" 4AN line for the passenger side.
For fittings you'll need:
(2) 1/2" NPT male to 6AN male for the fuel pump.
(2) .041 jets for the nitrous & .032 jets for the E85 in the auxiliary SAFE Fuel System.
Then it depends on if your lines come with 90 degree, 45 degree, or straight ends. If you live near a big city where you can just go to a store and get the fittings you need as you install that would be the best. You might have different preferences on where you want to mount components and that would also determine the fittings/lines you'll need.
To install the nozzles it requires a 9/16th" hole in each of the induction tubes. There's like a double nut that clamps on to the air tube from both sides as you tighten it. I sealed that from inside & outside the tube with ultrablack gasket maker. I also put Loctite Blue on the threads to keep it tight. When I drilled the two 9/16" holes I just pushed a clean rag in the tube past where the holes would be and pulled it out after the drilling so the plastic from the holes came out with the rag. The plastic of the tubes is very thick so it's a nice solid mounting surface.
Here's a few pics of where everything is installed and I'll add pics and videos as I get the system going. Rocket5979 (Rob) will be helping me with the electrical part of this system as he has lots more experience with nitrous systems than I do. We'll do dyno runs with & without the nitrous also. With this jetting it's supposed to be +150 HP at the wheels so we'll see how it does at the dyno. Evolve is doing a tune which will retard the timing 4 degrees for when I use the nitrous. This tune will be taking into account all of my mods just like my main tune except for the timing retard. You'll also need the NGK plugs that are 2 steps colder & I have a thread here that discusses those.
Ask any questions you may have & I'll try to answer as best possible.
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out and loudly proclaiming: "WOW! WHAT A RIDE!!"
DO EPIC S#!T!!!
USAF is offline   Reply With Quote
The Following 5 Users Say Thank You to USAF For This Useful Post:
CatsFan (4th August 2012), Hasan Shaikh (31st July 2012), MKSixer (31st July 2012), TZ04XJR (1st August 2012), waleed_wales (1st August 2012)
Old 31st July 2012, 00:06   #2
irishbimmer
irishbimmer's Avatar
Garage: 2010 M6 Sapphire Black, Black Full leather, Carbon Fiber, Fully-Loaded, Manuafactured April, 2010
That dang thing is gonna be so ridiculously fast!
irishbimmer is offline   Reply With Quote
Old 31st July 2012, 04:23   #3
cartek
Garage: M5 Black Saphire metallic
Nice!
Subbed
cartek is offline   Reply With Quote
Old 31st July 2012, 04:26   #4
MKSixer
MKSixer's Avatar
Garage: 2007 M6 Silverstone Metallic
Great work and write-up!
Subscribed.
MKSixer-Milton
2007 BMW M6 Coupe
Silverstone Metallic-Silverstone II Full Merino Leather Interior-Alcantara Headliner-Gas Guzzler Tax-No HUD (WTF?!)
Tubi X-Pipe (Thanks Hasan!)-Tubi Rumore Section 3-Red RPI Scoops-RPI Block Off Plates-BMC Filters-Charcoal Filter Delete
ACS Front Strut Tower Brace-Dinan Carbon Fiber Rear Strut Tower Brace-Dinan Rear Anti-Roll Bar-Dinan Front Roll Control System-12.5mm TMS Front Wheel Spacers-15mm TMS Rear Wheel Spacers-Pirelli PZero Corsa System
Custom Finished Factory M6 Wheels-CF Front Spoiler-Matte Black VRS Type Rear Spoiler-Matte Black Grille-Matte Black Side Gills-BMW ///M Valve Stem Caps-BMW ///M Matte Black License Plate Frame-LED Side Markers
Formula 1 Tint: 35% Front Windows-20% Side Windows-15% Back Glass
Hard-Wired V1 Radar Locator-Aluminum ///M Pedals-M6 Embroidered Floor Mats
In Hand but not Installed: Interior LED Lighting-Evolve ECU Upgrade-LED Brow Lights
Next: Exterior LED DRLs-Angel Eyes Upgrade-RPI Oiler Cooler
MKSixer is offline   Reply With Quote
Old 31st July 2012, 04:34   #5
Jackson1019
Jackson1019's Avatar
Garage: Crown Royal XR
Can't wait to see what kind of numbers this thing puts up on the dyno.
Post a video of the nitrous purge and the dyno runs.
Props on doing the install by yourself, that doesn't look easy.
