Maintence questions - Exhaust popping - low oil? - BMW M5 Forum and M6 Forums
Old 27th June 2012, 18:37   #1
STS-V
STS-V's Avatar
Garage: 2006 BMW M6-Interlagos Blue/White Interior
Hi all,
New owner and I have a few quick questions to any of the experienced members on this board.
First off, I noticed recently (maybe after my filter, blockoff plates, scoops and pulley) that the car has A LOT more popping in the exhaust. Almost like back fire. It happens even when driving normally, like between up shifts.
Which brings me to my next issue - I have maintenance required on the spark plugs. Do you think this could be causing the new backfiring / popping in the exhaust? Which plugs do you guys recommend, and is it something I can do (or have my mechanic do) or should this just be a dealer trip? I see that "vehicle check" is required. Do I need a special tool to reset these warnings on the DIC?
I also have a note that I am quart low of oil. Which oil should I use, can I get it at autozone? Does the level reset itself accordingly? I remember seeing some posts that something needed to be done to reset the oil level indicator.
Thanks in advance for any helpful responses!
2006 BMW M6-Interlagos Blue/White Interior - 420 hp / 300 tq.
Modifications Include:
Vossen VVS-CV3 Black/Machined Concave Wheels - 20x10.5 & 20x9
15% Tint All Windows / 50% Tint Windshield
Plastidipped Front Kidney Grilles / Lower Front Grille / Side Grilles
All Grilles Painted Carbon Matte w/ Shadowcast
Rear Tips Painted Carbon Matte w/ Shadowcast
Tinted Side Marker Lights
Silver/Black Headlight Turn Signals
All Emblems Replaced With Black/Carbon Fiber Emblems
Lumma Carbon Fiber Roof / Trunk Spoiler - Body Color Painted
CarbonFounder Carbon Fiber Front Bumper Splitter - Body Color Painted
Carbon Fiber Emergency Brake Handle, Steering Wheel Trim
Racing Industries Cat-Back Exhaust
Eibach Pro-Kit Lowering Springs
Tail Light / Reverse Lights Tinted
LED License Plate Lights
Front Turn Signals Tinted
HID 6K Angel Eye Rings
Silver Painted ///M Calipers / Hats
Rear Spacers / Black Lug Nuts
Performance:
RPI Scoops
RPI Filters
RPI Block Off Plates
Evolution Underdrive Pulley & Belt
Custom Magnaflow Exhaust w/ X Pipe
To do still:
Paint Bottom Grilles & Scoops Black(er)
Carbon Fiber Mirror Covers
LED Interior Conversion
Send SMG Module out for Software Upgrade to Vodik!
Previous Vehicle: 2006 STS-V - 573HP - See here: http://www.cadillacforums.com/forums...ged-573hp.html
STS-V is online now   Reply With Quote
Old 27th June 2012, 19:29   #2
Tetova5
Tetova5's Avatar
Garage: 2006 BMW M6
You can do the spark plugs yourself if you have the right tools. I just did mine and it was very easy just take your time don't rush. There's a write up on here if you search. As for the oil you wont find any at AutoZone. You have to go to the dealership for the castrol tws or order from sponsors. If you have liqui moly 10w60 you can get it online or see which store carries it. I got mine at Napa.
Tetova5 is offline   Reply With Quote
Old 27th June 2012, 19:32   #3
STS-V
STS-V's Avatar
Thanks. Any idea which plugs? And how do I reset the DIC?
Old 27th June 2012, 19:51   #4
Tetova5
Tetova5's Avatar
Garage: 2006 BMW M6
I used the ngk laser platinum LKR8AP. I used this video from YouTube different car but same in operation of DIC. YouTube - Broadcast Yourself.
Old 27th June 2012, 19:54   #5
STS-V
STS-V's Avatar
Do you think that plug is inferior to the factory replacement which is a NGK double platinum 4471?
Old 27th June 2012, 20:33   #6
Tetova5
Tetova5's Avatar
Garage: 2006 BMW M6
LKR8AP is the part number for 4471. Its the same plug so yes. I found mine on ebay because they were cheaper
Old 27th June 2012, 20:36   #7
STS-V
STS-V's Avatar
Thanks I ordered a set. Got the oil from my local BMW dealer in stock for $27 or something for 2 liters.
Any other advice on the other problems?
Old 27th June 2012, 20:39   #8
Tetova5
Tetova5's Avatar
Garage: 2006 BMW M6
Does your exhaust pop a lot? Your air/fuel mixture might be off for all the changes done so you might wanna think about a tune. Just my thought I could be wrong but thats what was going on with my other car and once tuned it stopped.
Old 27th June 2012, 20:40   #9
STS-V
STS-V's Avatar
Yes it does - and it seems like after I put on the intake scoops filter and pulley. I thought a tune wasnt required with those mods, as the engine computer "self learns." I checked for an exhaust leak, and found nothing.
Im almost wondering if a tune is necessary now.
Old 27th June 2012, 20:47   #10
Tetova5
Tetova5's Avatar
Garage: 2006 BMW M6
Well you don't have to get a tune for those mods. Take off the negative side of battery for about 10 mins let it reset it computer and see what happens I know when I installed a cai on my GTO it did the same once I unplugged the battery it learned the mods. The directions also said to do so.
The Following User Says Thank You to Tetova5 For This Useful Post:
Vtm6cabrio (27th June 2012)
50K Preventive Maintence and Service Redneck M5 E39 M5 and E52 Z8 Discussion 3 7th September 2011 06:05
Radio has frequent low-freq "popping" sound HenryHank E39 M5 and E52 Z8 Discussion 5 24th May 2010 18:45
Fluid for the 6 speed? Preventitive maintence? paulmer E39 M5 and E52 Z8 Discussion 23 16th May 2010 00:12
Dinan exhaust - slight popping on deceleration - Is this to be expected? HPINFO E39 M5 and E52 Z8 Discussion 34 23rd December 2007 01:25
new mafs and precat sensors but exhaust popping. max95se E39 M5 and E52 Z8 Discussion 0 20th June 2006 02:26
