31st July 2012, 21:21
#5
We dont really understand your question.
Power is power. Traction is traction.
If your tires are not fully warmed up and DSC is on - DSC will pull back power to keep the car on the straight line for you when your tires start to slip.
And with DSC off, if your tires are not fully warmed up - the tires will be slipping and sliding which will raise your RPM as the tires spin faster.
It is also almost impossible to shift from 1st to 2nd and immediately hit 8,200 RPM not unless again your tires are slipping badly.
Originally Posted by built240
So ive been playing around with trac lately. On a straight away with track off I notice when getting on it in 1st, once I hit around 8200rpm and shift into 2nd I notice immediately 2nd gear is almost at 8200rpm as well and its time to shift into 3rd. Its almost like even with trac off the car for some reason slips from 1st to 3rd but its not actually slipping. Its hard to describe what I mean. I'll have to record it. But when trac is on it almost feels like it shifts smoother and the car actually accelerates faster from 1st to 3rd.
Now on the freeway ive noticed with trac control off when shifting from 2nd to 3rd to 4th the gears hold much longer and the car pulls harder.
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