I don't like driving a car with traction-control lights flashing all the time. It's like having sex in a wetsuit
Horacio Pagani
Anthony
08 E64 Alpine White BMW M6 Drop Top
RPI Red Ram Air Scoops, BMC Air Filters, and Block Off Plates
Eisenmann Race Exhaust
Evolve-R ECU Tune
Matte Black OEM M6 Wheels
5 % tint all the way around
Black M6 Badges
Matte Black Kidneys
Red Calipers w/ M logo
Vorsteiner Black W/ White Trim Door Mats
Valentine 1 Radar hardwired w/ Blendmount
WeissLicht all interior lights LED Upgrade
WeissLicht License Plate LED
Looking for: Tubi X-Pipe
Eisenmann Race exhaust sound:
http://www.youtube.com/watch?v=AovubpAeilo
WWW.AMERICANFRICTION.COM
Jackson1019 is offline   Reply With Quote
Old 31st July 2012, 07:25   #6
IndyRedBeast
IndyRedBeast's Avatar
Garage: E60 Indy Red M5 & E65 Titanium Silver 750i
WoW I wonder how it would feel
Performance:
Meisterscahft Section 1 Pipes
Meisterschaft Section 2 X-Pipe
Eisenmann-Race Section 3 Cans
Eurocharged ECU Tune
Evosport Power Pulley
BC-Racing Coilovers
Stoptech SS Brake Lines
Stoptech Street Brake Pads
ATE Super Blue Brake Fluid
M Sprint Booster V2
Simota CF CAI
RPi Scoops
Wheels/Tires:
20" Varrstoen ES1
Hankook V12 Evo
TMS Spacers
Rolled Fenders
Gloss Black Calipers
M Caliper Decals
Exterior:
Hamann Painted Splitter
Custom Black Extension Lip
Hartge Painted Diffuser
Custom Rear Bumper Grille
Gloss Black Sideskirt Extebsions
Gloss Black OEM Grilles
Gloss Black Side Gills
Gloss Black Vinyl Roof
Gloss Black M5 Emblem
Gloss Black/White BMW Roundels
Interior:
Alcantara E-brake/SMG Boots
Alcantara/Perforated Leather Wheel
Alcantara Steering Wheel Trim
Alcantara Full Headliner
CF 3M Di-Noc Trim Wrap
CF Steering Emblem
CF Door Pins
Lighting:
Custom Painted Headlights
Orion V2's/Euro Reflectors
OEM LCI Euro Taillights
V6.1 Bruce Cables
Full LED Interior Lights
LED Clear Side Makers
LED License Plate Lights
LED Reverse Lights
Solaris Invisi-Bulbs
6000k HID Bulbs
Currently 465whp Dynojet
_______________
Mikelll M5
IndyRedBeast is offline   Reply With Quote
Old 31st July 2012, 08:40   #7
KILLZBUGZ
KILLZBUGZ's Avatar
Garage: M5 SSII
I wish I could find someone to do this mod for me
So sick.
KILLZBUGZ is offline   Reply With Quote
Old 31st July 2012, 12:05   #8
Hasan Shaikh
Hasan Shaikh's Avatar
Garage: E63 ///M6 - White
Congratulations Dean!
Awesome stuff mate. Big fan.
With your permission, I would like to copy it to our local forums here.
Hasan
Hasan Shaikh is offline   Reply With Quote
Old 31st July 2012, 13:33   #9
USAF
Sure Hasan no problem.
The Following User Says Thank You to USAF For This Useful Post:
Old 31st July 2012, 13:43   #10
Pistolero
Pistolero's Avatar
Garage: E60 M5 Indianapolis Red, CLK63 Black Series
Awesome, how long before you finish? Need vids and dyno numbers. Kudos for DYI, takes some serious talent and gonads.
2006 E60 M5 Indy Red/Sepang (Sold)
Mods: Eurocharged ECU tune, 10mm H&R Spacers, ADV.1 5.1 Wheels, Charcoal Filter removed, UUC Corsa Exhaust, Valentine 1, 423.6rwhp on Dyno Dynamics
2008 CLK63 Black Series Black/Black (Sold)
2009 Yamaha YZF R6 (Sold)
2010 Land Rover LR4 (Wifey Car) (Sold)
Pistolero is offline   Reply With Quote
CUSTOM AUDIO SYSTEM...An Audiophiles Wet Dream :) fendiesal E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 42 29th April 2013 17:17
Want to install system in E39 M5.. looking for some input and advice olegd88 E39 M5 and E52 Z8 Discussion 5 7th November 2011 21:33
brand new NOS brand wet nitrous kit FS RussianM M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 2 8th November 2009 05:21
help: v1 system install thebeen E39 M5 and E52 Z8 Discussion 5 10th September 2003 14:42
Install of Pong's UFM system greg E39 M5 and E52 Z8 Discussion 11 10th September 2003 08:01
