Problems with engine temp and high idling - BMW M5 Forum and M6 Forums
Like Tree3Likes
Old 26th June 2012, 12:37   #1
IM6
IM6's Avatar
Garage: M6
Hi Guys,
Need your thoughts please.
I have been having this problem quite consistently over the past few months. Its ironic that it happens to be since I got the latest Evolve map. I dont want to suggest that its map related but it could well be, i tried eliminating the doubts by switching over to stock map with the help of evolve r cable and the symptoms still persist.
The problems I am facing are as follow:
Engine used to heat up very quickly, i mean within 2 mins from cold start it shot to 100C, that was strange. However, I realised that the oil gauage wasnt reading correct oil levels and it was running low to like 0.3 - 0.4 L but still not in the dangerous territory to have the engine heat up so rapidly and this was all during normal driving conditions. I managed to rectify the problem by topping up. The problem now is that if i drive a little spiritedly it goes slightly over 100C which is worrying.
Secondly: Since the evolve map my idle rpm is consistently at 1K rpm, before it would sit at where it would normally be such as 500rpm. This problem is intermittent though and i also believe both problems are inter-related.
Hassan on the forum very kindly has suggested flushing the coolant plus changing one of the batteries. The ECU has picked up coolant sensor faults numerous times but the dealer wont look at it as it hasnt shown up on their system as I do have extended warranty.
Regards
06 M6 SPACE GREY
SUPERSPRINT EXHAUST
SUPERSPRINT X PIPE
EVOLVE R TUNE
RPI SCOOPS & BMC FILTERS
LOWERED ON HARTGE SPRINGS
UPGRADED ANGEL EYES
INTERIOR LIGHTS
EXTERIOR LIGHTS
AFTERMARKET SPORTS STEERING WHEEL
VORSTEINER FRONT BUMPER LIP
PREVIOUS
BLACK 2005 645, LOTS OF MODS
E46 330 CONVERTIBLE
ALFA ROMEO GTV V6 SUPERCHARGED
IM6 is offline   Reply With Quote
Old 26th June 2012, 12:47   #2
Bavarian Beast
Bavarian Beast's Avatar
Garage: 2010 M6 Carbon Black
I think my engines have run around that temp normally on both of the beasts I own(ed) so not sure if that is really an issue. As far as the idling, perhaps that is a tuning thing or have you changed out pulleys or something? Seems like a rather large increase....
2010 Carbon Black 'vert
Other M6 playmates
2008 X5 3.0 silver
2000 ML320 red (always one black sheep in the family)
1999 528i silver
Gone but never forgotten - 2007 M6 - Sapphire Black exterior, Indianapolis Red interior, Carbon trim, RPI scoops, BMS filters (carbon filter delete), Kelleners installed Schrick cams-100 cell race cats-chip tune, Evosport Headers and pulley, Dinan exhaust, Eibach springs.
Bavarian Beast is offline   Reply With Quote
The Following User Says Thank You to Bavarian Beast For This Useful Post:
IM6 (26th June 2012)
Old 26th June 2012, 13:13   #3
IM6
IM6's Avatar
Garage: M6
No pulleys as yet. Could it be a battery issue, probably on its way out? it is a 6 year old car with 35K miles
Old 26th June 2012, 13:32   #4
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
If your car is 6 years old and running on original battery - I recommend changing the battery ASAP as you are now running your battery on borrowed time. Batteries useful live is usually around 5 years, 6 years max.
Get a volt meter and check your battery. Fully charged battery should be around 12.7 volts DC.
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is offline   Reply With Quote
The Following 3 Users Say Thank You to whatheheck For This Useful Post:
Hasan Shaikh (26th June 2012), IM6 (26th June 2012), MKSixer (30th June 2012)
Old 26th June 2012, 13:34   #5
IM6
IM6's Avatar
Garage: M6
thanks mate. If I end up needing to replace the battery, should I go down the the dealer route or after market route?
Old 26th June 2012, 14:57   #6
Hasan Shaikh
Hasan Shaikh's Avatar
Garage: E63 ///M6 - White
If its not your battery or altenator, you might have a problem with your fuel system.
Lets hope its just a mtter of voltage.
The car running above 100C during spirited driving is normal and is not dangerous. I think the oil cooler starts working only when the oil temp goes above 103Cs. Also, remember that youare running 10W-60 oil for a reason. It actually provides better lubrication at higher temps as it flows faster.
So, the only thing I would worry about it the raised RPM. Perhaps you should ask Sal to check the tune again. Especially the maps controlling the throttle actuators.
Good Lcuk!
Hasan
Hasan Shaikh is offline   Reply With Quote
The Following 3 Users Say Thank You to Hasan Shaikh For This Useful Post:
IM6 (26th June 2012), JonnybravoM3 (26th June 2012), MKSixer (30th June 2012)
Old 26th June 2012, 15:24   #7
IM6
IM6's Avatar
Garage: M6
Thats what I did, kept badgering him with questions but he is adamant that he didnt tweak the throttle or the rev, when I swicthed to the stock map the problem was the same. Someone mentioned to check the water level as that could cause to raise the rev.
thanks for all your advise. I still need to look into the fuel system such as the fuel filter as you suggested. I dont think injectors would have any issues. The petrol consumption is quite heavy actually. I get no more than 2 miles per litre, if I am cruising then 3-3.5 if i am lucky.
Old 26th June 2012, 15:26   #8
Hasan Shaikh
Any problem with the fuel system will actually give you a fault code.
Check the voltage and the carbon filter behind the fuel tank.
The Following User Says Thank You to Hasan Shaikh For This Useful Post:
Old 26th June 2012, 15:30   #9
JonnybravoM3
JonnybravoM3's Avatar
Garage: 2008 E64 BMW M6 Cabrio
Whenever I had idling issues it was always related to the vanos. Let us know how you get on pls interested to hear what happens and good luck!
Stable:
2008 E64 BMW M6 Cabrio (Black Sapphire Metallic / Portland Brown)
- ECU / Intake/ Race Exhaust
2011 Ferrari 612 Scaglietti F1 HGTS (Grigio Silverstone / Rosso)
2012 Toyota FJ Cruiser (Military Blue / Black)
2013 Audi Q5 3.0 TFSI (Maya Brown / Cognac-Black)
JonnybravoM3 is offline   Reply With Quote
Old 26th June 2012, 15:50   #10
IM6
IM6's Avatar
Garage: M6
Johnny Bravo: how bad was your idling? i am sure it would throw up a fault code if the vanos would be faulty. Vanos recall was done right at the begining by the way.
Engine idling G1M559 E60 M5 and E61 M5 Touring Discussion 16 10th May 2012 05:50
Idle Speed, Engine Temp and Oil Temp mercutio2511 E39 M5 and E52 Z8 Discussion 27 19th February 2012 23:59
High Oil Temp Reading (and high Coolant maybe?) olis1 E39 M5 and E52 Z8 Discussion 46 21st May 2010 05:31
Radiator fan broke [now changed] + high idling on ESS equipped M5 agreenrhino E39 M5 and E52 Z8 Discussion 62 18th December 2009 17:14
(08-beast)Increased Emission, Engine Temp too high, Please Help... Shuang86 E60 M5 and E61 M5 Touring Discussion 1 23rd August 2007 08:37
